Question about Dell UltraSharp 2407WFP 24" LCD Monitor
I have a Dell Monitor 2407 WFPb. The monitor went black unable to locate the various adjustment button (that you can only see when monitor is bright-because it's black unable to locate them, unable to adjust the brightness and etc.). Please advise. Thank you! Sincerely, John
    Guru:
  • 811 Answers
Try unplugging it from the electrical outlet for about 25 seconds. Then plug it back in and go to your settings if the power button turns the monitor back on if it does not work try it on another working computer. Sometimes this happens when the settings are two high of resolution when your graphics card cannot handle it. Hopefully the issue is not the monitor going bad. Thanks for using FixYa! Do not forget to place a vote for me if I helped you in any way. John
Posted on Mar 25, 2011
Dell monitor went black when adjusting pixel setting. How do I fix this?
if you can still see and access the adjustment panel, just simple search for the default setting and click it and you will be good to go. hope i have answered your question...
Jul 24, 2014 | Dell Computers & Internet
Dell Ultrasharp 2407 monitor - Vertical lines
most likely capacitor problem as these caps only have a 25000-40000 hour life span. when you do replaace the monitor , turn it off when not at the computer. even though it goes into sleep mode there is still a current running through the unit cuz if you move the mouse or hit button on keyboard display wakes up. I know this because I have done boad level repair on panels
Feb 04, 2013 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
2407 screen goes black
faulty connector... need to call a repair guy to solder a connection.. usually 50 bucks
Apr 20, 2012 | Dell UltraSharp 2407WFP 24" LCD Monitor
How do you install the driver for a monitor if the monitor goes black
Go into safe mode and adjust the resolution of the screen to bare minimum. That usually allows most monitors to be usable at least inside normal operating mode.
Dec 07, 2011 | Dell E176FP 17" LCD Monitor
Lock on monitor adjustments don't know how to turn off the lock so we can adjust brightness and color
Follow these instructions :
  1. Turn on your Samsung monitor (if it isn't already.)
  2. Press the "AUTO" button on your Samsung monitor. This will run the automatic configuration utility. This will look at your current computer settings and adjust your monitor to best match those. This will take a few seconds. If this has calibrated the monitor to meet your needs, you are finished with the process. If it hasn't, continue to Step 3.
  3. Press the "Menu" button on your Samsung computer monitor.
  4. Use the arrows and the "Enter" button on the monitor to highlight and select various settings categories.
  5. Use the "Brightness" menu on your Samsung monitor to adjust how bright or dark you want the image.
  6. Use the "Colors" menu to adjust how prominent certain colors are displayed on your Samsung monitor.
  7. Use the "Contrast" menu to adjust the level of black on your Samsung monitor.
  8. Select "Save and Exit" to save your changes and exit the Samsung monitor's on Screen menu.
Dec 24, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Dell 2407 WFP monitor Flash Memory Card Reader does not
if on the card it is written SDHC then it means that the card reader doesn't support SDHC cards, for 100% compatibility try a 2/4 Gb card with only SD markings on it not SDHC.
May 25, 2010 | Dell Computers & Internet
Monitor went to black. checked and changed all
Check our web site at: www.ccl-la.com/badcaps.htm We have a free repair guide for that model Dell monitor.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 03, 2009 | Dell E173FPb 17" TFT LCD Monitor
How do I adjust brightness on Dell E152FP monitor
there's a buttong located on your monitor. just look for it then set up brightness to watever display u want.
Jul 03, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell UltraSharp 2407WFP 24" LCD Monitor Logo
148 people viewed this question
Alun Cox
