Question about KitchenAid Washing Machines
On the inside of my washer there is a bunch of wax on the top ring in the drum. Is it meant to be there? We just bought them used.
    Master:
    Sergeant:
  • 385 Answers
I don't believe that is wax. It probably is a combination of soap and fabic softner.Try wiping it off with hot water.
Posted on Mar 25, 2011
How to Replace rubber seal on front load washer
The rubber seal on your washer and similar front loading washers is a relatively easy repair. The seal is held onto the front washer panel and the fixed inside washer drum with separate spring-loaded rings that are reusable. So, don't throw them away! You need to remove the front ring from the front panel before you can remove the front panel. With the ring removed the gasket should be pushed into the washer; noting any drain holes, so that you can reinstall the new gasket in the same orientation. Once the outer ring is removed and the front panel is out of the way, you will have access to the ring holding the gasket to the drum. After the inside ring is removed, the gasket should pull off the fixed washer drum. You are now ready to install the new replacement gasket.
The amount of disassembly of the front of the washer is your option if it interferes with the installation. The door is usually heavy and it is useful to remove it from the front panel. Usually, a couple screws holds it in place. Removal of the front panel may also involve removal of the top of the washer and moving the control panel out of the way so that you can access the screws holding the front panel onto the frame of the washer. The locking latch may have to be temporarily removed but can be left in place if you simply push the front panel out of the way to have access to the inside gasket ring. It is useful to take pictures of each stage of the disassembly process to make sure your reinstall everything as it was.
Installation of the gasket starts with reattaching it to the fixed washer drum flange and then replacing the spring-loaded ring to hold it in place. Make sure the gasket orientation matches the original position. After the gasket is attached to the drum, you can now reinstall the front panel. If you unscrewed the latch mechanism when you took off the panel, now is the time to reinstall it as it can be manually held in place behind the gasket. The door can usually remain off the front panel until installation of the gasket onto the front panel is complete. Now bring the gasket forward and reinstall it on the flange of the front panel; secure it in place with the spring-loaded ring. Your gasket is now reinstalled. Simply reinstall the door and your repair is complete.
Tools needed include a blade screwdriver to help pry the rings off the gasket seal and one or two specialty screwdrivers (usually Torx or Philips) to remove the front panel.
Aug 05, 2014 | Frigidaire Washing Machines
Tip
If you are experiencing greasy marks on your cloths, let me ask a question. Are...
90% of greasy marks on cloths is due to scum build in the outer bowl of your machine...top loaders being the most vulnerable. prevention is better than cure. At least one hot wash a week on high level. If your machine is an early model one or two with a good bleach subject to manufacturers instruction...bleach is very cost effective and works well.
on Apr 10, 2008 | Bosch WFMC 3200 Front Load Washer
Have a DDL-555 bought used. The thread bunches up on bottom.
thread loops on the bottom is a sign that it isn't threaded correctly or the tension isn't set right.
Industrial machines tend to do some strange threading procedures. Are you sure you have it threaded correctly? Two of the machines I've had required that I do a 360 around one of the tension discs. I would start there.
Also some industrial sewing thread is waxed and that wax can cause you issues in between the tension discs. Raise the presser foot and take a piece of sturdy material like canvas or denim and "floss" between those discs. It will help remove wax build up that could be keeping your tension discs from working properly.
Nov 25, 2012 | Sewing Machines
I wont to replace the sealant from around the tiolet waste pipe, what is the best way of doing this?
turn water supply off to toilet and disconnect water line from bottom of toilet tank. flush toilet to drain tank, use towel to soak up water inside that didnt flush.remove the 2 bolts ( 1 on each side of toilet), lift toilet up and move to one side and lay on it side, scrape off old wax ring from bottom of toilet, scrape off excess wax from pipe on floor. install new wax ring over drain pipe. stand toilet upright and lift straight up over drain hole and reset slowly to make sure each bolt goes through the holes on toilet, replace nuts and washers on toilet and tighten. hook water supply liune back up and turn on water.
Aug 30, 2011 | Home
Neptune Washing Machine (MLE200AWW) spins but water is not pumped all the way out. I can hear it slosh in the drum if I spin the drum manually.
Hi, the sloshing sound is normal because of the balance ring which has liquid in it...
I would be concerned about your door latch wax motor ( part # 12002535) though... See Neptune Help for more information about replacing the faulty wax motor with brown colored actuator tip before it damages your machine control board. When the wax motor shorts out it will blow the Q6 triac and then the R11 resistor will burn and your door probably won't lock anymore as indicated by the door locked light not coming on. The next thing you will notice is that your clothes will be soaking wet after the wash cycle because the spin cycle will not work if the door does not lock...
Your machine control board is located above the dryer on the right side.
Every Maytag Neptune front loader with a timer knob (non digital) has a wax motor and all of them shipped with faulty one except the later 2000 series stacker models. You should proactively replace the wax motor with the new design (with black tip) to prevent the Q6 R11 failure on the control board. If you're too late you can try the STAGE 1 repair kit at the same site above.
To inspect your door latch wax motor on the stackers you:
? Unplug machine
? Remove the (2) screws holding center panel and remove panel
? Remove the (1) center screw holding the top panel located inside compartment above washer
? Remove the top panel to expose the door latch assembly
I hope this helps you.
Apr 25, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
My Maytag Neptune Washer Model MAH3000AWW, Serial 35269627WB drains the visible water that can be seen inside the drum, but then does not drain the rest of the water that remains between the drum and its...
Hello, The earlier Maytag Neptune front loaders have a balance ring on the inner tub that has liquid in it and that causes the sloshing sound when you turn the tub by hand. That is normal.
I noticed that you have a MAH3000... Have you replaced your door latch wax motor yet? If not, it will fail and damage your control board located behind the timer. See NeptuneHelpSong for a video that explains the failure.
I hope this helps...
Apr 25, 2011 | Maytag Neptune Washer
Tiled bathroom floor. Went to install toilet
hi, the tile is supposed to go under the toilet flange (the thing you put the wax ring on), very common "oops", can be rectified by placing another wax ring right on top of the first on. best to make the first one a "horn type" wax ring, then put the plain one (no horn) on top of first and try to smoosh it on just enough to stay in place so when you install toilet it doesn't move,.....cheers!
Jan 31, 2010 | Kohler Cimarron 2-PC Elongated Toilet with...
What is the proper way to stack wax rings? I hear
You place the plastic sleeve down toward the drain. If that does not seal due to the floor being higher than the drain mount simply add another wax ring minus the plastic sleeve. You can buy wax rings that do not have the plastic sleeve. In lots of cases you have to use 2 wax rings to get a good seal. Make sure you securely tighten the toilet down.
Dec 31, 2009 | Jacuzzi BK37959 White Era?? Two-Piece...
Frigidaire Affinity Washer beeps & won't spin
The drain filter is clogged. I had the same problem. There is a filter inside the "drain boot" (black) that comes from the drum to the drain pump. Mine was completely clogged with money, lint, etc..
Sep 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
LEAKS AND SQUEAKS
If you suspect the leak is from the main drum seal.
To remove the agitator, remove the softener cap by pulling, look inside the agitator, undo the bolt (4) with long socket extension and then lift out.
5e90500.jpg Not sure if you can see the seal ("O" ring at this point, you may need to remove the inner drum.
Isolate the supply.
Lift the top cover by inserting a flat blade approx 4" in at each side at the front to release the two top clips, top cover will lift and hinge backwards out of the way.
To remove the top ring (13) from the drum, unclip each clip around the top untill released, then remove.
to remove the inner drum (10) , unbolt (7) from the inside, lift out inner drum.
Seal (1) should be visible.
Mar 24, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
18 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Eric Taylor
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
