Question about Philips 50PF9631D 50 in. HD-Ready Plasma Television
I have the Philips 50 Ambilight tv. I turned it on, the green light went on but no picture. After about 20 seconds the green light started flashing to red. Flashes 8 times, then stops, then flashes 8 times more, etc. Then the only way I can turn it off is to unplug it as the power button won't work on the tv or remote. I have tried plugging and unplugging it but it still won't come on. Can you please help??? Thanks! Jean
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, it may eventually stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
I have the Philips 50 - utube.pngYou-Tube video "Mm51C_RDIZE" placeholder
utube.png You-Tube video "BNHHrgX_6cs&feature=related" placeholder
(do not delete)
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 25, 2011
Philips widescreen flat TV model #50PF9966-37 50" plasma, as the tv warms up a loud hissing sounds comes from the back. The hissing sound does not go away when you mute the broadcast sound. when you change...
From what I'm seeing online, the bulbs in the Ambilight may be the culprit. I also read that a firmware upgrade could fix the issue too. There was also a recall of some TV's with that issue, so I would check with Philips about your model and serial number and see if your TV was included in the recall. If you raise enough cain and threaten to never buy from them again, they may get your set fixed for you... even if the warranty is up!
Good luck and please post feedback!
Oct 10, 2010 | Philips Televison & Video
Why wont my tv turn on? a red light just flashes
Right now, your TV is in " Protection Mode". A damaged part has occurred inside on one of the power supply boards. The red flashing light is a trouble code for a tech to trace the trouble circuit path.
If you have electronic experience with circuit boards, you can find a Service Manual for the TV on the internet for less than $20. This Service manual will have the schematics, red light codes, circuit diagram, and part number list you need to fix the board.
Oct 11, 2009 | Philips 42PF9631D 42 in. Plasma Television
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Plasma TV Does Not Turn On - continous Red Flashing Light
Had a similar problem with my Sony. Unplug for 36 hours and try again.
Aug 29, 2009 | Philips 50PFP5332D 50 in. Plasma...
Phillips ambilight 50 in red light problem
I had this problem on a 42" Philips Ambilight. After reading in another forum, opened up the back, and found 2 leaking capacitors on the center circuit board (main power supply pc board) toward the bottom. Tops of the capacitors were bludged out (10v 3300uF) and leaking electrolytes. Unsoldered the old ones myself, went to Radio Shack. They were out, so order 12 on ebay for $6.63 including shipping. Resoldered and works fine. Can't do it yourself? Take the board out (just unhook the cables & unscrew it ), and take it to a computer shop or tv repair or someone who knows how to solder, and have them change them. Piece of cake!
Jul 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
My flatscreen tv gets green dots that appear on screen while...
The first mistake was the Philips TV. They are the worst tv. They are constantally needed to be updated. If you have warranty, I would recommend you taking it back or calling philips customer service and getting your tv repaired or replaced.
Apr 07, 2009 | Philips Ambilight 2 52 in. Flat-Panel LCD...
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Philips 42" Plasma TV
no se como instalar la cam en miportatil
Apr 03, 2008 | Philips J44414
Philips 50PF9631D 50 in. HD-Ready Plasma Television Logo
599 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
