Question about Imperial IFS40 Deep Fryer
My pilot won't stay lit and I've replaced the pilot and thermocouple. Any ideas as to what I can do to fix this problem?
  • Imperial Expert
  • 684 Answers
Your gas valve may also needs to be replaced.
Posted on Mar 31, 2011
Royal commercial oven pilot
replace the thermocouple first. it can be purchased at you local hardware store.
if that does not fix it, you will need to replace the Baso, pilot safety. that can be purchased at partstown.com
Jul 07, 2013 | Ovens
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
Pilot won't stay lit...gaffers&sattler model B35
Hit the flame sensor next to the pilot with sandpaper. If it still doesn't work replace it.
Feb 26, 2013 | Heating & Cooling
I have a Dayton 3E290 wall heater that was installed new 30 years ago. The pilot light started to extinguish a few years ago. Gradually this began to occur more frequently. I've changed the...
The pilot assembly may need cleaned out and the orifice cleaned, also the gas valve may need to be replaced, to check for proper voltage from the thermocouple you need a flame source and it takes a meter that can register DC milliamps, and should be 350 to 750 millivolts. Heat the thermocouple with the pilot or other flame source and check, if OK, gas valve is weak.
Nov 02, 2011 | Dayton Gas Furnace Heater
Pilot won't stay lit, replaced thermalcouple but
I would remove pilot light assembly and clean orifice and blow out gas line to pilot. Check to see that thermocouple is centered in pilot flame. It is possiblethat your gas valve is bad but it is also possible that you got a defective thermocouple. I would change the thermocouple again as they are much less expensive then the gas valves. The next time when you are sure you have the thernocouple mounted as close to the center of the pilot flame hold the pilot button down for several mins. If none of this works then you may have to change your gas valve.Thank you.
May 06, 2011 | Rheem Water Heaters
Pilot light will not stay lit; replaced the thermocouple, still no work. Replaced the W/R gas valve 36C04-222 on my Trane furnace. Still not working. any ideas? Could I have gotten a bad replacement valve?...
Trane unit ,same White -Rogers gas valve. I have replaced both the gas valve and the thermocouple . Have agreat robust blue pilot while the button is pushed in , let go and the flame does not stay lit . I checked the milly D C volts and have better than 20 . Is there a problem with the new gas valve or the couple not generating enough volts or is there a safty I do not know about that could be open ?
Dec 15, 2010 | Heating & Cooling
I have a readyheater model 65-85 the flame will not stay lit im thinking thermal couple is there a way to test this part? or could it be another problem?
If your pilot light will not stay lit when you release pilot light button then chances are that your thermocouple is bad. Make sure that the tip of thermocouple is directly in line with pilot light. Tip of thermocouple should be cherry red if it is properly placed. If pilot will not stay lit then replace it. If you aren't sure about placement of thermocouple you can heat thermocouple with a seperate heat source. If you do this and pilot light stays lit then reposition thermocouple in pilot flame. If it still won't keep pilot burning then replace thermocouple. Hope this helps. Thanks.
Nov 19, 2010 | Reddy Heater-30-55,000 BTU Variable
your thermocouple needs to be replaced. they are available at any hardware store.
Sep 16, 2009 | Water Heaters
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
May 30, 2008 | Coleman (5040B750) Patio Heater
Imperial IFS40 Deep Fryer Logo
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Joseph Hoffmann
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
