Question about Baby Gear
I have avalon a34RMG stroller. When I installed front wheels I installed one of the front wheel wrong way. I need to remove the wheel and re-install correctly. Pls let me know how I can remove the front wheel.
  • 17 Answers
SOURCE: graco quatro wheel removal
There are several different styles of the Graco Quattro Tour stroller, but it seems that all styles have similar instructions for the wheels. For the front wheels, you might need a flat head screwdriver. The front wheels snap into place, so there should be some form of clip that is holding them in place. You will need to locate this clip (which may be inside the piece connecting the two wheels together. Use the screwdriver to reach this piece, and push it in, then slide the wheel off while the clip is still compressed.
The rear wheels will also require the use of a flathead screwdriver. There is a Graco logo on each back wheel. It is an oval piece that should be pried off with the screwdriver. You will then see a locking pin under it. You will need to use the screwdriver to spread the open end more so that the pin will be wide enough to slide out of the axle hole. Remove the wheel and the washer (be careful to move the pin and the washer somewhere where you child cannot find it, as they can be choking hazards).
The following is the link to one of the Graco Quattro stroller instruction manuals. http://www.gracobaby.com/assets/pdfs/instructions/ISPA173AB.pdf
You should be able to look at this for detailed pictures for the stroller assembly, but then follow those directions in reverse to remove it.
I hope this has helped.
Posted on Jan 01, 2008
SOURCE: GRACO STROLLER FRONT WHEEL BROKEN
I have the same problem, the airline broke ours the last time we flew. I just found on Graco's website that you can order replacement parts. Here is the link, http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
You'll need the model number and serial number. I found ours on a sticker under the footrest. For our stroller it's $19 plus shipping for the front wheel assembly.
Hope this helps.
Posted on Feb 11, 2008
  • 9 Answers
SOURCE: baby trend expedition double jogging stroller
No but if you just sort of push on one side of the handle bar it will pull it to turn without lifting the front.
Posted on Oct 25, 2008
SOURCE: Remove Rear Wheel on Phil and Teds Stroller (Dash)
There is a little push button on the metal bar that runs the length of the stroller.  good luck, my bearings have gone bad on my phil and teds and they told me that I had to replace the entire wheel at 40 dollars a pop.
Posted on May 25, 2009
SOURCE: bugaboo frog stroller- front small wheels put on wrong way. how do I get them out without breaking them?
get flash light and butter knife... shine light through back of where you have your wheels... use knife to press tab back and pull on wheel.
Posted on Jun 06, 2009
Cant remove Front wheel
Hi Fergal
We would recommend you contact Mothercare for assistance Contact Mothercare
Jan 07, 2014 | Baby Gear
Avalon 3 wheel stroller
click on contact us and they should be able to help you find a wheel
http://www.zooper.com/index.html
Robert
Please rate this solution
Sep 08, 2008 | Baby Gear
Installing front wheel on stroller
Does it have a bar like thingy that you pull to get the wheel off? If so, just pop the wheel on. Think auto factory.
Dec 01, 2013 | Graco Baby Gear
2002 Avalon spindle nut removal
To replace the spindle lock nut:
  • Raise the vehicle and support it on jackstands.
  • Remove the wheel and the wheel cover.
  • Remove the spindle dust cap.
  • Pull the cotter pin.
  • Unscrew the spindle lock nut. If the nut is a multiple-piece type, make sure you remove all of the pieces.
  • Reverse these procedures to complete the installation.
  • Torque or adjust the nut according to the manufacturer's specifications
May 09, 2012 | 2002 Toyota Avalon
I need a detailed instruction on how to fold a combi stroller
1. Lock both front swivel wheels. Not locking the swivel wheels before folding the stroller can damage the wheels 2. Empty the basket. 3. Fold the canopy by lifting the canopy levers. 4. Remove your player from the canopy. 5. Lift and hold the folding levers up on both sides of the handle. 6. Tilt the stroller onto its back wheels and roll it forward and then pull it back quickly and the front guardrail will fold inward. 7. Turn handle inward with an underhand hold to latch and lock.
Jun 02, 2011 | Combi Cosmo DX Stroller
How can i take off the front tire on stroller?cant take off the front tire. Its a graco brand.
Hi, Graco strollers all vary. Some wheels can and cannot be removed. Quickest thing to check is the undercarriage of the wheel. Front wheel ----------------- Place your buggy in front of you Then push it onto it's rear wheels The front wheels should now be up in the air Check underneath where the wheel attaches itself to the chassis Some wheels just have a simple lever you push and the wheel releases Others there's a round rod with a **** running through the middle similar to a peg if you have a pair of long nose pliers you can squeeze them together and pull the wheel towards you Others just cannot be removed peg just won't release itself or the wheel is bolted onto the chassis I hope this information proves useful. Liz.
Mar 12, 2011 | Baby Gear
How do I take off my front wheels off my chameleon
You can down load manuals from www.bugaboo.com the front wheels are held by two plastic tabs at the top of the wheel assembly. These are pushed together to let the top of the wheel assembly pass down out of the front wheel mounting. They are quite firm the first few times you remove them. If you have put the wheel assembly into the wheel mounts from the wrong side you'll need two large screwdrivers to slide down into the mount to reach the tabs.
Feb 09, 2011 | Bugaboo Cameleon Stroller
How do I fold my jogger (The Twinner II-16). I bought it used without a manual. Can manuals be located on the internet? Thanks
There are 4 pins that need to be pulled. 1st Flip the stroller over and remove the 2 back wheels...sqeeze the metal piece by the wheel and pull the wheel straight out. Pull the 1st 2 pins, they are between the back wheels and the front wheel, on either side. The bars these were holding in place will swing up. Then pull the 2 front pins (by the front wheel) and flip the front tire up. The front wheel also comes off but isn't neccesary.
Sep 15, 2010 | Baby Jogger City Twinner Stroller
The front wheels on my Maclaren XLR keep locking up
When you click the wheel release (to make them go onto swivel mode) press a little harder as it sounds like you haven't fully engaged the release mechanism.
I hope this helps.
Oct 07, 2009 | Maclaren Vogue Umbrella Stroller
I don't know how to remove the front wheel in order to install the new spare one
Remove captive washer (chrome button to you) by force, remove and replace with new washer if broke.
May 30, 2009 | Maclaren Triumph Umbrella - Navy Stroller
Baby Gear Logo
117 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
