Question about Onkyo TX-DS474 Receiver
I can't figure out what output to hook my Mirage nanoset 5.1 sub woofer up to.
    Problem Solver:
  • 11 Answers
There should be a purple colored RCA jack on the unit's rear.
This is the output to the sub.
Link to owner's manual:
http://www.us.onkyo.com/download/own_manuals.cfm?cat=Receiver
Posted on Mar 25, 2011
Trying to hook up a KLH sub woofer, S100ETH, PSW8-100 to a VCR reciever. Reciever has sub woofer connection but does not works on the KLH sub woofer. What is the problem ?
I suggest you go over your receiver set-up instructions. See if you need to set the receiver to acknolwedge the addition of the subwoofer. It should be in your receiver set-up steps. Just as a check, hook up one of your other speakers to the subwoofer lead to see if gets audio signal. I'm guessing the issue is your receiver settings.
Jan 06, 2015 | KLH Audio Players & Recorders
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
How to hook up emerson subwoofer sw 03
For powered sub :If your receiver has a sub woofer output on female RCA plug, that is the way to go. If no output you will have to get a speaker line to line output converter to then connect to your subwoofer amp input.
Unpowered sub - just hook up across the speaker terminals for each channel making sure that you hook it up in phase.
Mar 14, 2014 | Audio Players & Recorders
I have a subwoofer can i hook up to computer speakers
Yes you can. cut the left speaker lead and splice a wire from it to your sub woofer. If its a powered woofer you may have too much gain going in, You don't say what kind of sub it is or weather or not its a "powered" unit. If its a powered woofer (built in amp) you should take the output directly from the computer output (buy a 1/8 in male to 2 1/8 in female connector, send one output to your original speakers and the left side of the second output to the sub woofer. you can usually adjust the level of the sub (if powered) with a control on the unit. if you need more help, contact me but please tell me more about what you have.
Mar 18, 2011 | Altec Lansing Multimedia Computer Speakers
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
Cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Mar 09, 2010 | Cerwin Vega Audio Players & Recorders
Mirage LF 150 Sub Woofer. sub not working
within the sub amplifier is an electronic amplifier, that is shorted and blown a fuse. This is all internal. If you can dismantle this module, I suggest do so and any electrical/electronic individual will identify the part needed. you could also check on a replacement module-complete.
Mar 04, 2010 | Mirage LF150 Subwoofer
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Sub
Most amplified sub woofers need to be grounded to the output source.If you plug the sub woofer in to the receiver you would use a ground wire from the receiver to the sub woofer there should be a ground terminal on the sub woofer and receiver.
Feb 17, 2008 | JVC RX-778V
Onkyo TX-DS474 Receiver Logo
69 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
