Question about Pioneer Televison & Video
How do i connect my x box to my tv - Pioneer Televison & Video
  • 112 Answers
The included video cable will suffice. Connect the single plug end to your xbox. Connect the 3 plug end to your TV (Yellow - video, Red - sound right, White - sound left).
Posted on Mar 25, 2011
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
Im not sure how to hook the converter box up to it
For a digital to analog converter box, connect your antenna cable to the converter box. Then pick your output connection. Either set the TV to channel 3 or 4 and connect the coax out from the converter to the TV or connect the composite video (AV) to one of the A/V inputs on the TV (change the TV source to the appropriate input). The source is changed with the remote (TV/Video button).
If you have other devices like a VCR in the connection sequence, you could connect the converter box to the VCR (and record on channel 3 or 4) and then connect the VCR to the TV as above. You will be limited to recording and watching the same program unless you get another converter box or tuner.
Programming the remote will depend on the box. For other set top boxes, the connections will be very similar.
I hope this helps.
Feb 17, 2011 | Sony KV-32FS10 32" TV
I am having trouble connecting my Panasonte SC-BT230 to my cable box and my TV. Do i connect my cable box to SC-Bt230 than to my TV or my SC-BT230 to cable box than to TV
Here are a few ways to go about this.
connect the cable box hdmi (if Capable) to the panasonic hdmi input. Then connect panasonic hdmi out to tv hdmi in. The easy thing about this setup is that you only need the two hdmi cables because they carry both audio and video.
If your cable box or tv are not hdmi compatible, Then connect video output from cable box directly to your tv, and send an audio feed from your cable box to the panasonic.
Hope this helps,
Good Luck
Jan 07, 2011 | Panasonic Home Theater System System
I want to connect to a TV that;s already connected to a cable tv box
What do you mean? Do you want to connect or add another tv to that cable box?
Like two TVs connected to one cable box. If so, on the back of the cable box you have three different ways to connect a tv from, through AV cable, component cables and coaxial cable.
If the main tv is connected by coaxial, the second tv can be connected thru AV or Component cables..
Hope this helps.
Sep 21, 2010 | Televison & Video
Direct TV satellite to TV connection issue
hi cable from the wall into the box then a cable from the box into the tv or hdmi cable from the box to the tv thanks
shaun
Jun 13, 2017 | Toshiba Televison & Video
How do you connect the digi box to tv and vcr
Put the main aerial into the digi box,connect a fly lead from the other connection on the digi box and plug it into the vcr,then take another fly lead from the vcr and plug into the tv,connect the digi box to the tv with a scart lead.
Dec 12, 2009 | Televison & Video
Sound from my tv card, skydude doesnt work on my hp laptop, vista home premium
You haven't mention about the connections you have with the SKYDUDE TV box. TV boxes usually have AV (audio and video) connections i.e., two seperate connections for audio and video signals. If you are using a set top box to connect to the tv box you can connect the "video out" of the set top box to the "video in" of the tv box using a cable. and "audio out" of the set top box to the "audio in" of the TV box using another cable. Some TV boxes don't have the "audio in" option. In that case you have to connect the "audio out" from the set top box directly to the "audio in" of the computer. This pin you can find just near the "speaker" and "mic" connections.
If you have an S-Video pin in your TV box, you can use an adopter wire to connect two "audio in" and one "video in" connections to the same pin. And you have to select S-Video option in the software installed.
If you have "RF in" option in your TV box, you can use use AV to RF converter to connect your set top box to the TV box.
Thank you,
Apr 25, 2009 | Computers & Internet
I have 2 DTV converter boxes - one for TV and one for VCR. The wiring is exactly as prescribed by manuals and FCC. VCR does NOT record programs from TV - altho it plays back pre-recorded tapes OK. I have...
Use only one box.
Connection should be:::Video Source(cable, antenne) connected to converter box:::::Converter box connected to VCR:::VCR connected to TV.
Try this connection and let me know how it goes.
Please rate this solution.
Lone99star
Mar 10, 2009 | Sony Televison & Video
LG Plasma 42PC56 optical digital audio out
I can't imagine your setup. Box, tv and pc speakers?
Typical setup would be box, tv and some kind audio system with optical IN. Correct wiring would be connect box to tv via scart and connect optical cable from BOX to audio system. You have to go from box not from TV since scart connection doesn't carry audio signal. To have TV to output optical audio out you would have to connect it to box via hdmi.
Dec 02, 2017 | Televison & Video
Televison & Video Logo
35 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
