Question about Poulan 14" Chainsaw
I was wondering how many watts the chainsaw would run off if it runs on 120 amps. i would like to use it out in the field but need to have the right amps.
    President:
  • 1,489 Answers
I think you mean 120 volts.
Use a heavy guage extension cord and plug it into a GFCI if you have one outside your house. If no GFCI installed on house, buy a portable one at a hardware store.
The amp draw is on the nameplate on the saw. If it reads 10 amps, for example, you'll need a 16 guage extension cord. If it pulls more than 10 amps, you should use a 14 guage extension cord.
More info, let me know.
Charlie
Posted on Mar 25, 2011
How do you stop generator from stalling under load
As you have not provided me with the information I requested I'm going to have to take a few guesses here Bob. You could be overloading the generator. You can't run a 10,000 BTU air conditioner off of a 1000 watt generator. You need to look at your load, (what you are trying to power), and determine how much power it needs. Almost everything has a tag somewhere on the device. Most don't give watt requirements. But they do tell you, how many amps the device pulls, as well as the voltage the device needs. So you need to do some math here. Volts X Amps = Watts. So if we have a 120 volt device, that pulls 15 amps, we need 1800 watts to power it. But it gets a little more tricky than that. Motors are often rated at what they pull while they are running! But it can take two or three times more power to get them started. Example... A motor rated at 10 amps, using 120 volts will be 120 X 10 = 1200 watts. But it could take 2400-3600 watts to get it running. So in theory a 3000 watt generator may die before it can start that load. Heating elements are also power hungry! Let's say you have a small 800 watt generator, and your just trying to run a simple coffee pot! Well the heating element in a typical coffee pot pulls 1000-1500 watts. A hair dryer or microwave oven rated at 1000 watts, is the power they produce, not the power they consume! So a 1000 watt microwave may pull 1600 watts of power to run. Most non US generators are highly over rated as well. I certainly would not trust a Harbor Freight 3000 watt generator to actually put out 3000 watts of power. Not that they are bad units, I would expect their numbers to be under PERFECT conditions. Temperature, humidity and altitude also play a part! Your 3000 watt generator is going to put out more power at 50 degrees, at sea level, than it is at 7000 ft in the mountains at 100 degrees. So my "guess" Bob, is that your just asking more from the generator than it can produce. Picking out a generator is not as easy as it looks. "Hey that one is $1000 and this one is $300! They both make power! What's the difference". The difference is what do you need to run! "Heck I'll just get that 50,000 watt unit"! Yeah you can do that too, but you will never use that much power, and you will burn way more fuel than you need to. My other "guess" is that you have a governor issue on the engine. As load increases the gov will throw more throttle to the motor. My generator has an option to run full speed or on the gov. So it will idle and burn less fuel while I am hammering in a nail, then go to full power when I trigger a saw connected to it. Lot's of factors involved here Bob.
May 30, 2014 | Generac Electrical Supplies
Tip
What size of inverter do I need?
The correct size of inverter is an easy calculation and important to ensure long life from the inverter and the life of the appliances getting there power from the inverter. To calculate you take the volts and multiply by the amps which equals the wattage. Every appliance has a tag which must state the volts and amps. Locate the tag to find the information. Here is an example.
Under Counter Refrigerator 1.3 amps (120 volts x 1.3 amps = 156 watts)
Microwave (120 volts x 10 amps = 1200 watts)
Alarm Clock Radio (120 volts x .03 amps = 3.6watts)
TV (120 volts x .6 amps = 72 watts)
You now add all the watts together, since the above list could likely be running at the same time. There is a combine wattage of 1431.6 watts. In this example you would need at least a 1500 watt inverter. However given some unknown variables personally I would get a 2500 watt inverter. Less stress on the inverter, will lengthen the life of the inverter. Had the total been 1,000 watts a 1,500 watt inverter would suffice.
You must also remember that your alternator on your vehicle must be able to keep up with the power demand of not only your vehicle needs but your inverter needs as well.
on Apr 23, 2010 | Electronics - Others
How can you get the amp size for a product when they dont list it for example I have a heater it runs on a 120 v and goes to 1000 to 1500 watts so how do I get the amp size?
One watt is the rate at which work is done when one amp of current flows through one volt of electric potential difference. Thus, to find the amps, divide the watts by the volts. In your example, 1500 watts divided by 120 volts gives 12.5 amps.
Sep 07, 2013 | Office Equipment & Supplies
AC surge current?
you are missing the voltage supply here to get an definitive answer
for 240 volts drawing 4.8 amps the required wattage is 1152
for 120 volts the wattage is 576 watts
for 120 volts with a current of 900 watts , it equates to 7.5 amps
with 240 volts with a current of 1150 watts , it equates to 4.79 amps
so you can see the problem by not stating the supply voltage
get access to an cable clamp amp meter / watt meter from an electrician and read the current on starting the ac unit
if it exceeds 900 watts for 120 volts or 1150 for 240 volts , consider a bigger generator
Aug 31, 2017 | Fixya.com Heating & Cooling
I'm in Europe where the voltage is 220 instead of 110-120. I need a transformer to use the fan but was wondering what wattage is required.
Hi elinorkim...
To find out what wattage transformer to use you must do a little math.
Multiply Amps times Volts = Watts...this is the least amount of watts you want to use, the more the better...higher wattage will make the transformer run cooler and last longer.
Look on the side of your fan for a tag that has this information on it.
Please take time to rate me
Sep 04, 2011 | Holmes Products /FANS HT38R-U Tower...
Just paid over 1,500 last year an has not rungood since. starts up real good, but once aair is turned on it stops running, or it might run one air at times. on my way back to michigan an not a happy...
This generator is a 5KW model. This means it can supply up to 5000 watts of power, total. Not all devices list the watts they need to be provided - instead these devices list the power they need as volts and amps. This can make it hard to determine what the actual watt requirements are for the device.
Overly simplified, watts is equal volts times amps (watts = volts x amps). A single 120 volt light bulb that uses .833 amps consumes 100 watts. If you checked a regular 100 watt light bulb with an ammeter, you'd find it does indeed draw .833 amps.
Working the formula a different way, we can learn how many amps this 5000 watt generator can supply at 120 volts, too. If all the loads you need to connect to this generator are 120 volt types, that means the total amount of amps the generator can supply is 5000 watts / 120 volts = 41 amps purely resistive loads (like a toaster or light bulb) maximum under ideal conditions. There is never a time when ideal actually happens, and not all loads are purely resistive - many are inductive. Inductive loads are motors (like your A/C), fluorescent lamps, computer power supplies, etc. - so figure more like around 30 amps total instead.
If you try to connect devices that require more than 30 - 35 amps, the generator will probably have problems trying to supply this load for any longer that a short length of time. Additionally, motors like those in A/C compressors draw significantly more power when first starting and can cause the problem you are describing. Try running the generator with loads other then the A/C to see how well it can supply the load(s). Or try running only 1 A/C unit and other non-A/C loads.
What I'm trying to tell you is that you may need to do some active load management to be sure that you aren't trying to get more power out of the generator than it is capable of supplying. You may need additional generators or swap this one to a larger size to handle the load properly and safely.
I hope this helps & good luck!
Apr 09, 2011 | Watts Onan Portable Generator - 5000 ,...
I have a trailer house that has a 100 amp breaker box in it. I has gas for heat, water heater and stove. I am changing them to electric. Will I need to change the panel put to a 200 amp.
Its probably not a bad idea. Thats alot for a 100A panel to handle, a range needs a 50A, a water heater needs 30A, and the heat will need a 50A or a 60A breaker... Plus whatever else is in the house will be a bit more than the 100A service can handle. But if you don't have the money it will do for a while because for the most part they won't all be pulling at the same time. Word to the wise get at least a 30 space panel when you upgrade, I always install a 40 space panel because for the cost difference its well worth it for future needs because you'll fill it up quicker than you think and you'll have space for anything else you may want to add later on. Hope I helped
Dec 09, 2010 | Your One Source Homeline Circuit Breaker
Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
Apr 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Conecting to 120 volts AC
If you want to get more precise, figure out everything in terms of power (watts).
Basic electrical rule 1, 2 and 3:
voltage x current = power
or re-arranged:
current = power divided by voltage
or re-arranged:
voltage = power divided by current
For example, 12V X 2 amps = 24 watts.
or another example, 400 watts divided by 120 Volts = 3.33 amps
A 55W headlight that uses 12V would draw 55 /12 = 4.6 amps @ 12V
A 55 watt light bulb in a lamp at home would draw 55 / 120 = 0.46 amps @ 120V
As the previous post mentioned, inverters are not perfect when convertering 12V into 120V. If the converter consumes 1000W from the 12V battery, then a 90% effecient converter would generate 900W of 120V AC power best case. The other 100W is lost primarily as heat.
The other thing that gets tricky is that these ratings and the formula above are used for resistive loads, like light bulbs or hair dryers. Anything with a motor or transformer is considered an inductive load and can get much more tricky to calculate.
Consequently you need to give your self a safety margin when figuring out how big an inverter you need.
How does work in a practical sense?
Lets say you want an inverter for TV, DVD and Sat. Receiver. Look at the back of TV or in the manual. It should say how many watts it consumes. Lets say it is 400W. The DVD might be 100W and the Sat. receiver 50W - just as an example.
400 + 100 + 50 = 550 Watts. (just as an example)
You might think, well no problem, I'll use a 600 Watt inverter and have 50 watts left over. Depending on your inverter, that 600W might really be 600 x 90% effecient = 540 Watts of AC, less a 20% margin of error for the inductive transformers in the electronic of the TV, DVD and Sat. receiver 540 - 20% = 432 Watts.
Now you can see your 600 Watt inverter isn't big enough to do the job.
If we really need 550 watts of AC, add 10% to make up the effiency loss, then add a safety margin for inductive loads.
550 + 10% = 605 + 20% = 726 Watts.
Sounds more like an 800W inverter fits the job.
What does that mean in terms of wiring the 12V batteries to the inverter?
from the formula above:
In our example, we have an 800W inverter that runs on 12V
The current would thererfore be:
current = 800 watts divided by 12V
current = 66 amps.
That is important info because you can not use light gauge wire to carry 66 amps worth of 12V to the inverter nor could you use a 20A fuse to protect your inverter.
Now that's a lot of science for a guy who just wants to run a toaster on an inverter right?
800W / 120V = 6.66 amps
Using garryp's ratio 11:1, 6.66 x 11 = 73 amps.
That is a good ratio with a good safety margin.
This is all just MHO and should not taken as solid technical advise. In other words, don't blame me if you blow yourself up.
Nov 26, 2008 | Coleman 5640B807 Compact Refrigerator
Poulan 14" Chainsaw Logo
89 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
