Question about Bosch & Tankless LP Hot Water Heater
Pilot OK main burner does not flare when hot tap turned on
If you are not getting error code, then problem could be plumbing.
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Many internal and external factors can also cause tankless problems without error code.
Circuit board failure, sensor failure, incoming air, venting, gas flow, water pressure, water flow, or combination of factors.
Open following link for Bosch troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Add a comment with your experience to help others with same-similar problem.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 25, 2011
I have a bosch aquasar 125b tankless water heater and the burners do not light when hot water is turned on this also causes the pilot light to go out
possible faulty pressure switch connected to the water line and that is failing to turn on the main gas tap solenoid
best have it checked by an accredited gas fitter or service center for the make
Aug 20, 2016 | Bosch AquaStar Indoor Natural Gas Tankless...
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
Sep 19, 2011 | Bosch 425HN NG Tankless Water Heater
The pilot is ok.the main burner does not come on
First check and see if the dial on the gas valve is on the ON position. Next turn the thermostat up all the way.if it does not come on then, this sounds crazy, but, tap the gas valve twice lightly with the back end of a screw driver, sometimes a spec of dirt can clog the gas valve and this releases it. if it still doesnt come on, you need a Volt Ohms meter or multi meter, set the meter to millivolts, you want to connect the 2 leads from the meter to the terminals on the gas valve that the 2 wires from the pilot generator, located next to the main burner underneath tank. turn the meter on and the millivolts should read a minimum of 400 milivolts, if lower, replace pilot generator. If still doesnt work, replace gas valve.
Aug 31, 2011 | RTO Water Heaters
I have a Bosch AquaStar AQ-125-BNG tankless water heater. It has worked very well until recently. The problem: The hot water at the tap is turned off, the flame on the main burner keeps burning and...
there is a small dia copper pipe which has a thermal coupling on it the end of it sits in the flame of the pilot light,
if it fails which it does after about 25-15 months,it shuts down the gas burner
Jul 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Pilot light will not automatically light when hot water is turned on
This is a great unit! Try turning the flow nob to the half way point and the flame all the way to low. Run the hot water tap and slowly turn the flame dial until you hear the unit try to light. Every house is different regarding the restrictions in the plumbing and water pressure. Once the unit tries to light that is your minimum setting. It is best to leave it there.
Apr 05, 2010 | Bosch & Tankless LP Hot Water Heater
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Bosch & Tankless LP Hot Water Heater  Logo
64 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
