Question about Whirlpool LEQ9858P Electric Dryer
Change a belt?
How do i change a belt
  • trajaytri Aug 27, 2008
    I took off all that I can take off of the back of the dryer. My dryer model number is LER3624JQ1 and it is a whirlpool. I cant seem to get to the belt, but I did find it broken. Since the belt was broken, I pulled it out. How woud I get any further to put on a new one?
    Sniper:
  • 68 Answers
Replacing the belt is not that hard.
  1. You have to take the back of the dryer off.
  2. Then lift the tension arm on the motor releasing the pressure on the belt.
  3. Inspect the tension pulley, checking the bearings on the pulley.
  4. Wrap the new belt around the drum, and wrap it around the tension pulley, lifting the tension pulley to adjust the belt.
  5. Reinstall the back of the dryer.
Please rate this solution
Posted on Aug 04, 2008
How to change power steering belt
How To Change The Serpentine Accessory Belt On Nissan Maxima Altima Etc
Nissan Drive Belt Tensioner and Belt Replacement 3 5 Front Wheel Drive
There are several videos on how to change out the serpentine belt For more info just do a web search " 2002 Nissan Altima serpentine belt replacement".
May 26, 2014 | 2002 Nissan Altima
What parts should i change in order to completely do a timing belt change on an '02 mitsubishi Lancer cedia? I own a 2002 mitsubishi cedia, and i just reached 110,000 Kms and would need to do a ti
Remove the accessory drive belts. Remove the power steering pump by rotating the bolts securing it to the bracket counterclockwise with a ratchet and socket.Rotate the crankshaft bolt counterclockwise with a large socket and ratchet and remove the pulley. Rotate the bolts securing the engine mount counterclockwise with a wrench or ratchet and socket and remove the bolts and the mount...
Mitsubishi Parts
Source:http://www.ehow.com/how_7950071_change-belt-2002-mitsubishi-lancer.html
Jan 05, 2012 | Mitsubishi Vehicle Parts & Accessories
When should you change the timing belt
well I think its around 60,000 miles for most vehicles but if it is going bad, i would change it asap! but it verys from vehicle to vehicle. If you have the owners manual for your vehicle, it should detail when the belt should be changed.
A good general rule of thumb is that a timing belt should be changed every 60,000 to 75,000 miles, although some belts are designed to last up to 100,000 miles before requiring a change. Regardless though, it is best not to let a belt go more then 80,000 or so. have a good day !!
Feb 25, 2011 | 2008 Ford Fusion
I bought used Optima 2004 with mileage around 120k, i'm worried about the timing belt. Should I change it now? When should we make second or third change after the 60k timing belt change.
to be on the safe side id change the belt every 55,000 to 65;000 miles make sure u change the belt tensioner as well they fail more than the belt
Feb 23, 2011 | 2004 Kia Optima
Hi, i have a 2003 toyota camry v6. everyone is saying the the bearings will need to be changed if i am going to change the timing belt. is this true thanks
If you change the timing belt it is reccomended to also change the tensioner and idler pulleys as well, depending on the mileage. You can change just the belt but it is a little risky, considering you can't actively see what's going on in there. If your timing belt slips on that engine, There's a good chance of doing major damage.
Nov 23, 2010 | 2003 Toyota Camry
When to change timing belt on 2004 honda civic
Honda reccomends timing belt change at 100k. Most Honda dealers like you to change the belt at 90,000 miles (90k). some auto repair places will want to change the belt at 60k but that is not necessary (Note: if in a severe cold or hot climate like florida or canada you would change the belt before 90k or if the belt is over 7 years old.. Good luck:
Oct 01, 2009 | 2004 Honda Civic
Timing belt change on 2002 lexus straight six cylinder engine.
how do i know when to change timing belt what are symtoms!
Apr 02, 2009 | 2002 Lexus Gs 300
Need to change the belt on my Maytag Performa Dryer
The belt is a 341241, a pretty standard belt. To install it you must get the front panel off. Do this by using a putty knife: 549402b.jpgUse this hady DRYER BELT ROUTING guide
Mar 26, 2009 | Dryers
Samsung CLX-3160 Change transfere belt
I got a way to reset the transfer belt counter:
Just press Meny.button, then #{4-digit-password-number}# and follow this path:
Techmode - DataSetup - Clear counts - Transfer belt Passord={4-digit-password-number}
The brackets should not be entered, only 4 digit.
Mar 02, 2009 | Samsung CLX 3160fn All-In-One Printer
Whirlpool LEQ9858P Electric Dryer Logo
213 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
