Question about Hoover Vacuums
Hoover Breeze model U1432 spares Activator & belt
How to change belt on hoover breeze 2300
click link below for the manual it will show you on page 7
http://service.hoover.co.uk/manuals/BR2201.pdf
Feb 06, 2016 | Hoover Vacuums
What is the belt part no. for a hoover elite rewind?? model no. UH71009RM
If you look up the Hoover page for the UH71009 (the non-remanufactured Elite Rewind), there are 3 different belt model numbers listed. One part number is simply for a 2 pack of the belts. See http://hoover.com/products/details/uh71009/elite-rewind-bagless-upright/ . Click on the Parts & Accessories tab.
I believe the belt part number is 38528058 , http://hoover.com/parts/details/38528058/sra-r-b-562932001-belt/ .
I hope this helps.
Oct 04, 2015 | Hoover Vacuums
Belt falls off Dirt Devil upright
I have a Hoover canister vacuum it works great.
I think you have the right idea. Good Luck!
May 15, 2017 | Vacuums
Brushes don't spin
Hello :
try this please : switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
or try this also if the above suggestion didn't work :
Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
please rate !
May 07, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Cant find spare belt to order for my hoover. It's an upright durabrand model no. ymh29046. Then typ cbu1
Are you sure that your vacuum is a Hoover? There is a brand called Durabrand that makes vacuums but they are not related to the hoover brand.
Oct 24, 2009 | Vacuums
My Hoover U6439-900 also losing belts
When upside down there is no resistance,on carpet there is.
You need to try a a fresh, genuine hoover belt and buy a spare, belts stretch and slip after 30 -90 a days of normal use, often to 25-30% oversize Hoover belts generally fit very snug. If your belt looks shiny inside, that is likely the issue. Try that and post results
Sep 28, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6439: Belt keeps slipping off
The belt is stretched and you simply just need to replace it. You can get the belts you need for this model here:
http://www.vacbelts.com/hoover-self-propelled-windtunnel-belt.htm
Belt won't stay on
A belt will slip off because it is stretched, or the brush bearings are worn, or the motor drive shaft is misaligned.
Hoover belts fit snug.
After as little as week they begin to stretch. Even though they are not broken, they will spin loose. IF you can stop the brush with little effort and the belt keeps moving the belt is stretched. Do not buy a belt buy size, buy it by model. But 2 and store your spare under the hood of the vac if possible.For best cleaning results,change every 3-4 months if you vacuum weekly. 6 months at most.
Most times your old belt will be stretched as much as 30% oversize. If it looks shiny inside it has likely been slipping.
Before reinstalling check that your brush rolls freely and clean the bearings at the end of the brush roll.. Once reinstalled check it again before turning on the vac.
Sep 13, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Belt Broke - Need to replace it
All you need to do is:
1) Get the actual model number of your Hoover. The information you gave is just what appears on the front of the unit, and that's not the model number. You will find the actual model number on a small tag at the rear of the vacuum near bottom, or on the bottom of the unit.
2) Take that model number to a local independent vacuum cleaner store (not a department / big box store, which will have very limited belt offerings), where they will set you up with a new one. Probably wouldn't hurt to call first just to make sure they carry them / have them in stock.
May 07, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Hello . The beater bar is not spinning on my Hoover bagless upright rewind. Can I fix this?
very simple to repair its a broken belt read owners manual or somtimes they print instructions on the head of vaccum belts are sold at walmart you must know make and model or get number of old belt. before buying one check the back where the attachments are some cleaners have spare belts
Jul 20, 2008 | Hoover Vacuums
Vacuums Logo
69 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
