Everex IMPACT GC2500  PC Desktop Logo
A
Anonymous Posted on Mar 25, 2011
On my everex impact pc window was updated , while windows was starting and now i receive the following error message when booting up "the computer restarted unexpectedly or encountered error. windows installation cannot proceed. to install windows, click ok to restart the computer, and then restart the installation" i have tried this many times and i end up at the same screen again please help
  • Anonymous Mar 25, 2011
    Was this a windows update or are you trying it upgrade your windows system?
Anonymous
Level 3:
  • Master 961 Answers
  • Posted on Mar 25, 2011
Anonymous
Master
Level 3:
Answers
961
Questions
Helped
273372
Points
3003
If I undrestand this correctly, this was a windows update? In some caese after a windows update, a restart is required and during shutdown and restart it configures that update. If the computer is shut down, "unexpectedly" or shut down before update is finished, then the update won't complete. If this is what happened, shut down computer by pressing power button on front of tower. Start system back up using on/off button. When screen comes up with options to start mormally or..., arrow up to "start in safe mode". Wait a couple of minutes and a window will come up "what is safe mode". Scroll down in that window until you see "what is safe mode", highlighted in different color, and click on that. It will take a couple of minutes, and another window will come up where you can scroll down to "start safe mode", click on this. This will take a couple of minutes and a window will come up with a suggested restart time and you will see a box "next". Click on the box. You should see the update in the list of things that come up. Click on the process just prior to the update and click "start or next". This will take a little time and will restart your system. When it comes up, let it think until you see a message "system restore complete", click on ok. Now you can click on start, find control panel and click on to open. In your list find "windows udate". Right click on and open. At the top left of screen you will see "check for updates" and click on that. It should recommend the update you just removed. If it it "important" check box, and install. Restart when update is finished and give it the time to do it's configurations.
If I misunderstood your problem you can let me know at "add a comment" or try reposting. Make sure you clarify between a "windows update" or a "windows upgrade".
1helpful
How to do a factory reset on my Everex impact GC3500
You'll need to reinstall windows, look for an install disk that may have come with your computer, or look for a message when your computer starts up that says something like "Press x to show startup options", and select recovery.
3answers
I can't install windows 8 for my laptop (SONY vaio PVCEB42FM/BJ)
Installing within Windows might overwrite 7. Depends on what version of 8 you have. You could try from boot up and choose / create a new partition, but it may require you to configure boot loader in order to dual boot.
The Computer says "Window Starting.."
if you have now your OS installer, try to repair it using that. don't choose boot regularly
2answers
Hello, My name is Polly and I'm having technical issure with my Everex laptop computer. When I start it up and before I'm prompted to log into Windows. I'm getting an error message noting that I'm missing...
Follow these steps to restore your system files-
1. Shut down the computer.
2. Turn the computer on and immediately press F8 repeatedly until you get the "Advanced Boot Options" menu.
3. use the down arrow to select "Safe Mode" and press enter.
4. Window is should start with a "Help" window.
5. In the help window there is an underlined "What is System Restore?"
Click on that and "Click to open System Restore"
6. click on that and a new window comes up recommending restoring to a previous state.
7. Click ok and the operating system should restore your computer successfully and reboot into normal mode.
//javaftper
3helpful
2answers
OPERATING SYSTEM NOT FOUND
On my Windows 7 laptop, I have got "Operating System not found" error, to fix problem, Windows Boot Genius helped me finally!
I lost all my windows from my Everex Cyberlink DVD Solution.How can I reinstal a OS without cd? Can I use another computer to download the cd or usb? Then use it on my PC desktop
You sholud make a bootable cd or usb so that your pc starts booting with next boot and install the windows Yes u can do it but the cd or the usb device must be bootable
thanks
1helpful
Misssing partmgr file how can I load this thanks
To resolve this issue, start the computer from the Windows XP CD, start the Recovery Console, and then use the Bootcfg.exe tool to rebuild the Boot.ini file. To do this, follow these steps:
  1. Configure the computer to start from the CD-ROM or DVD-ROM drive. For information about how to do this, see your computer documentation, or contact your computer manufacturer.
  2. Insert the Windows XP CD-ROM into your CD-ROM or DVD-ROM drive, and then restart your computer.
  3. When you receive the "Press any key to boot from CD" message, press a key to start your computer from the Windows XP CD-ROM.
  4. When you receive the "Welcome to Setup" message, press R to start the Recovery Console.
  5. If you have a dual-boot or multiple-boot computer, select the installation that you have to use from the Recovery Console.
  6. When you are prompted, type the administrator password, and then press ENTER.
  7. At the command prompt, type bootcfg /list, and then press ENTER. The entries in your current Boot.ini file appear on the screen.
  8. At the command prompt, type bootcfg /rebuild, and then press ENTER. This command scans the hard disks of the computer for Windows XP, Microsoft Windows 2000, or Microsoft Windows NT installations, and then displays the results. Follow the instructions that appear on the screen to add the Windows installations to the Boot.ini file. For example, follow these steps to add a Windows XP installation to the Boot.ini file:
    1. When you receive a message that is similar to the following message, press Y: Total Identified Windows Installs: 1
      [1] C:\Windows
      Add installation to boot list? (Yes/No/All)
    2. You receive a message that is similar to the following message: Enter Load Identifier This is the name of the operating system. When you receive this message, type the name of your operating system, and then press ENTER. This is either Microsoft Windows XP Professional or Microsoft Windows XP Home Edition.
    3. You receive a message that is similar to the following: Enter OS Load options When you receive this message, type /fastdetect, and then press ENTER.
      Note The instructions that appear on your screen may be different, depending on the configuration of your computer.
  9. Type exit, and then press ENTER to quit Recovery Console. Your computer restarts, and the updated boot list appears when you receive the "Please select the operating system to start" message.
Missing boot.ini cant find it and missing logon.exe
      [1] C:\Windows
Top Everex Computers & Internet Experts
k24674
Jose Ramirez
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
