Question about Humax Televison & Video
Hi My name is Barry Willans and I have a Humax PAU-42THD tv. When I use the remote to change to TV/AV it just keeps moving up and down and I can"t stop it on a channel also the volume control with the remote is the same press volume and it keeps going up and down. Normal channel change is ok as well as switching on the tv. All these operations are ok when done manually on the tv. I have tried three remotes and all do the same thing so the problem seems to be the tv. Hope you can help in this matter Regards Barry Willans
chrispurs1
  • 372 Answers
SOURCE: Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Posted on Jan 20, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
SOURCE: Don't know how to switch from tv to av without remote
tried remote does not want to changetv just stays on enlish spanish french.mode.push enterselect does not work
Posted on Jun 12, 2009
  • 136 Answers
SOURCE: lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
Posted on Aug 08, 2009
SOURCE: Panasonic remote and volume/channel buttons do not work
try unplugging while the TV is still on and plug it back after 5 mins and check. it should work.
Mine did. I know this may be a crude method, but it worked.
Posted on Sep 08, 2009
The humax remote formerly managed all functions with TV now won't turn TV on, when tv on won't change channels, show home, guide any functions, but will change volume.
If you have changed your TV, you'll need to change the TV code in the Humax remote. See the TV code list at the back of the Humax User Guide.
Jun 27, 2015 | Humax Televison & Video
Why can i only get radio stations from our humax freesat and not tv channels
There is a button on the remote labelled 'TV/Radio' which was probably knocked when the remote was dropped.
Sep 15, 2014 | Humax Televison & Video
My youview has taken over my humax channels
Put BT box into standby. This is probably due to the scart connection. Try to connect both boxes via HDMI if possible.
Aug 23, 2014 | Humax Televison & Video
Why is my panasonic viera picture only showing when humax box switched on. Why?
Try the AV/Source button on your TV remote control, might help. Sounds like your source is set to the Humax box channel so you need to change it to the source you want, whether thats TV, DTV, HDMI1 etc... hope this might be it... also check your plugs in the back of the boxes and ensure they are firmly plugged in.
Jul 10, 2014 | Audio Players & Recorders
After switching off and on last night the volume and mute on stopped responding on Humax remote. IT is PVR9150T and remote RT531B. TV Remote works fine with volume. Humax remote works fine on all exce
Note that this type of device is designed to be left on at all times, so should not be switched off each night. I suspect that it has some slight corruption in the user-settings, so a factory reset may be required.
Apr 03, 2014 | Humax Televison & Video
DVD output to TV not displayed
So you have HDMI off of the PVR into the TV and AV off of the DVD Player into the PVR at the moment? Just for info what connectors do you have at the back of the tv, dvd and pvr? In's and out's...
Feb 28, 2014 | Televison & Video
How do i get the tv on av without using the remote?
push channel down button through the channels, then it will go into av mode(video) by just keeping to press channel down. it will be channel below channel 02. just keep pushing channel down button
Nov 21, 2009 | Beko 324250WN 28" TV
How to select av without remote control
try pressing plus and minus channel on the tv at the same time. works with my daughters tv
Nov 16, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Need remote code
Humax codes are,1325,1565,1569 Ted10
Apr 16, 2009 | Humax LD2060 20 in. EDTV-Ready LCD...
Televison & Video Logo
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
