Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
My paloma tankless gas has a error code c2 11 c4 12 why
Open following link for useful troubleshooting information:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error code 11 is 'No ignition'
http://waterheatertimer.org/pdf/Paloma-Tankless-Error-Codes.pdf
Ensure you have gas to the appliance.
Ensure gas type and pressure are correct.
Bleed all air from gas lines.
Ensure gas line, meter, and regulator are sized properly.
Ensure appliance is properly grounded.
Check gas solenoid valves for open or short circuits.
Ensure igniter is operational.
Check igniter wiring harness for damage.
Error code 12 is 'Flame Failure'
Ensure flame rod wire is connected.
Check flame rod for carbon build-up.
Check power supply for loose connections.
Check power supply for proper voltage and voltage drops.
Disconnect remote control.
Disconnect and re-connect all wiring harnesses on unit and PC board.
Ensure proper venting material was installed.
Ensure condensation collar was installed properly.
Ensure maximum vertical vent length does not exceed allowable limits.
Ensure maximimum horizontal vent length does not exceed allowable limits.
Range of causes are part failure, gas pressure loss, air in gas line, improper installation of gas line or vent, 120V power to unit is disrupted or unit not grounded, circuit problems, venting problems, remote control, wiring to PC board, board failure, carbon build-up on flame rod, short circuits on gas valve solenoids.
The fact that you have error code tends to eliminate your plumbing as culprit, the error code does not mention air supply, otherwise it looks like every possible cause is on the table.
Add a comment with your experience so other with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 25, 2011
My Paloma pg-711fr is turning itself off and error 12 comes up
Copy following link for error codes and Rheem-Paloma tankless troubleshoot.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#error
Add a comment and say if this is new installation.
Call Rheem and hear them tell you to call the tankless installer, or hire local service technician to check your tankless computer that heats water, and catch up on required monthly and yearly maintenance. For example cleaning burner and flame rod, or replacing bad flame rod, or installing correct gas line, or checking gas pressure etc.
Fix any tankless problem yourself, any brand tankless, same day for $385, by replacing 1 part: the whole thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Do not install tankless.
Jul 21, 2013 | Water Heaters
I have a paloma tankles water heater model #ptg-42pvn i am getting an intermitent error code C4,12. what is the problem?
Copy following link for Rheem-Paloma tankless troubleshoot and error codes:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
If unit worked before: Maybe bad PC board. Maybe lack of required yearly maintenance.
Common error codes can be caused by not following maintenance protocol such as cleaning combustion parts, checking gas pressure, checking venting, and air intake, bleeding gas line etc.
Too bad Rheem-Paloma manuals do not show HOW to conduct this maintenance, leaving customer with many unknowns, and no way to oversee that maintenance performed by hired technician is complete, and matches recommended maintenance.
Sell unit on ebay, and install tank-type gas water heater.
Mar 20, 2013 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Error Im getting is C8 82
Before calling service tech, copy following link for Rheem-Paloma troubleshoot resources:
C8 is usually the PC board, or could be failed gas solenoid valve.
82 is gas-type-data-failure = program PCB for proper gas type, or proper altitude above sea level.
If this is new installation, Rheem-paloma might tell you to contact the installer.
If this is older tankless that worked before, then things point to failed PC board. Rheem-paloma may send you new PCB for free if unit still under warranty period for defect parts.
Rheem does not post service manuals, but will send instructions.
Hopefully the success rate for replacing your main PC control board will have better outcome than expected when replacing motherboard on your computer.
Perform regular maintenance to avoid some common error codes.
Aug 16, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
My Boch 24ES Highflow Hotwater is showing Code 14 and only runs for i minute then shuts off
Code 14.
What water heater do you have?
Question posted under tankless Bosch, but these error codes start with a letter.
Rheem/Richmond etc Tankless has error code 14
Call tankless service technician.
Ask technician how much it costs to have recommended yearly service.
Or install whole new tank-type gas water heater yourself for $350 from local box store, and avoid the entire headache, then sell tankless online for parts.
Aug 09, 2012 | Water Heaters
Error 13 paloma tankless hot water system. no hot water
Before calling service technician, open following links for error codes, Rheem/Paloma chat and tech support, and possible manual:
http://www.fixya.com/support/t3444443-paloma_tank_less_water_heater_flashes
Error codes are considered start-point for troubleshooting.
Tankless manuals recommend yearly service including burner cleaning, gas pressure and plumbing check, de-liming etc to prevent problems and so technician is familiar with that specific unit.
Aug 05, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have an error code of c2 11 on rheem model number ptg-74pvn-2 I will get warm water for about 5 seconds and then it goes cold
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner -Lou
Dec 10, 2010 | Rheem Tankless Hot Water Heater...
PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Dec 06, 2009 | Rheem Paloma Tankless Water Heaters...
Problem for Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor... What does C2 11 error code mean on my Paloma
hi pete here ill try and help this could be 2 things check the sensor on the unit the outher one is a qustion has the gas company changed your meter latley and turned off you gas and not come back to light your poilet because this code also means not enough gas or wrong type of gas
Nov 18, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
654 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
