Question about Health & Beauty
What tyre pressure - Health & Beauty
Tyre pressure is the pressure which is inside the tyre
Posted on Mar 26, 2011
Tyre pressure for tyre size 5.00 - 10
The maximum pressure will depend on the ply rating of the tyre and the working pressure will depend on the application.
A 4 ply tyre has a maximum pressure of around 32 psi and an 8 ply tyre about 65 psi. For many years this essential safety information has been moulded into the sidewalls.
Sep 22, 2017 | Cars & Trucks
What are the tyre pressures for a peugeot 208
the tires have that stamped into the side walls . and should also be on the tag on the door frame .
Nov 18, 2016 | Peugeot Cars & Trucks
What's the tyre pressure for a caravan with 185r14c on it
It depends upon the type of tyre, whether you have a single or dual axle as well as the weight of the van when loaded.
The maximum tyre pressure for the type of tyre you have will be listed on the sidewall of the tyre. Given the weight of a loaded caravan I would recommend you run the tyres at 2 PSI under the maximum pressure listed on the tyre for a cold inflation. If the maximum is, say, 40 psi then run the tyre at 38 psi. Tyre pressures will increase when the tyres are warmed up from running so always check and adjust the pressures when cold and purchase a good tyre gauge to carry with you if you do not have one yet. Higher tyre pressures within max specification, will lower the tyre's rolling resistance and tyre heat build up, places less stress on the tow vehicle and will give better tyre life on the van tyres.
Tyres are maximum load rated so know the van weight and make sure you do not exceed the load limits of the tyres (printed on the side wall) when adding weight to the van, including water storage.
Tyre Sidewall Explained
Jun 06, 2016 | Cars & Trucks
What is the correct tyre pressure for a 17 foot single axe pop top Regent caravan (tyre size 195-14)
I can calculate it with spreadsheet I made, call myself tyre-pressure specialist nowadays.
Depends on tyres maximum load and Pressure needed for that ( AT pressure 6pr 55psi/3.8 bar, 8pr 65psi/4.5bar or 69/70psi/4.75/4.8bar). and maximum speed of tyre given as letter mostly N to R for caravans.
Then from Caravan MPVW ( max permissable Vehicle Weight).
Or better real weight ( overloading is more rule then exeption and unequall load is possible.
But normal car tyres or XL/reinforced/Extraload are sometimes OK if they have enaugh maximum load for MPVW.
Will try to make picture of example.
Feb 12, 2015 | Cars & Trucks
I drive a 2009 Mazda bt50 single cab tray back ute. The recommended unladen tyre pressures are 32 front and 30 rear but continually have approx 240 kilograms loaded in the tray. What pressures should
you should be running 8 ply tyres on the vehicle to carry the maximum load as required by the regulator
The recommended tyre pressure will be on a decal attached to the drivers door ( probably on the door frame under the latch)
Having said all that I recommend 45 psi for the rear and 40 for the front
If you run any less ,the ride will be smoother but if you load the vehicle, the rear tyres are under inflated and prone to failure from overheating
tyres are manufactured to run at a certain pressure due to the construction of the case. Talk to a tyre shop as to the pressure you should be using for the tyres.
Feb 10, 2015 | Mazda Cars & Trucks
Tyre Pressure for Majestic 19.6 ft Caravan
Depends also on the kind of tyre.
For the maximum load of tyre nex kinds need next pressure , wich is called AT-pressure/maxloadpressure/reference-pressure , for up to maximum speed of tyre or if lower 160km/99m/h. This is not the maximum pressure of tyre.
Normal car tyre /standardload AT 2.5bar/36psi ( exeptions as low as 2.2)
XL/Reinforced/Extraload AT 2.9bar/42psi ( exeptions 2.8 and 3.0)
6PR( plyrating) /C-load AT 3.8bar/55psi EUR ( USA 50psi/3.4bar)
8PR/D-load AT 4.5/4.8 bar/ 65/69/70 psi
From E -load is not often used in Europe.
From this AT pressure you can calculate the needed pressure for lower loads . Made spreadsheet for it in wich I first add 10% to the assumed load before calculating.
Will give example picture
Jan 06, 2015 | Cars & Trucks
Recommended tyre pressure
The required tyre pressure is established by the amount of load or weight that the tyre is carrying. Over or under inflation can cause excessive tire tread wear. The recommended pressures for your tyres are shown in raised lettering on the sidewall of the tyres.
Depending on what you are towing, you will know how much additional weight is being placed on the cars rear tyres, and you can adjust the pressure accordingly.
Personally, When I am towing, I increase the tire pressures by about 5 psi just to reduce sidewall flexing and create a more stable towing package.
Hope this helps.
Apr 03, 2014 | 2005 Chrysler Voyager
What tyre pressure should the 2002 polo 1.4 auto be? Type of tyre: 165/70R14 Thanks a million.
2002 VW Polo 1.4
Tyre: 165/70 R14
- Front tyre pressure: 2,2 ... 2,4 bar
- Rear tyre pressure: 2,0 ... 2,6 bar
- Spare tyre pressure: 4,2 bar
Aug 22, 2011 | Volkswagen Polo Cars & Trucks
I want to know the tyre pressure front and rear daytona 1200
Yup nice question. For any vehicle accurate tyre pressure will give you better tyre life, low running cost, etc. Here is a chart for car tyres click here.
For bikes i havent found any chart. basically in india rear tyres having 100/90 18inch maximum tyre pressure is 32psi. front tyre having 2.75P or 80/90 18 inch uses 24 psi pressure. and do check your tyre pressure twice a month.
Dec 12, 2009 | 1995 Triumph Daytona 1200
Correct tyre pressure hyundai accent coupe i
DEPENDING ON TYPE OF TYRES IT SHOULD BE 2.2BAR LOOK ON THE TYRE PRESSURE IS PRINTED ON THE TYRE
Jun 30, 2009 | Hyundai Motor 1998 Accent
Health & Beauty Logo
64 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
