Question about Frigidaire 14 Cycle Tumble Action Washer
It will not let the water out or spin I think it is the water pomp how do I change the pump I have a frigidaire tumble action washer
First try pressing the start and cancel buttons for about 3 seconds and see if there is an error code, then you can troubleshoot from there....Have you checked the drain lint trap? It is inside the accordian looking drain hose that attaches the drum to the pump. It may be clogged. Use a wet/dry shop vac to remove as much water as possible. Unplug the machine. then remove front panel and remove clamps to check if it is clogged. Hopefully that is the problem!
Posted on Mar 25, 2011
Need to replace water pump in Frigidaire tumble action front loading washing machine. Parts are hard to reach/get to. Is there a step by step for the process available?
After unplugging the machine, turn it around and remove the rear cover, After that all the parts are relatively easy to access and it will be obvious how to replace the water pump.
Feb 13, 2011 | Frigidaire 14 Cycle Tumble Action Washer
I have a 7 year old Frigidaire washer (Model #GLWS1349AS1) and the water drains really slow and the spin starts before all the water is drained and then the washer leaks as water is still in it during spin...
you have a restriction in the drain somewhere or there is something inside the pump housing,chk every line from the tub to pump to drain pipe and hoses for blocks or kinks
Apr 09, 2010 | Frigidaire FTF2140ES King Size Front-Load...
Frigidaire tumble action washer will not agitate or spin. Drain water fine. One of the shock absorbers is broken. would this be the problem? The belt is fine.
Yes there are several balance switches in the unit and if the shock is broken at least one switch has been activated. If you were to some how bypass the switch the unit would be very dangerous to even be near during the spin cycle as it would try to walk, tumble or jump across the room! The switch is a safety feature for all concerned.
Please get your machine repaired.
Thanks for using FixYa!
Kelly
Mar 10, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Washer will not drain and go into spin
Possible bad pump or plugged drain line, door will not open if water in tank
Mar 03, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Tumble Action washer won't complete the final spin. leaves clothes soaking wet.
Had the same problem and fixed with ease. The problem is with the door lock. There is a secondary locking mechanism that kicks in for the final spin due to the high speed. When the secondary lock goes bad the washer will not do the final spin. The replacement part is under $40 @ AppliancePartsPros.com .
Dec 08, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Tumble Action Washer
I called in an electrician/plumber - thanks !
Jul 01, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire 14 Cycle Tumble Action Washer Logo
88 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
