Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
I have a stihl 029 chainsaw and the oil is coming out next to the muffler and not on the blade
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 344 Answers
If the clutch drum was not set on the oil gear spring properly the housing can wear out and leak oil. I recommend removing the clutch and inspect the housing.
See a local dealer like www.arcolawn.com for parts.
Good luck
Posted on Mar 28, 2011
  • dbmvoices Mar 28, 2011
    Thank you for your reply. The oil is coming out to well next to the muffler, A friend told me it was the plastic drive gear! I finally figured it out by looking at another body and noticed the plug is messing and called the dealer and they said I need to put a screw part they have into the hole.
The chain is not being oiled
You may have blockage where it oils,needs cleaning their.
Oct 03, 2016 | Stihl 029 039 Ms 290 310 390 Oil Pump...
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
My stihl chainsaw leaks oil from behind the muffler
there is a small plug that is on the chain side of the saw that is at the bottom corner by the muffler. look and see if that is where it is coming from. if it is then you will have to take it to a Stihl dealer for repair
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 23, 2014 | Stihl Garden
Chain oil leaking on 025 stihl chainsaw
Their is a oil passage that has a plastic plug in it by the muffler. It might be gone like mine is.
Nov 29, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl 029 super oiler is not working
Pull off the clip and sprocket, then check the spring or wire behind the clutch. There is a notch in the sprocket hub that drives the spring when the hub is spinning. Sometimes the spring comes off the worm gear that it drives. If the spring is not there you need to remove the clutch to check it. It has left handed threads on it)
Mar 08, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Hole in oil tank need to replace need help stihl 029
New Stihl parts and IPLs are proprietary. The only source of parts is eBay or Stihl.
Lou
Jan 24, 2010 | Garden
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
240 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
