Question about Dryers
Got an older modle gas dryer running on propane, have a full tank starts up and runs for 1 to 3 cycles than dosen't fire. Ignighter works just dosen't fire up. Shut it down and wait a few minutes and works as discribed before shuting off again. Is it the regulator?
    Sniper:
  • 68 Answers
Are you any issues with any other appliances? (i.e. Water heater, range, oven , furnace) If you are having issues with your regulator(on the propane tank), then other items would be affected also.
If your ignitor is trying to ignite, then you are not getting gas to the burner.
  1. Replace the thermacouple.
  2. If this does not fix the problem, then you are looking at a bad gas valve.
Please rate this solution
Posted on Aug 04, 2008
I have a Kenmore Elite He3 dryer that runs on propane. The dryer worked fine until i ran the propane tank empty. When I filled the tank the dryer worked but did not heat up. I bleed the propane line...
To check the igniter ya need to use multimeter set to ac voltage and check for 120 vac coming into the igniter if ya have 120 volts ac and the igniter does not glow the igniter is the problem. This tip i wrote covers what to check when a gas dryer does not heat
http://www1.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 24, 2011 | Dryers
My gas furnace fires but then cuts out. There is a similar post on here about this but my problem is a little diiferent. The unit kicks on, fires then shuts right down. The blower comes on and stays on....
HAD A similiar problem last week with a customer who had just installed a pool and running off of propane tank for gouse as well... he let tank go empty and started having problems ..what we ended up finding is that not only was his regulator on tank bad he needed a additional regulator to regulate the different psi pressure to the appliances... get them to check your regulator out
Jan 24, 2011 | Goodman Heating & Cooling
Gas only comes on sometimes propane tank is full
check the voltage to the gas valve in cycle if there constant voltage there during ignition then change the gas valve
Jan 14, 2010 | Dryers
Liquid Propane vs. Propane (like used for BBQ)
They are the same thing.
The propane you buy for your BBQ is liquid in the bottom of the tank. At the top, it comes out as a gas, which you run through a regulator and then into your grill. If you by some chance turn the tank sideways, the valve inside will shut and keep the liquid propane from coming out. If it did you could have a serious fire.
However, there is a difference between what most folks call "Natural Gas" and propane. If you have gas piped into your home, it's natural gas and not propane.
Natural gas dryers won't run right on propane (LP Gas) and vice versa. There is usually a conversion kit you can buy to switch them over.
Oct 14, 2009 | Dryers
My dryer doesn't produce heat. the coil ignites
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. In your machine, it appears Amana doesn't sell the coils as a separate item and the whole valve needs to be replaced. The part number is Y504091.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
At front, remove 2 screws near floor at the bottom of the lower front panel. Pull bottom of panel toward you and down. The gas valve should now be accessible on the left. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Reverse process to re-assemble.
Sep 17, 2009 | Amana ALG331RAW Gas Dryer
Cold dryer?
I would bet on a bad ignitor. An appliance parts store should help you thru the install. Should be about $20.00 for the part.
Apr 22, 2009 | Frigidaire GLGR341AS Gas Dryer
I moved and after hooking up my gas dryer to gas tank it will not heat up....
were you on propane b4 the move or natural gas? A natural gas dryer will not run on propane nor a propane one run on natural gas
Jan 14, 2009 | Kenmore 73932 Gas Dryer
Whirlpool ultimate care gas dryer
the glow bar on the gas ignighter
Mar 15, 2008 | Dryers
Whrilpool gas dryer
Let it run. If nothing has changed, the dryer will go through several relight cycles and should eventually purge the lines of air.
Jan 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
69 people viewed this question
Top Dryers Experts
