Question about RCA DCM315R Modem
The Modem DCM315 was working when suddenly it's led light became solid. Confused i turned it off, but it was still solid (when the power was still on ) then i found the reset button pusshed it , now the LED light's aren't on at all... unless i unplug the modem and turn it back on
4 Suggested Answers
SOURCE: how do I get into my RCA cable modem DCM315
For Me I Use 192.168.100.1 I don't know if that will work for you, but it might.
Posted on Apr 30, 2009
  • 164 Answers
SOURCE: i need cd for thomson cable modem DCM315 HOW I CAN
download drivers for that cable modem
http://users.volja.net/pm5884/thomson.htm
Dont forget to rate the advice.
http://www.aa1consulting.com
Posted on Aug 03, 2009
SOURCE: Cannot connect to my Internet.
With the DSL light always flashing, it means that either the ADSL signal (synchronization) does not reach your modem, or your modem cannot 'read' the signal.
You need to determine if the problem is from one of the following places :
  • outside of your house (your land line or ISP equipment) or from the modem;
  • your telephone-cable inside your house or
  • one of your equipment;
Try the following manipulations to determine from where the default comes :
  1. Determine if the problem is in your house or on the land line
    • Unplug each and every equipment which is connected to your telephonic installation (Fax, phones, answering machines etc);
    • Using the shortest telephone cable (RJ11) you possess, plug only your modem to the main telephone jack of your house.
    • If the DSL LED still flashes continuously, the problem is somewhere between your ISP's equipment and your house. You should call them and expose the situation. At this stage, you can't do much else.
  2. Determine if the problem is in your house installation
    If the DSL LED lights up when it is plugged to the main telephone jack, then it is either one of your equipment which is at fault, or the house installation. To pinpoint the problem, do the following :
    • With all the other equipment still unplugged, try the modem on all the other telephone jacks you have around the house.
    • If the DSL flashes continuously on one of the jacks, you will have found the source of your miseries. Depending on your ISP's terms and conditions, you will either have to call them of call for the services of a third-party technician to solve the problem.
    • If the DSL lights up correctly on all the telephone jacks, then your house telephone installation is good. Proceed to the next series of tests.
  3. Determine which equipment is at fault
    • Plus your modem to one telephone jack and wait for the DSL line to light solid.
    • Use a splitter (ADSL filter) to plug the equipments you possess (telephone, fax etc) one by one. Verify each time if the DSL LED is still lit or flashes continuously.
    • If one of the equipment causes the DSL LED to flash, it is that equipment which causes your problem.
    • If every equipment causes the DSL LED to flash, the it is the splitter (ADSL filter) which is causing the problem. You can confirm this hypothesis by testing each and every ADSL filter you have in your possession.
    • Replace any faulty equipment and you should have eliminated the problem.
If nothing of this solves your problem, you won't have any choice but call you ISP. Don't hesitate to tell them all tests you will have done.
May I also make some recommendations :
  1. Use a power surge protector (not a UPS though) to plug your modem to the electric outlet BUT plug it directly to the telephone jack;
  2. Make sure your modem is plugged in as far as possible from UPS, television, etc.;
  3. If possible, don't plug the modem in the same electric outlet as other equipments;
  4. Don't use any telephone extension cable to plug your modem to the telephone jack.
Hope this helps you. Let me know what happens next.
Posted on May 12, 2011
RCA DCM315 - Need password
The DCM315 doesn't have a password, as there are no real settings that can be changed by the end-user.
Sep 13, 2013 | RCA DCM315R Modem
Cable modem 315
Have a look at the link below for basic troubleshooting techniques for RCA modem
Troubleshooting DCM 315
Oct 13, 2008 | Computers & Internet
The Router is showing modem prob : when router out of loop works
Your router needs to be configured correctly
Turn everything off, modem, router and computer.
Turn on the modem first and wait for a solid data/connect light.
Turn on the router, give it two minutes.
Still if problem presists you need to reset the router ..
How to reset::
Push and release the “Reset” button.
The lights on the Router will momentarily flash.
The “Power/Ready” light will begin to blink. When the “Power/Ready” light becomes solid again, the reset is complete
Jun 05, 2010 | Belkin F5D8236-4 Router
My Belink (F5D8236-4) Router stopped working. The modem light blinks orange. When connecting the modem directly to the PC the internet works. How do I resolve tis issue?
It shows your router is not configured properly
How to reset::
May 15, 2010 | Belkin F5D8236-4 Router
I have the Zoom X6 (5590) DSL Modem, trouble using software
You may check the following:
1. Make sure to plug the power cube into a power strip or wall outlet and then plug the power cube's other end into the modem's power (PWR) jack.
2. You should only use the power cube with the Zoom X6. Other power cubes may damage your hardware.
3. Try another wall outlet.
4. Reset the modem. Use a paper clip and insert it into the RESET pinhole in the modem's back panel and press it 3 times. Then turn off the modem for a minute and turn it back on. Check if the power light will turn solid green.
5. Possible defective modem.
Hope this helps! Good luck!
Dec 12, 2009 | Zoom X6 Adsl Modem/router Rohs...
Solid red LED for power, Solid green LED for wireless
You can try upgrade the firmware of the device first and then reset to factory default.
Jul 12, 2009 | 2wire 2700HG-B Router (2700HGB)
NOkia seimens hardware problem
1.check out whether you are using the same adapter provided with the modem, if not sure check the voltage rating details provided on the modem as well as the adapter.
2.try to reset the modem by pressing the rst point provided at back side of modem keeping the modem in on condition. keep the reset s/w pressed till you see the modem lights turning off and again turning on.
3.if the lights light up normally you have the configure the modem.
4.if still having problem contact me on 9444482052 ........jammy
May 18, 2009 | Computers & Internet
How do I get into my RCA cable modem DCM315
Apr 16, 2009 | RCA DCM315R Modem
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
I cannot connect to my friends insight digital broadband with my computer. what do i do? i've tried repairing and renewing the ip address, but nothing...
Is the PC wired directly to the broadband modem?
If it is, try this:
* Turn off the PC
* Turn off the modem - make sure its powered off completely
* Wait 30 seconds
* Turn modem on, wait for the lights to become solid (Cable or Online LED should be solid)
* Start the PC
Nov 06, 2008 | Computers & Internet
RCA DCM315R Modem Logo
124 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
