Question about Refrigerators
Need a new stricker you can't spin the stricker handle fast enough to make a spark
  • 132 Answers
I assume this refrigerator is an absorbtion type of refrigerator, also known as a 3 way fridge ( 12volt, 240 voly and lpg gas.)
The stiker is a piezio crystal which does not wear out. The problem is that the where the spark jumps across the gap has become dirty or blocked in some way.
In general the push button should be easy to push in, if it has become harder to push in that is a sign of dirty "points"
Posted on Mar 25, 2011
What causes the water not to spin out of the clothes?
Hi, it means that the machine is not spinning fast enough and pumping the water away. If its not spinning enough then you have to get the machine looked at as its not clicking on in the cycle for it to spin fast enough. You also have to have it set to wash cycle that has a fast spin. If it is spinning fast then you have to look at the pump to make sure its pumping the water away.
Mar 18, 2016 | Washing Machines
88 rx7 run but wont start
The FC3S is notorious for this and fueling issues. Check all ground points, battery cables and connections. Check the draw from the starter. If the voltage drops below 10V there is not enough power for the ignition, causing weak spark. It really needs to spin over 200rpm cranking. Pop starting does not necessarily mean the compression is good. You need to make sure it cranks fast enough to get a proper compression test with rotary tester, New NGK plugs, new NGK plug wires.
May 28, 2012 | 1988 Mazda RX-7
Kenmore Automatic Washer Model 110.24642300 - problem is that spin cycle is not fast enough to get the water out, so clothing is sopping wet and loose at the bottom of the tub instead of plastered to the...
Your transmission is starting to go bad. It is not creating enough power to spin the clothes fast enough to dry them. It is cheaper to look for a new washer . To fix the transmission will cost you over 400 I would do light loads until your able to get a new washer
Jul 12, 2011 | Washing Machines
Hello, I have honda accord ex, 1995 bottom driver side light kept blingking while am driving. Do you thing "Fuse" thks Jessie
I think your door might be adjust too far out and the door is not push the Door Switch in far enough when it's close. Adjust the door inward a little by loosing the stricker screws and tipping it in with a hammer. See picture below for Door Switch and Stricker.
good luck
Jan 21, 2011 | 1999 Honda Odyssey
Will not spin fast enough on final spin cycle to
ITS POSSABLE ITS NOT PUMPING FAST ENOUGH. CHECK THE DRAIN HOSE AND MAKE SURE IT HAS NO KINK. IF THATS OK IT MAY HAVE A BUILDUP OF SOAP. RUN A EMPTY CYCLE WITH NO SOAP. IF THAT DONT WORK YOU NEED A REPIARMAN TO CLEAN OR REPLACE THE PUMP.
May 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
GE Front load washer spinning too slow????
A couple of things come to mind,if the micro-processor senses the load is out of balance enough, it will control the RPMs(reveloutions per minute) or slow it down in order to avoid damage to the suspension system, so readjusting the spin speed manuallly probably would help. Although that machine should be able to handle 9 large towels easily! Next thing, have you cleaned out the trap inside the lower access panel, if it is restricted you will have draining problems. Good luck !
Jan 07, 2010 | Kenmore 22422 Top Load Washer
Kemore washer
If the machine spins but not fast enough you will need to replace the clutch.
Jan 05, 2009 | Washing Machines
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
