Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Top of fridge not working - Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
  • 132 Answers
The top part of the fridge relies on cold air being forced up from the freezer section. The is a fan in the freezer that forces air into the "ducting" which channels the air to the fridge.
So either the fan is not working
Or the ducting is blocked
Either way you may need a technician to fix this problem
Posted on Mar 25, 2011
Why is there water on top shelf in fridge
I would guess the fridge is not set level. A small amount of water is normally meant to condense and run down the back of the fridge and then evaporate outside the fridge.
If either the fridge is leaning forward slightly or if anything on the top shelf is touching the back of the fridge, then instead of running down the back of the fridge water may instead end up on the top shelf.
Assuming the fridge is still working in every other respect then this is what I would suspect.
Aug 25, 2014 | Max-Fridge Refrigerators
My Hotpoint Fridge/Freezer only works with the freezer at the bottom and the fridge is fed from the freezer via ducting to the fridge at the top ---- can anyone tell me why the freezer works perfectly and...
There has to be something restricting the air flow to the fridge. If the fan is running blowing cold air into the freezer, then it should be cooling the fridge too. Empty out the fridge and freezer and use a blow drier to blow hot air into the duct work. There could be an ice blockage not visible in the duct work.
Aug 15, 2014 | Hotpoint Refrigerators
Kenmore 795 freezer on top. Freezer working, temp lights on in fridge, but fridge not cooling and lamp out as well.
If the freezer is located above the fridge, the air from the freezer drops into the fridge to create the cooling in the fridge. So what I would look for is a blocked vent from the freezer to the fridge, which is usually located on the top and or back of the fridge inside of cores. You can get a frost or ice build up in there and block the air flow to the fridge, that is usuall the problem. I would also heck the dial for temp control in the fridge, I know my kids have changed it before on me.
Sep 07, 2012 | Kenmore Refrigerators
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Mar 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I have also turn the buttons off and on inside the fridge.
Feb 21, 2008 | Zanussi ZX97 / 5 Bottom Freezer...
Fridge and freezer not working right
remove and refix the regulator inside the fridge....
Jan 04, 2008 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
664 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
