Question about Xerox Phaser 6180N Laser Printer
Xerox phaser 6180 no display just all lights are
Xerox phaser 6180 no display just all lights are on. display lights on green,red,power saver lights on printer sounds like its powering up no response from key board
  • 2072 Answers
SOURCE: Xerox Phaser 6180 uses too
In all honesty, its not that they use to much toner. Xerox does NOT put nearly enough toner in their cartridges to get the proper yield.
I have gotten as low as 200 pages out of those cartridges.
I do service on them and they do not give 1/5th the yield they advertise.
Nothing you can do to be honest. But they are hugely inefficient.
Posted on Aug 13, 2008
  • 2072 Answers
SOURCE: XEROX PHASER 6180 LASER ERROR
That is a laser fault. You should have a 1 year warranty from Xerox on that product. Call 1-800-835-6100 have your serial number ready.
Posted on Sep 04, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 8200 error code 15004.45:25393
Yep. The drum heaters are burnt out.
There are 2,,, 150 watt Halogen lamps that heat the drum.
The way to see if they are working or not is to turn off the lights in the office or room the printer is in. Turn the machine on and look through the fan slots on the right side of the machine. GIve it a minute or two and you should see lamps glowing inside, ( I seriously doubt you will see them comming on).
That is a very common problem, You can purchase those lamps at Lowes, Home Depot or anywhere you can purchase halogen lamps. They cost about 12 dollars for a good pair.
Replace both .. If you want to try and do it yourself. Let me know I will send you directions.
Posted on Sep 11, 2008
  • 49 Answers
SOURCE: Color Printer Xerox Phaser 6180 Black Background Print out
Try the link below. If the toner is leaking from the cartridge return it to shop were you got it if it is damaged.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=466,E=0000000001344030351,K=1906,Sxi=11,Case=obj(1307)
Niallbt
Posted on Mar 30, 2009
SOURCE: Xerox Phaser 6180 MFP-D password
The default password is "00000" If this password does not work you can follow the following to reset it:
  1. Power OFF the machine using the power switch located on the right side of the machine, toward the back. Press the power switch to the (O) position.
  2. Press and hold the [OK] button on the Control Panel.
  3. Continue to hold the [OK] button and power ON the machine. Keep the [OK] button held down until the Ready screen is displayed. The password is now reset to the default Control Panel password, which is 00000.
    NOTE: There will be no confirmation message during or after the machine's power on sequence. However, if the procedure was performed correctly, the password has been reset.
Posted on May 29, 2011
Xerox phaser 6180 has error code LPR and blue horizontal marks in background show up.
Background is usually a cleaner unit fault, need to check out more on this point. Best to start from this point and try this to see if you can make changes.
Good luck.
Oct 06, 2014 | Xerox Office Equipment & Supplies
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
Xerox Phaser 6280 Y CRUM ERROR
The yellow cartridge either has a corrupted chip, or the wrong chip, or its a cartridge from a different model of printer.
Xerox 6180 and 6280 cartridges LOOK the same, apart from the label and part number - the chip is different.
Feb 08, 2013 | Xerox Phaser 6180N Laser Printer
I have an older Phaser 6180 printer that was never used until i opened the box today. I think it was a 2007 version but never opened. I connected it to my windows 7 computer with usb and while...
You most likely need a Windows 7 printer driver.
Go to the Xerox WEB site to download the printer driver -
http://www.support.xerox.com/support/phaser-6180/downloads/enus.html
Jan 19, 2011 | Xerox Phaser 6180N Laser Printer
My phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 8200 goes through post then hangs.
Sounds like a RAM problem. Go to the back of the machine, You will see  2 large, thumb Screws, Twist them about half a turn and remove the main board. Remove and reinsert the memory stick. If that does not fix it the main board or the electronics module has probably failed.
Mar 03, 2010 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8560 display error
There is a known issue with that display. Call 1-800-835-6100 and tell Xerox you have a problem with the diaplay, They should replace it free.
Jan 26, 2009 | Xerox Phaser 8560MFP Laser Printer
How to replace the waste container in phaser 6110?
The easiest way I can tell you is this.
GO to Xerox,com, click on support and drivers.
THen the search box comes up type in phaser 6180, then enter, when the next screen displays click the support line for the 6180, In that search boc type in replace waste and step by step directions with photos come up,
Its the best place to go to find that information.
Jul 18, 2008 | Xerox Office Equipment & Supplies
No Display
in response to the previous response, does the printer have to be under warranty to receive the free replacement?
Jun 02, 2008 | Xerox Phaser 8550DP Printer
Xerox Phaser 6180N Laser Printer Logo
49 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
