Question about Dryers
I'm looking for a pdf of the LER6620PQ0 whirlpool dryer repair manual. Would you know where I could find one? Thanks
  • 1028 Answers
SOURCE: Whirlpool gas dryer LG5801XS
look under console if has a bottom panel could be on back side of it
Posted on Jun 07, 2008
  • 115 Answers
SOURCE: dropped item down Dryer lint filter...
you will have to take unit apart there are usually screws on bottom holding front panel on unplug dryer first
Posted on Aug 19, 2009
  • 1382 Answers
SOURCE: no heat , drum turns and wont shut off
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Hi, On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on May 06, 2010
heatman101
  • 43501 Answers
SOURCE: will not start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 06, 2010
  • 127 Answers
SOURCE: LE GQ8000HQ Whirlpool Ultimate II Electric Dryer
Copy and paste the below URL into you address bar. Go to last page.
http://www.kitchenaid.ca/assets/pdfs/literature/Repair%20Part%20List%20-%208180403.pdf
Posted on Jun 03, 2011
Manual for Whirlpool Dryer Model Number LGB6400kQ1
If you need Adobe Reader Click Here=> http://get.adobe.com/reader/ Then Click Here=> LGB6400kQ1-User_Manual.pdf and for the parts manual click here=> LGB6400KQ1_Repair_Parts_List.pdf If you are having service problems with your dryer I will answer your questions. Let me know and please rate if helpful, Thanks Sea Breeze
Link for Whirlpool Manuals=> http://shared.whirlpoolcorp.com/product_literature/search.jsp
Nov 07, 2011 | Dryers
Will not start
heatman101
Jun 06, 2010 | Dryers
No heat , drum turns and wont shut off
May 05, 2010 | Whirlpool LER4634J Electric Dryer
Ler6620pq0 wont heat up
Usually no heat with this unit is the thermal cutoff that is attached to the heating canister. It is a 2 piece kit when you have to change it. The other thing would be the element but check the cut off first.
Feb 28, 2010 | Whirlpool Dryers
Dryer model LER6620PQ0 dryer runs, but will not heat
If drier runs and doesnt heat, it can be one of two things. 1)The over temp. th/stat has activated. Possibly it can be reset. or 2)the actual element is faulty, which would need replacement.
Sep 21, 2009 | Whirlpool Dryers
Dropped item down Dryer lint filter...how to get it out? Tried to go from both ends...no luck...Whirlpool gold..model LER6620PQ0
Aug 19, 2009 | Whirlpool GEQ9800P Electric Dryer
Dyrer will spin but no heat, i noticed the other day after i took cloths out it was fire red in the back of dryer. model # ler6620pq0
It sounds like a lack of airflow.
Has the lint trap been cleaned?
Depending on the view you had of the "fire red", you could be looking at the heating coils, which will glow some. Unless the overtemp switch is not functional, returning air flow to the dryer may be the only issue.
Jul 09, 2009 | Whirlpool Dryers
Trying to locate thermistor whirpool dryer and replace it
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208180470.pdf
Try this web site. Look on page 5, item 42. It is listed as a thermistor. If you can not get to the site, let me know and I'll give you the step to find it on the whirlpool web site.
Jun 16, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
76 people viewed this question
Top Dryers Experts
Marvin
Marvin
