Question about Panasonic KX-T7560 1-Line Corded Phone
How do I store a number for autodial at a later date?
  • Panasonic Master
  • 2,460 Answers
Autodial? You're going to use one of the 8 buttons for autodial or are you trying to put system speed dialing in? The phone buttons are easy if you dial "9" to get an outside line. You press PROGRAM a button, and dial 29 plus your number and STORE.
Now, obscurely, you can program one of the 8 buttons to SAVE a number. Thats done by PROGRAM the button 5 STORE. When you dial a number that you want to save, you press Autodial and SAVE (the button you programmed) and it will save that number under the button.
Now, grab a line and press the SAVE button and it will dial your saved number.
Last, if you're not totally bored, you can store 10 Personal speed dial numbers on your phone. They program by 2* (0-9) number # and are dialed by pressing # (0-9).
Yeah. BTW this is an instruction set for a TA-624, common for the type of phone you have. I think it applies to most of the TA series KSU's.
Carl
Posted on Mar 25, 2011
Where can I find operating instructions for a Jazz 4400 telephone. I want to change the speed dialing to 10 digit but can't find the original instructions.
Jazz 4400- Programming an Autodial key: 1) Lift handset wait for dial tone 2) Press SAVE key 3) Dial the number you wish to save 4) Press SAVE key again 5) Press the Autodial key that you want to save number to. // Notes: The number can be up to 16 digits. If you need to add a pause (for PBX system) press REDIAL key. //
Jazz 4400 has 10 Autodial keys each can store 2 numbers for a total of 20 saved numbers. Press SHIFT key before Autodial key to access second number. Their is a HOTLINE key to store one frequent or emergency number programmed same as Autodial.
Aug 20, 2014 | Nortel Jazz Plus 4400 Speakerphone -...
When i pickup the phone i want the intercom to be my first option not a line out?
One of the following two methods of programming "Preferred Line Assignment-Outgoing" should work depending on which Panasonic phone system your KX-T7433B phone is connected to. Try number one first, if PROGRAM 99 does not get you into station programming, try number 2.
1) Press PROGRAM button then dial 99 to enter station programming. Dial 1, then press INTERCOM button to select Intercom as your Preferred Line Assignment-Outgoing choice. Press AUTODIAL/STORE button to save programming. Press PROGRAM button to end station programming or lifthandset then replace in cradle to end station programming.
2) Press PROGRAM button then dial 19, press AUTODIAL/STORE button. Press INTERCOM button then AUTODIAL/STORE button. Press PROGRAM button to end station programming or lift handset and replace in cradle to end station programming.
Feb 11, 2011 | Panasonic KX-T7433B Corded Phone
I am getting a pref.Out :NO .. after I press the program> auto Dial> then I press 10 ( which is the line I want to store a number on ) and the I get pref.Out :NO
HUH? You program autodial for the SYSTEM from a SYSTEM phone in SYSTEM programming. You program the "auto dial" buttons, the ones on the right side of your phone from the phone by pressing PROGRAM one of the 12 buttons and dialing "9" plus the number SAVE.
If you are trying to program one of the left side buttons for autodial (bad move) then you dial "29" first.
Carl
Oct 19, 2010 | Panasonic KX-T7731 Corded Phone
How do I change the number on a speed dial
You can program a memory button with a new number or
feature.
External autodial:
1. Press (Feature), ( * ), (#1).
2. Press a memory button.
3. Dial the external number.
4. Press OK to store the number.
5. Label your new button.
Internal autodial:
1. Press (Feature), ( * ), (#2).
3. Dial the extension number.
How to erase memory buttons:
3. Press OK to erase the button.
Alternatively, you can download the Nortel T7316 Quick Reference Card from IdacomUSA, your solution for Nortel Repair and Refurbishing.
Feb 11, 2010 | NorStar T7316E Corded Phone
CANNOT ENTER NUMBER INTO AUTODIAL.
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00.
3. Enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial.
4. Press AUTO DIAL / STORE to save your setting.
5. To go to the next speeddial location press SP-PHONE and follow steps 3 and 4 again.
6. Press PROGRAM to exit program mode.
7. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
Feb 03, 2010 | Panasonic KX-T7730 Corded Phone
Changing date and time on kx-t7731 phone
Program,**,1234,000,(change date and time),autodial/store,(lift handset
Jan 07, 2009 | Panasonic KX-TA824PK Phone
Trouble with the display
Hi Mary
Which system are you using?
If you are using panasonic kx td 1232 then just press the * key keeping the handset on hook.
If you are using a panasonic kx tda system then just press the transfer button keeping the handset onhook.
To change the date you will need to goin the program mode by pressing the Program button followed by *# 1234. then it will show on the display sys pgm no : enter 000 and press autodial or enter. Then you can change the date.
Aug 08, 2008 | Panasonic KX-T7453 Corded Phone
TIME SETTING
OK - have done some button pressing & here's the solution...
1 - press the PROGRAM button then 0
next enter the date the number 3 (not too sure on that bit) then the time ten AM (being 0) or PM (being 1) in the following format
2 - 080514 3 12.05 1
(this being 08 (year) 05 (month) 14 (day) 3 (?) 12.05 (time) 1 (PM)
3 - press the AUTODIAL / STORE button
4 - press the PROGRAM button
That's it !!
Apr 22, 2008 | Panasonic KX-T7730 Corded Phone
Changing time on PAnasonic KX-T7633?
This is what worked for me :
program, **, passw 1234, you change the time/date, and then to store, press Autodial or store button.
Hope this helps!
Caroll
Mar 10, 2008 | Panasonic KX-T7633 Corded Phone
How do I set the time and date?
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following. 1. Push PROGRAM key 2. Dial "0" 3. Enter year (last 2 digits) 4. Enter month (01-12) 5. Enter day (01-31) 6. Enter day of week (Sun 0, Mon 1, Tue 2, Wed 3, Thu 4, Fri 5, Sat 6.) 7. Enter Hour (01-12) 8. Enter Minute (00-59) 9. Press 0 for AM 1 for PM 10. Press "AUTO DIAL/STORE" key 11. Push PROGRAM key to return to normal mode.
Sep 14, 2007 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7560 1-Line Corded Phone Logo
270 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
