Question about D-Link DIR-600 Router
Both my PC and laptop were not able to connect to internet and I am using a dlink wireless router, what could have caused it?
Please do the wireless settings i.e configure SSID & encryption key in DIR 600.
After that connect laptop or pc wirelessly with same ssid.
Posted on Mar 25, 2011
I have a d link d1 514 router. I'm unable to open 192.168.0.1. if i put the internet connection wire in LAN then I'm able to get internet access using cable but if i put the wire in wan, I'm not getting...
carry out the resetting of the dlink router
then use lan cable to gain access to dlink router,
set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
if it has a built in wizard then just follow the on screen instructions
you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
and the your done. disconnect the laptop from wired connection and connect via wireless
Oct 16, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Can not connect to the internet using my DLink 514 wireles router
May be the wifi modem drivier is not installed properly. check it using device management
Apr 19, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
How do I intall the dlink router if I dont have a cd drive My computer is a dell inspirion and is runs on vista
hello, here is what you need to do: if have a pc connected to high speed modem directly you will unplug the network cable from the back of your pc/laptop and that end will then go in to "WAN" port on the new dlink router.
second, you take another wire and plug one end in your pc/laptop and the other end in one of the 4 lan ports in the back of your new dlink.
restart everything in the following order at 30 seconds duration:- first the cable/DSl modem, then dlink, then your pc/laptop.
once everything is up open up internet browser and test connectivity.
at this point you should have internet up and running but you need to configure you router and wireless etc.
from your browser in address bar type in http://192.168.0.1 and hit enter that will bring you router login prompt : default user name is "admin" and password is left blank and hit enter, you are now in router to configure options as you please.
I would strongly recommend changing your router password administration and if you plan on using wireless, setup SSID, encryption, network key on wireless. NEVER LEAVE IT OPEN.
Hope this helps
let me know if you have any questions
Amar Sondhi
Dec 04, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
I cant connect my wireless n router to my internet connection
hey can you see your router pppoe connectied to you pc or laptop
Jul 05, 2009 | Computers & Internet
I currently use a cable modem to connect to the internet from my Imac. I have dlink wireless router that I used to have for my old pc so that my work laptop could connect. How do I install the dlink on the...
No need to install the dlink on the imac. All you need to do is connect the modem first the dlink. (Modem connected to Internet or WAN port of the dlink). Now if they are connected, your imac should be plugged in to port 1 of dlink, and your PC to port 2. That should do it.
Nov 18, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
D-Link DIR-600 Router Logo
121 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
