Question about Kitchen Ranges
WHAT ARE THE USES OF AIR CONDITIONER? - Kitchen Ranges
    Problem Solver:
  • 16 Answers
Air conditioning can be used to raise or lower the temperature of an area or room, or to remove excess moisture from the surrounding air, commonly used in damp or badly ventilated rooms.
Posted on Mar 25, 2011
Air condisoner stop working on Toyota corolla89years
It may have leaked out all its Freon gas. If it uses Freon it will not be able to be re-gassed as Freon puts a hole in the ozone layer of the atmosphere. It is expensive to get an air-conditioner re gassed if it uses ozone destroying gas as the new gas is different and the air conditioner needs to be modified to run the newer gas if the Corolla is a older model. Could be compressor has gone faulty. but to replace it will mean it will have to be re-gassed.
Jul 14, 2015 | Toyota Cars & Trucks
2004 Chrysler Voyager, had an acrid burning smell and a lot of smoke when heater is turned on, also a rattling/squealing noise, all stops when heater turned off?
you more than likely have a sciezed air con compressor. most modern cars have climate control which uses air con even when demisting and when engaged the electric clutch tries to engage but the pump itself will not turn, clutch will get red hot and burn your belts
Nov 25, 2013 | 2004 Chrysler Voyager
Where is the drain hole on my frederich quietmaster wall air conditioner?
Hello, if there is no drain hole under the unit then it uses the fan blade to sling water on the condenser to evaporate the condensate. Some window units are made this way instaed of using a drain hole.
Jul 12, 2011 | Friedrich QuietMaster KM24L30 Wall/Window...
Does LG M8003L Air Conditioner use freon?
Hello, yes your ac uses freon. Usually it will be r-22 or r-134a.
May 29, 2011 | LG M8003L Air Conditioner
AF-S80MX Thru-Wall/Window Air Conditioner: What kind of refrigerant does this unit uses? ...
Most new window units are using R-22 or it's most common alternative R-410A - but you will need to check the 'data tag' on the AC to be sure. All AC units have a data tag (either metal or paper label) - somewhere on the AC - which gives you model number, size, voltage, and type of Refrigerant, as well as other info.
good luck!
May 08, 2010 | Sharp AF-S80MX Thru-Wall/Window Air...
Been researching this model, and haven't seen anything about what type of refrigerant it uses. Does it have a compressor and use refrigerant?
Yes it does have a compressor - I believe this particular unit is a 10000 BTU unit w/compressor and uses R410A refrigerant which is btw a ozone friendly refrigerant.
Apr 29, 2010 | Sharp CV10NH Air Conditioner
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
