Question about Eureka Enviro Steamer 310 Stick Vacuum
Knob I cannot open the knob to put water. I don't remember if it pulls up or you turn it around. please help!
  • 25 Answers
The safety cap (knob) turns counter clockwise to open so you can put water in. Turn clockwise to close after filling.
Posted on Nov 30, 2008
Can not get smartmix knob and plunger to line up to put back together
Turn the plunger so that the flat edge is turned all the way to the right (clock wise) as far as it will go. Turn the dial on the cover to just water and it should line up. If the plunger is stuck in the cover pull it out and put it in the bottom part of the cleaner.
Feb 04, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
CAN,T REMEMBER WHERE THE WATER GOES
Please open the top white lid and unscrew the top black knob with instruction on the back of white lid.
May 11, 2009 | Steam Fast SF-250 Mouse Vacuum
Can't get it open
had same problem. Tried pouring boiling water over cap and it seemed to loosen some so I boiled more water and put the steamer top down in a bowl in the kitchen sink and pour the boiling water in and let it sit about 5 minutes. It came loose with some effort. The grooves are the opening are metal and they had started to corrode.Once open coat with wd40.
Jan 31, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
I have no idea how to put the belt back on
Take the nozzle of, remove the brush roll, put the a new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Jul 13, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Generation 4
First off get a new belt, I am sure this one has stretched. Then put the belt around the brush roll, put it in the center, put the bottom plate back on. Then turn the big knob on the front and turn it until it locks, you will know if it grabbed the belt, it will be hard to turn. Then install the nozzle back on the vac, lock it down, turn the knob again and it will release the belt on he pulley.
Jun 22, 2008 | Vacuums
Polti 1500 no steam just droplets of water
Before trying anything else make sure you turn up the pressure control knob in the direction of the + sign if it is turned right down you will have steam in the system and the gun will be heard to click open the flow control valve but you will not get any steam because the control screw is set too low just turn it anti-clockwise to increase the flow and your good to go .I hope this helps I have one too and I some times forget to turn up the flow and wonder why for 3 minutes then realise that during storage and manuevering it gets turned down by accident and i turn it up and all is well again.
Jun 20, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
I have a bissell power steamer That is not spraying soap, only water. I have checked all the filters and belts that I know of I also tried to reprime the pump as indicated in the trouble shooting section....
If it spraying water, then the pump is ok. The valve at the bottom of the soap bottle may be bad. Also when you turn the smart mix vavle, does it turn easily or hard, if hard, try spraying some furniture polish around the knob and turn it to work in in, if it turns all of the way around and doesn't stop where it is supposed to, then the knob or the top under the knob is broken.
Apr 29, 2008 | Vacuums
Smart mix valve reassebly and alignment
Have the piston on the screw threads, put the knob on the water only setting, then after the piston is on, turn slightly so it doesn't come off, just before you put the housing all of the way down, turn the knob back to the water only setting and then push the top all of the way down. Turn the knob back and froth and if it turns smoothly, then it should be ok. If you put the top down and it is straight, the piston will go into the slot ok.
Feb 16, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Can't reassemble!!!
The piston is put on the bottom of the smart mix knob, turn the knob to the water only setting, then put the top housing back in place making sure that the piston went into the slot, after the top is all of the way down, turn the knob, if it turns easily, then it is in place.
Feb 10, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat pro tech model 7901-3 smart mix dial and valve assembly
Turn the knob to the water only, put the piston on the bottom of the knob then turn it slightly so it doesn't fall off, Start to put the cover on, when it is straight, turn the knob to the water only selection and push the top all the way down. The piston should have gone into the hole and the knob should turn easily.
Nov 14, 2007 | Vacuums
Eureka Enviro Steamer 310 Stick Vacuum Logo
121 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
