Question about Sony KV-35S45 35" TV
I do have Sony KV-35S45 TV. I had before problems with blinking light and no vertical picture. Replaced 2SC5148 Hout transistor and it worked fine for 10 weeks. I think after I put back cover it got warm and failed again. I replaced 2SC5148 again but now it clicks and clicks only no standby light or any lights. So now after Power on I hear click and click and click....on T621 relay on G board which is Power supply. What I can check to fix it? Thank you Andrew
  • 11 more comments
  • andrewlacki Mar 25, 2011
    How to locate diode? Is it on main A board where I did replace Q502 H-out? I can see D502, D503, D504 but do not see R2KS/R2KN. What is closest large component to diode? How to check for open resistor at the power supply?
  • andrewlacki Mar 26, 2011
    After I locate diode how do I check ou if it is good? Can I take it out of circuit and check with ohms meter? If one way about 10Ohms ??? and the other way 100K ??? then it is OK? If both ways about 10Ohms then it is no good. What is the part number for me to order? Do I order from sony or you know better Websites? Thank you. Andrew
    How to locate diode? What is label on the main A board where I did replace Q502 H-out? I can see labels D502, D503, D504 but do not see R2KS/R2KN. What is closest large component to diode on main board A? Is R2KS part number to order diode or label on printed circuit main board A?. Does it mean that there is second diode R2KN which I also have to check located at Power Supply board G which has fuse? I can see labels D645, D648 but do not see R2KS/R2KN. What is closest large component to diode on Power Supply board G? How many diodes I need to check? How to check for open resistor at the power supply? Which resistors to check R615 R612.....?
  • andrewlacki Mar 27, 2011
    Let me follow up with you. Are you capable of solving the problem? Are you able to locate diode? Are you reseaching the problem? Last time I have heard from you was one day ago. I expect within next 3 hours to respond to me if you need more time. Thank you. Andrew.
    Main board A is AA-2D 98. Power Supply board G is A 1316-399A. Why it is burning my Q502 H OUT 2SC5148 transistor? What I need to check to fix current symptom to constantly clicking T621 relay located at Power Supply board G? When I disconnect power, unplug connector going between Power Supply and Main board A then power on - relay stops clicking. I think something is wrong on main borad causing clicking. Please let me know what to check to pinpoint it to the bad component.
    Thank you. Andrew.
  • andrewlacki Mar 29, 2011
    I did look at capacitors and they look OK. When I have connected only Power Supply board then I relay is not clicking. As soon as I connect main board A as a load to Power Supply then it clicks and clicks. How to find out what is the root cause for clicking?
    Does it mean that I need to measure diode in the circuit and if have 10Ohms both ways then take it out of the cicuit and measure again. If then has 10Ohms both ways then it is no good.
    How to locate which diode to check?
    I have schematics for my model. On main board A there is IC001 Tunning MCON which has line labeled Relay. What is triggering that line? Is some voltage missing? Is it something else? When does it go to protect mode?
    How to find out what is the root cause for relay clicking? How to find out which diode to check? How to schematics with voltage pictures at specified testing points?
  • andrewlacki Mar 30, 2011
    How to find out what is the root cause for relay clicking? I have schematics and oscilloscope. Do you know about description of Power Supply on the Web which I can use to troubleshoot the problem?
  • andrewlacki Mar 31, 2011
    I have PIN 1 changing from about +2.1V to -1.8V, Same for Pin 5 and 7. Pin 10 is changing from +6.0 to +2.0V. It looks to me like I am missing 9V on Pin 5. What you think is the next step?
  • andrewlacki Apr 08, 2011
    Let me follow up with you. When I was checking output voltage of pin #1, pin#5, pin#7 and pin#10 of CN641 connectors(G-board) I did shorted two pins. This has blown fuse 6.3 Amp.I think that may be has damaged an additional component. Taking all into consideration I decided to stop trying to fix TV and buy new one instead. I do appreciate you plan and step by step professional instructions. As soon as you reply back to me I will close the problem giving you full credit for it. Thank you. Andrew.
    Technician was very professional. Thank you.
  • Sony Master
  • 2,098 Answers
Hi Andrew,
Check output voltage of pin #1, pin#5, pin#7 and pin#10 of CN641 connectors(G-board). These are DC voltages.
Let me know the reading to assist you further
Jdvillanueva
Posted on Mar 30, 2011
  • Jdvillanueva
    Jdvillanueva Apr 01, 2011
    You have an abnormal voltages reading in that board. Pull-out this G-board and make first some re-soldering to isolate bad solder joints from fault. Look for crack/dried/cold solder in that board, this is hard to spot, I would advice you to work in the brightest area or used table/portable lamp and magnifying glass. After that test again the pin-out voltages, if nothing changed, check the voltage across the largest cap C607(250v/560uf).
    - Stay the black test prod of you meter to ground of this cap then jump the red test prod to pin#2 of chopper transformer T605.
    - Set you meter to AC, check the AC voltages in pin# 10 and pin#11 (black test prod to pin#10 and red test prod to pin#11 or vise versa.
    Let me know the reading to determine the next steps.
    Note : ensure safety precaution while in testing of voltages to avoid electric shocked or further damaged.
    If you can send me the closer picture of the board (Top view and on the conductor side which I can read the labeled parts) much better.
  • Jdvillanueva
    Jdvillanueva Apr 08, 2011
    Hmmm, this how difficult working in the power supply section, a little mistake will result to additional damaged. Safety precaution is a must, however we will learn to our mistakes and that cenario also happened to me when I was starting in electronics troubleshooting. This is the real world of electronics...
    Good luck bro, and have a nice day!
  • 1,591 Answers
You're most likely right about it being the power supply section.
]The thing I am seeing most these days is failing electrolytic capacitors.
Look for any that are even a little bulged on top or worse, bulged and or leaking on the top or bottom.
This may be what took out your transistor before, or the failing transistor may have damaged one of the capacitors.
The caps I see going most nowadays are rated 10V 1000uF or 3300uF, but it hasn't been limited to these exclusively.
Give a check to the inverter boards too though, in case the power supply is going into protect (the click you hear) as soon as it tries to turn on the backlights.
Don't forget to check to be sure all the cables are well connected when reassembling the unit!
Posted on Mar 27, 2011
  • 2 more comments
  • Norman Skinner
    Norman Skinner Mar 29, 2011
    If resistance both ways is 10 ohms, take the diode out of the circuit and re-test it.
    If a transistor is firing a coil, the transistor will have the coil's resistance across the emitter and collector (plus any resistance from series resistors)....you have to take a component that LOOKS bad out of the circuit to properly test it!
  • Norman Skinner
    A diode out of circuit should have much more resistance in one direction than the other.
  • Norman Skinner
    if you're going to diagnose over the net you should have a schematic, and i don't have one for your unit, and youj don't have one, so I am done here.
  • Norman Skinner
    Norman Skinner Mar 30, 2011
    At some point you have to determine if you can diagnose to a component level. If you can't, then replace the bad board completely. I can guide you to the solution but I can't completely teach you electronics in the process. It took me years to learn electronics, and I just cannot teach someone electronics in one chat session. Stop looking for components and replace the board.
    President:
  • 1,961 Answers
Check the zener diode on the horizontal section this diode is a circuit protector it became shorted once an over voltage occur it is labeled R2KS/R2KN replace it with a new one...check also for an open resistor at the power supply section good luck let me know..
Posted on Mar 25, 2011
  • Danilo Baraquiel
    Danilo Baraquiel Mar 26, 2011
    hold on sir! I'll be preparing a visual reference so you could easily find the diode in your circuit diagram.
  • Danilo Baraquiel
    zener diode is located at the main board just within the high voltage section at the Horizontal output area and on the power supply board.Zener diode is a voltage limiter diode it is measured with a multimeter set your multimeter into a diode test because a diode has a polarity the reading from the multimeter must not have a reverse reading.when you measure it in forward bias the meter must have a reading and for reverse bias the meter must read 0000 no reading the diode is good.here is a link for a diode tutorial
    r2ks diode application circuit...
Power outage at the house when power returned tv will come on but no picture. Blinking light on front panel. What should i do?
Unplug the set for 30 minutes to see if the processor will reset,if it works great, now if there is no change you will need a tv technician to troubleshoot the problem with an estimate.
Dec 30, 2010 | Sony KV-35S45 35" TV
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
TV Sony is working for 3 min., after screen is
Get a check of your picture tube. It may have been destroyed. If yes get it replaced. P.S: Older picture tubes are of great quality compared to new ones.
Apr 21, 2010 | Sony KV-35S45 35" TV
Kv-32fs16, no picture or sound , red lights flash 4 times
Hi
In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
It is often caused by a faulty vertical output i.c and/or related components. If you feel handy with a soldering iron let me know and i`ll help you with it.
Hope this help Merry Christmas
Dec 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How to connect laptop to sony kv-35s45
when connected to the tv, change the laptop resolution settings until you get one that is satisfactory.
Aug 23, 2017 | Sony KV-35S45 35" TV
Tv wont turn on -- stand by light just keeps blinking
This is very common problem for sony. Blinking light is power supply problem need to replace two voltage reulators in supply and caps and sometime horz output.
Sometimes if you adjust screen voltage adustment on flyback just slightly it will fix it.
cost if ps is 225.00
screen is 95.00
Thanks doctor video
May 17, 2008 | Sony KV-35S45 35" TV
No Power on Sony TV
Be sure to use an ORIGINAL Sony transistor and be sure to resolder the pins of the small horizontal driver transformer and all parts connected to and around it, and your set should be fine.
Aug 17, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
No picture, sound works on Sony TV
Hello, maybe there is a contact error in power supply or the deflection stage. If the resoldering does not help- here are some possible solutions: remedy Replace flyback location LP04. Entered for KV32S22 /SONY (Chassis) remedy 2 Replace IC351, Q602, Q601 (2SC4834M), R607 (1R/0.5W), R622 (10R), IC641 (SI3090CA) and Q502 (2SC5148). remedy 3 Replace tuner. remedy 4 Replace R607, Q502 and IC601. Entered for KV32S22 /SONY (Chassis) remedy 5 Replace regulator IC, R607, check C609, C610 (0.68pF) and C613 (0.0022pF/500V). remedy 6 Replace horizontal output transistor (2SC5148), IC601 (MX0841) and R607 (0.1R). remedy 7 Replace IC1701 and IC601. remedy 8 Replace Q501 (2SC5148), R607 and resolder horizontal driver transformer. remedy 9 Check and replace horizontal output transistor Q502 (2SC5148) and IC601 (MXD8411AB-F). remedy 10 Replace shorted R607. Also check T501 and Q501 for dry joints. remedy 11 Replace C608. remedy 12 Replace Q602 and D648. remedy 13 Replace Q502, Q601, Q602 and R602. Entered for KV32S22 /SONY (Chassis) remedy 14 Replace D626 (6.2V). remedy 15 Replace IC801 and R607. remedy 16 Replace horizontal output transistor and the associated damping capacitor. Check flyback transformer and SMD microprocessor as well. remedy 17 Replace R639 (4.7R/0.250W) located on G board in standby power circuit. remedy 18 Replace D600. remedy 19 Replace C502 (0.47uF/50V). remedy 20 Check D655(1N4937), D657 (1S1834) and Q601 (2SC4423). remedy 21 Check D606 for leakage. remedy 22 Check yoke between vertical and horizontal windings for S/C. remedy 23 Replace Q601 (2SC4834MNP), R607 (0.1R) and C517 (2.2uF/250V). remedy 24 Replace R611.
Apr 22, 2007 | Sony KV-27V22 TV
Sony KV 35S45 Status light blinks, but no picture.
I think the set is worth repairing,it appear it has a loose conection and a few other, as well as overheated areas witch will need to be resoldered to prevent any other problems,if you are familiar with tv service you could check the horizontal drive and output circuits,if you are not too familiar with tv's be safe and call for assiatnce from a servicer.To correcthis problem it should not be too expensive.
Oct 12, 2006 | Sony KV-35S45 35" TV
Sony KV-35S45 35" TV Logo
109 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
