Question about Galaxy Radios DX-2547 40-Channels Base CB Radio
DX 2547 Only transmitting at 1 watt and swinging backwards on the power on high side from 4 watts to 1 watt.
    Sergeant:
  • 250 Answers
Check the SWR reading on your antenna. If you have the wrong adjustment here, it is like having the wrong antenna, or none at all. You will need a SWR Meter, and somebody who knows what he/she is doing to help you.
Posted on Mar 25, 2011
MI CB COBRA DX-19 IV when someone ear me say i don t ear you well sounds like bad voice or no good my voice..
try turning you radio power down to 1 watt and see what that does .the asskicker 100 watts is being overdriven by the radio power and its coming out sounding horrorable . How many watts does the radio put out now? the lower the better like I said in the begining 1 watt is best with a box.
Mar 28, 2013 | Cobra 19 DX IV CB Radio
Cobra 200 gtl dx only does 12 watts on high
Open radio up and adjust rv9for am fm high power or rv 14 for ssb for high power,do not use a screwdriver,a matchstick would be better.board information is available from cb tricks.com
Dec 17, 2011 | Cobra 200 GTL DX 4-Channels Base CB Radio
Cobra 2000 with a d 104 mic and a palomor tx100 bi linear amp...how can if possible make the amp key up with less than one watt on the ssb side..Radio has a 4 watt dead key on am and i have ajusted the...
Hi, my name is John. Adjust the radio to key 1 watt, then switch to SSB on radio,then switch to SSB on amp, key down and adjust to 1 watt on amp. enjoy !!!!!! ...hope this was very helpful....
Aug 31, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 29 modulation modification
did you make sure the caps stripe is facing the back of the radio? If not, its the wrong way.
Also, don't use a 1/4 watt resistor because it will get too hot for it to last. use 1/8th.
changing the cap size will not change output, however it will change the tone. Bigger the cap, the deeper the tone of audio.
to be honest with you, high output mods are worthless in these radios. they are fine with out them. mosfets are unstable and are very dirty transmit finals. As well if you are planning to use a linear you may hit it too hard unless its a high drive, in which case you will need more then 35 watts swing to drive it fully. A stock cobra 29 that has been peaked and tuned, then the swing mod put in, 220uf e cap and 100 ohm resistor, which should give you about 2 watts, should swing to about 27 watts, and kick an amp in the pants.
I run a cobra 29 in my blazer with a dave made 5 pill, and I key on 6 pills and I near keyed on a 2x8. very close. All that I have done to the radio is peak and tune, (of course I have a few tricks with that up my sleave which I don't usually share with just any one.) and variable power, wich will control the dead key, which is basically a varible swing kit. I run it just under 2 watts, just enoug to get a 125 watt dead key out of the amp. The amps swings over 920 watts.
any more swing from the radio will beat up the pills in the amp.
Jan 06, 2010 | Cobra 29 LTD CB Radio
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Nov 12, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Just want to know if i should use my ll203 amp in am or ssb mode when running with a cobra CB radio?
What radio?? Does it have single side band(SSB)? If not, then don't use SSB.
AM - amplitude modulation
SSB - single side band.
If you have SSB, there would be a switch on it to transmit in SSB. If not, it is AM only.
Second, Has this radio been worked on to be able to run on an amp? If not, you will blow the amp.
A CB radio transmits dead keys with 4 watts of power, and transmits with 4 watts of audio.
a 4 watt dead key is too much for a linear amp. You will smoke the transistors. Also, 4 watts of audio is not enough to drive it properly. You won't get full power.
The dead key needs to be around 2 to 2 -1/2 watts,or what ever makes the linear dead key half its peak wattage., and the modulation (audio) turned up all the way.
It doesn't sound like you know too much about CB radio's. Not a big deal, you can learn. For right now you may want to take it to a cb shop and tell them you want a peak and tune, and set up to run a linear.
You can find CB shops usually at truck stops. Some area's they are other places. Check the internet for local shops.
Oct 31, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Tunring up a cobra 150 gtl/dx
Um... What?? This is hooked to a switch? CB radio by FCC regulations is only supposed to have a max of 4 watts total output. If you can flip it to 7 watts dead key, you are doing really good. It won't do much more then that. It sounds like its set up to run on a linear amplifier, which cannot have more then 3 watts dead key transmitting into it.
Dead key, and modulation are different. You may have a meter that only reads dead key, and won't see the modulation. This radio is probably swinging close to 15-20 watts. you need a meter that can read PEP, Peak envelope power. Cheap meters only read AVG, or average power, witch will only show your dead key.
7 watts dead key is really good for that radio.especially since stock only has 4 watts. you cannot get any higher then that without changing finals.
at 3 watt dead key, or 7 watt dead key, your modulation wattage is still swinging much higher.
Also, you will get more swing with a lower dead key any way, which is better if you want it to be loud.
Leave it alone. its probably set just right.
May 12, 2009 | Cobra 150 GTL DX Base CB Radio
Low output power
On the meter you are using, does it mesure Average power or peak envelope power?
This is very important to know when you are measuring.
AVG measures basically your dead key. It usually will very little if at all.
PEP measures your peak output, or swing. Modulation.
So even if you have a radio that has been peaked, on a meter that reads AVG, it will still read around 3 to 4 watts. And, if it has a swing kit in it, it will read even less. A swing kit lowers the dead key it increase modulation. Higher PEP.
For example. I peaked my cobra 29 and it does some where around 22 -25 watts PEP. I have variable power in it as well, but usually run the dead key at 2 watts because I have a linear. The Radio alone, when mesureing on PEP with key up at 2 watts, and then when you talk, swings to about 22 -25 watts.
If I flip the meter to AVG, it stays at 2 watts even with talking.
If you have one of those cheap pyramid meters, etc, they usually only read AVG.
Get a meter from radioshack. They have a fairly decent radio for the money. It reads both PEP and AVG and has SWR as well.
If the radio has been peaked and it has a swing mod, it will most likely be swinging to some where in the 20 watt range.
On a side note. According to FCC regulations, a CB radio is only allowed to transmit with 4 watts of final power. Most times the manufacturer will have it a hair under so that they are leagal.
Basically it is illegal to use a CB that puts out more then 4 Watts.
But its a free for all these days. There is no more funding to the FCC for monitoring CB radio, so they do not want anything to do with it. As long as you don't over do it, have over 50000 watts and terrorize a small community with RF, you can do what you want.
Now a days most cb radio's bought have already been peaked if you got it from a cb shop, or off a website that does it.
Apr 21, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
148gtl, Taiwan when you modulate the meter swings backwards
In the back is where power mods have been added...It sounds like a swing kit 1/2 watt deadkey to 25 watts which is a powerful modulation exceeding 100%. Its a 220uf capacitor in place of a jumper J1 or J(x) J something in some radios. if you replace the jumper and remove the capacitor 220uf or 470uf one.(near finals it will return to around 4 watt dead key) The result of 4 watts is modulation is flat;where if you adjust it to 2 1/4 watt to say 20 watts it will be very loud and modulation is at 100%.
Dec 07, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Galaxy Radios DX-2547 40-Channels Base CB Radio Logo
128 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
