My usb turns 0 bytes i guess it is because of a certain virus. i cannot format it.
  • 125 Answers
Right click on my computer ->select computer manage\manage ->select disk management ->
choose the drive of your pendrive-> right click on it ->click yes read msg cilckok thats it.
Posted on Mar 25, 2011
Transcend jet flash v33
Hi Virus or Trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert the pen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
Mar 30, 2014 | Electronics - Others
My (Transcend)pen drive showing free space 0 byte and used space 0 byte .
jmy (Transcend)pen drive showing free space 0 byte and used space 0 byte
Nov 26, 2010 | Transcend (589307) Media
256mb & 512mb Trek usb thumb drive can't be formatted
As all your pen drive are getting affected by auto.inf virus your PC contains that virus.
Please scan your PC with proper anti virus and clear all your drives in PC.Then insert the pen drive and scan and remove that virus.
The intensity of affecting the pen drive depends on the virus.Hi no virus damage the usb physically.
Please do the above steps and you wont get it again.
Thanx
Jul 24, 2010 | Computers & Internet
My one week old usb today said used capacity 0 bytesfree 0 bytesfile system raw.cannot be formated.it says insert flash drive. This happened the last new usb device I bought three weeks ago. Is this a...
This is probably a problem of system files on the USB key.
First of all, read the manual for the key, and verify that no utility provided with the key to reset or reformat. If such a utility is present, it is recommended that you used same before proceed to next step.
Otherwise, to reformat and therefore repair the USB key, you can use standard tools of Windows. Insert the key into the USB port of a PC, then go to:
Start / Control Panel / Administrative Tools / Computer Management / Storage / Disk Management /
Select the drive to the USB key in but ensure same is not a hard disk system!
Once the back up of your USB key effected, delete the existing partitions on the key (right click / delete the partition.). Format the key to FAT16 using all the available space (right-click / Format). For more than 2GB, it is recommended that you format same as FAT32.
If the available space is under the capacity of the key, this is surely a hardware problem, in which case it may be necessary to reduce the after-sales service.
It should be noted however that a difference of about 10% should not be considered, prior the way the manufacturer has recorded bytes. To be more appropriate, as a manufacturer considers that a Megabyte equals 1 million bytes or 1024 * 1024 bytes, a key of 512 MB can display 512 000 000 bytes or 488 481 250 bytes.
May 14, 2010 | PNY USB SmartMedia Reader PC (SFRUSBWB)
My one week old usb today said used capacity 0 bytes,free 0 bytes,FILE SYSTEM raw.Cannot be formated.it says insert flash drive. This happened the last new USB device I bought three weeks ago. Is this a...
Format with this tool.
http://en.kioskea.net/telecharger/download-127-hp-usb-disk-storage-format-tool
NB use server 2 for download. Server1 requires password.
Mar 24, 2010 | PNY USB SmartMedia Reader PC (SFRUSBWB)
On opening a pen drive it is showing 'please insert a disk into removable disk (h:)' and opening its properties it is showing used space 0 bytes free space 0 bytes
Hello there yogeshpat876.
Here's your geek-steer ...
Is this a new drive? If so, it probably just needs to be formatted [and optionally assigned to whatever free drive (letter) you desire]:
Start > Run... > tpye "diskmgmt.msc" (without quotes), then OK
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 13, 2009 | Transcend (589307) Media
External smartdisk firelite
It seems that you will lose your files. These file already
infected with virus, and corrupted it. There's no other
way but to reformat your smartdisk.
Oct 08, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Pen drive is showing o bytes
I would first put it through a fast formatte then a standard formatte, then i would recommend asector scan and see if there are any sectors that are not recoverable, if they are messed up and or still not solved try to uninstall the file that has stored the recognition files for the pen drive remove the main file in c drive program files , find the file by name corresponding to what it is you have and delet it then do a full shutdown and after a full cold start reboot install pen and software when asked if you still experience this post the results and i will try to help in a higher level of tech knowledge and support
May 31, 2009 | Transcend (589307) Media
1GB MicroSD card detecetd by computer as 0 memory device
Please format it. It needs to be formatted to read them.
Jan 12, 2009 | SanDisk 1GB microSD Memory Card
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
