Question about Acer Computers & Internet
Hi im trying 2 reset my bios but carnt get in there i need 2 know what on and off pins on the board i can take off and where r they located
  • 24 Answers
You should give exaclty the name and code of mainboard. Here are basic step for reseting bios:
1. Unplug the computer completely
2. Find the battery of BIOS, it is silver shiny, a bit bigger than the coin.
3. Remove the battery
4. Find the 3-pin jumper NEAREST the battery
5. lift up the jumper. the Jumper connect pin 1 & 2 (pin 2 is the one in the middle)
6. Use that jumper to connect pin 2& 3.
7. Leave it there 2-3 minutes
8. Put the jumper back to normal. IMPORTANT If you dont do this step, the computer cannot start.
Posted on Mar 25, 2011
  • Acer Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don
How to remove bios password
hi lata.
you can try this.
  1. Remove the computer cover.
  2. Locate the 2-pin password connector (PSWD) on the system board.
  3. Remove the 2-pin jumper plug and set the jumper plug aside.
  4. Replace the computer cover.
  5. Connect your keyboard and mouse, then connect your computer and monitor to electrical outlets and turn them on.
More items...
How to Perform a BIOS or CMOS Reset and/or Clear the NVRAM on ...
https://www.dell.com/.../how-to-perform-a-bios-or-cmos-reset-and-or-clear-the-nvram-o...
or go to this link.
How to remove bios password Google Search
Nov 06, 2017 | Computers & Internet
Ibought a computer with a Biostar Ta780G M2+ mother board and an AMd quad core chip I have to enter the bios to celect cd as priority after having to a new hard drive. Unfortunately I do not know the...
You can over ride the password by reseting the CMOS. To do this you need disconnect the computer from the mains and locate the CMOS reset pins (these are 3 small pins that have a plastic jumper over 2 of the pins, you should also see the word CMOS printed on the board around the pins). Once you have located this you need to slide the jumper off pins 1 and 2, then put the jumper on pins 2 and 3, wait around 10 seconds and then replace the jumper to its original position. Plug the computer back in, boot up and voila the password is removed!
Feb 27, 2011 | Computers & Internet
A200 bios password how to remove
HI,
The best way to remove the bios password is to reset your bios jumper. All boards have the jumper, you will move the jumper from it's current position to the next pin. Example. It has two pins. Jumper Pin 1 and 2. The jumper might current be set on pin 1 and blank. Move the jumper to pin 2 and blank. Leave it on for about 10 seconds and then move it back to the original position. This will reset your BIOS.
Good Luck
Mark
Dec 29, 2009 | Computers & Internet
Reset bios to factory settings in dell optiplex gx520
The BIOS password may be cleared from a Dell Optiplex by removing the password jumper (PSWD) from the motherboard.
Can click the link below to see how its done or follow the steps below :--
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&l=en&s=gen&~subcat=87&~cat=12
Choose the desktop model and continue.
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Else can follow Optiplex User Guides.
Hope it helps !!
Thanks.
Sep 14, 2009 | Computers & Internet
I have a sony vaio vgn-a290 laptop and im trying to reset the bios password. Ive found the dipswitch on the mother board but dont know witch one resets the bios password. could anyone help me
Pull cmos cell from motherbord for 10 minutes so all settings are goes to defaults.
Also you can reset its settings with jumper settings.
You can see 1 jumper onmmotherbord near cmos cell.
Read carefully on bord you read there RESET or CLEAR bios.
it has 3 pins.set jumper in 2-3 position then power up .
Then again set to its original position 1-2.
Then all settings defaults.
Let me know if you need more assistanse.
Thanks.
Sep 01, 2009 | Computers & Internet
Trying to locate a service/user manual for the motherboard
Remove the onboard battery out for about 30 minutes, this will cause the bios to go back to the default settings!
Or look on the board for CMOS RAM clear.
Pins 1 & 2 are normal mode and pins 2 & 3 will Clear the BIOS.
Here is some info from Compaq.
Mar 15, 2009 | Compaq Presario S4000NX (DF213AR) PC...
I have a probleme with a MSI 945P NEO5 Motherboard CPU install is an Intel Pentium4 3.0MHZ. The problem is the voltage reading is out of specification in the semos and even when analising it with the...
It seems like your board has been overclocked you must enter BIOS
2 methods to do so
1) Press one of these keys to do so
DEL F2 ctrl + esc.
or check lower part of screen during boot up will tell you which key to press.
When in BIOS reset to "Default" and see how you go
2) check M/board somewhere on it will be BIOS reset pins
either a 2 pin setting with no jumper across them fit jumper across them for 2/3 minutes then reset to normal and boot.
Or a 3 pin setup change jumper across middle and other pin 2/3 mins then reset them back to standard
either method should do to reset BIOS to default
Jan 28, 2009 | MSI 945P NEO5-F Desktop Board - Core 2...
Felly08
Dont know why
But try resetting BIOS
1) remove M/board battery for 1 to 2 hours refit and see if bios is back in default mode
2) on M/board will be a 2 or 3 pin reset jumper switch with word on M/board reset bios or similar
On a 2 pin remove the jumper from 1 pin and fit it over both for 3 or 4 seconds then replace back to where it was and reboot
On a 3 pin remove jumper from the 2 pins it is on and fit over middle pin and the one it was not on same time then refit back to how it was and reboot
Your computer should now start and allow you into BIOS
Aug 07, 2008 | Computers & Internet
Pc chips m811
try to reset the BIOS to default either take the M/board battery out for at least 1 hour reinsert battery and try or
On M/board will be writing with reset bios or similar usually a small 2 pin connector with a jumper on 1 pin connect jumper over both pins remove jumper refit over 1 pin and reboot
If 3 pin setup remove jumper and fit over middle pin and the one it was not on replace back to how it was and boot computer
Aug 04, 2008 | ASUS K8V-MX Motherboard
Motherboard problem
if you have tried resetting the bios by putting the jumper across pins 2-3, then back to pins 1-2 and it still wont boot into the bios and you know the memory is ok, then the bios chip on the motherboard is damaged and may not be easy to replace as the board is quite old.
Aug 11, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Computers & Internet Logo
151 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
