Question about MXR Stereo Chorus Pedal Guitar
The effect light won't stay on so I don't know by looking if effect is activated or not. The light goes on when I step on it but as soon as I release it goes out.
  • MXR Master
  • 5,603 Answers
Chances are the switch itself is defective... Either the toggling mechanism in it is bad or it has excessive contact bounce. Replace the switch.
Posted on Mar 25, 2011
My behringer um300 pedal won't turn on when pressed. the sound goes through, but any slight movement makes a loud, scratchy sound.
It's probably the activate button. Maybe it is stucked, but more probably that is damaged so when you tap it with your feet, it's making these sounds...
If you don't have any or very small experience in electronics, then take it to the electronics service center for electronics engineers to look it up,
Cheers!
Sep 05, 2016 | Behringer UM300 Ultra Metal Distortion...
How do I use a Seiko electronic tuner?
Hi! Have you read the manual? That is a good place to begin. Maybe you did not get one (if you bought your tuner used, or found it, or stole it, or something). You did not mention your model number, but one of the really common ones is the SAT500. Here's a download site for its manual:
http://www.manualslib.com/manual/657760/Seiko-Sat500.html
Just stay cool. Concentrate on one thing at a time. And take your time. You will soon become a competent user. I think you will find it pretty easy, once you get a good start. Truly.
Jul 24, 2014 | Seiko Auto/Manual Chromatic Tuner...
I have a bad pot on the very last knob closer to the bridge if i want to replace it could 250k be replace with 500k pot or vice verse
You can. If it is a tone control you may have a reduced effective rotation range. Probably this won't matter to most people. As a volume replacement, replacing with a lower value may reduce treble slightly, and a higher value increase treble slightly. It is quite a small effect though and you may even like it better.
Jul 02, 2011 | Fender ® Deluxe Active Jazz Bass?® V...
Hi there, I have an american DJ Dekker LED. I plugged it in and put it into Sound active / sound to light mode. I'm getting response to sound because I can hear and see the fan inside the unit...
I have OFTEN found that a cable has come loose. Open the unit and look for such a situation. Also make sure the motion (probably a disc) is working/rotating since with high power LED devices, they have interlocks for safety to keep beams moving.
Jun 24, 2011 | American DJ Supply American Dj Dekker Led...
Hi, I hope can help me with this problem because I start to get desperate. I have a Clavinova CVP-85A. The sustain effect is always activated, whether the pedals are plugged in or not. I read that to...
It sounds like the inputs from the pedal switches are "floating", that is, not pulled up or down and they are drifting across the logic threshold. If I could find a schematic I could direct you right to the problem. For now, check the voltage across the switch contacts with a high impedance meter. Also check the resistance to ground of the common of the contacts. Without a schematic I am afraid to have you try things lest I direct you to do something that would cause damage.
Jun 07, 2011 | Yamaha Music
My husband purchased one of your xr8600 peavey mixer the problem hes having is he cant get the echo settings right.please can you help.
View videos on YouTube regarding "mixer setup". Find the parts of setting up of "effects". Don't worry that you have a different mixer, the principles are all the same for analog mixers. Steps are this: Set the EFX send level for EACH of the input channels (knob above each channel gain) for the proportion you want for each channel. Check that the level you are sending does NOT cause the effect clip light to light very much. Set the effect you want, delay, echo, etc. with the selector knob. Advance the output sent to the power amp with the two knobs in the upper right of the panel. Adjust the "time" knob for the delay or effect depth you want. Then go over the same settings in the same order until you get the sound you want.
Apr 24, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Eurodesk sx3242fx has the numbers 1 & 25 flashing in the effects processor display. where can I find the code to tell me what is wrong?
Hi ! I have the same problem. THERE IS DEFINITELY something wrong there. It's not that you've not selected the effects, but the units keep on resetting. Even if you can select a different preset, it will go back to 1 & 25. I've been told that the problem has something to do with the power source, but I'm still trying to get a solution. Best luck !
Feb 09, 2011 | Behringer Eurodesk Sx3242fx Mixer Weffects...
My boss metal zone works when you dont have it activated but when you step on it, it won't work. It kind of makes a buzzing noise but thats it. Whats the problem and can it be fixed?
hello i repaired 1 of these last year if you open it up you may find that 1 of the diodes has blown change it, but you may have to change the 3 long transistor as well also look for any dry joints
regards
shaun
Oct 21, 2010 | Boss Mt 2 Metal Zone Effects Pedal
When i press the harmony effect i have to hold it
Well i hope the latching mechanism isn't busted!
Check/review your parameter settings for your programs. Especially in the Expression Pedal Control areas.
From their site:
--Harmony Footswitch
This footswitch turns the harmonies on or off. While multiple harmonies can be selected within a preset, the HARMONY footswitch activates or deactivates any selected harmonies simultaneously.
When the LED above the HARMONY footswitch is illuminated, the harmonies are on. When the LED is turned off, the harmonies are turned off.
--Note: The settings for FX Footswitch Control, Harmony Footswitch Control and Guitar Sensitivity apply to ALL presets. The setting for the Expression Pedal Control applies to the current preset only. If you modify the Expression Pedal setting and wish to store it you must Store the preset (see page 11 ). When you load another preset, its setting for Expression Pedal Control will take effect.
--To perform a Factory Reset procedure
If you are editing a preset, press the Up or Down footswitch to exit edit mode.
Press and hold the Major/Minor button and then press and release the Store button. The display will read FAC RESET- WILL ERASE ALL YOUR PRESETS... , then STORE=RST.
Press the Store button again to continue with the factory reset. If you don’t want to do the factory reset, just wait 5 seconds, or press almost any other button, to cancel.
Mar 27, 2010 | Digi-Tech Digitech Vocalist Live 4...
NO LIGHT OR SOUND
A BARE USB cable should NOT have caused any problem. If it was an "Active" type cable that does a conversion something might have happened. Another possibility is you had a static charge on you and the static did damage. Another possibility is if the connector really wasn't the SAME type and pins were shorted. Turn off the power and with a bright light compare the connectors to see if this last possibility might be the case. Also look for signs of arcing or bent pins. If the connector was forced, then it is possible the circuit board was cracked.. In any event servicing is required.
Search the web for a "Factory Reset" sequence for the unit. Usually you have to hold a button or a combination as you turn power on.
Jan 16, 2010 | Pioneer DJm 400 Professional DJ Mixer
MXR Stereo Chorus Pedal Guitar Logo
63 people viewed this question
Top MXR Music Experts
Michial Gueffroy
Are you a MXR Music Expert? Answer questions, earn points and help others
