Thank you for posting to Fixya.com and it is my pleasure to guide you.
I have located the manual, click or copy paste to download the manual for future reference.
Getting Started Guide 9.11M http://h10032.www1.hp.com/ctg/Manual/c00230513.pdf
From the manual : Power - Troubleshooting page 101
QUOTE
Symptom: PC will not turn on or start.
Problem: PC is not securely connecte
Solution: Ensure that cables connecting the PC to the external power source are plugged in properly.
Problem: Green power supply light on back of PC is out.
Solution: When the cables connecting the PC to the external power source are plugged in properly and the wall outlet is functioning, the green power supply light should be on; if the light is not on, refer to the Warranty and Support Guide to contact Support.
Problem: Monitor is not connected or is not on.
Solution: Connect the monitor to the PC, plug it in, and turn it on.
Problem: Line voltage selection switch is not in the proper position for your country/region (115V/230V).
Solution: Set the line voltage selection switch to the correct setting for your country/region, or refer to the Warranty and Support Guide to contact Support.
Problem: Wall outlet is defective.
Solution: Test the outlet by connecting a different electrical device to the outlet.
Problem: Wrong memory modules were used in an upgrade, or memory modules were installed in the wrong location.
Solution: Reinstall the old memory to return your PC to its original state. Refer to the Upgrading and Servicing Guide for instructions.
Problem: Hard disk drive is damaged.
Solution: Press the Help ? button on the keyboard to open the Help and Support Center, or refer to the Warranty and Support Guide to contact Support for replacement details.
Problem: After an upgrade or repair, the drive power, data, or power supply cables may not be properly connected.
Solution: Reseat drive power, data, and power supply cables. See the Upgrading and Servicing Guide for instructions.
UNQUOTE
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
