Question about Garden
Hi I have a Briggs and Stratton/Troy Bilt 675 series Self Propelled Lawn mower. I took the blade off for sharpening, but didn't know it had two washers. One washer is wavy in shape and the other is solid round. My question is do two washers get attached together between the blade and the shaft assembly. I can't find a manual that would show me the assembly of the blade to the machine shaft. Thanks Freddie
    Problem Solver:
  • 16 Answers
If the wavy washer you are describing is a locking washer, then the order of replacement would be, blade, then plain washer, then wavy washer, then bolt.
Carefull examination of the blade may indicate further how it was originally fitted, good luck, hope this helps.
Posted on Mar 25, 2011
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
How much oil does a 675 briggs & stratton 22" lawn mower take?
HI There try adding oil a bit at a time. They will only need minimum amount to lubricate the engine. Firstly put in about a quarter of a litre and check the dip stick after 10 mins.
Sep 23, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Troy Bilt 675 Series manual
Try internet search w/full detail like you used in question plus specifics like model number. That worked for me w/my lawnmower manual search.
Jul 09, 2012 | Garden
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
The front drive self propelled wheels stick and squeal
why is the back wheels of my briggs stratton wont stop turning
Aug 29, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Where is the carburetor on the Craftsman 675 Series 190cc 22" cut self-propelled lawn mower?
The carburetor would be located BEHIND the air filter housing and air inlet tube. The air filter housing should have a removable (by screw or clip) cover.
Apr 13, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Where is the oil change plug
The plug is under the mower on the bottom of the engine. Make sure you take the spark plug wire off before you work, remove the blade (it needs sharpening anyway right?) and then tilt the mower on its side WITH THE CARBURETOR UP. position an aluminum cake tin under the mower so that once you remove the oil plug using a 3/8" ratchet you can set the mower back down over the cake tin and it will catch the oil. Don't forget to put the plug back in =-)
Jun 04, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
318 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
