Question about Insignia 2.0 Speaker System (2-Piece)
When i plug them into my computer and sound plays, it sounds like its echoey like your playing it in a dance studio. how do i fix this
  • Insignia Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 25, 2011
Why do my cd decks sound echoey
It might still be a installation issue but if you are using a Surround Sound type amp that might be on. If the unit is doing it by itself then there could be an internal problem with a delay line or A/D converter.
In all of my years I have never heard of this symptom though.
Jan 20, 2013 | Audio Players & Recorders
My sound is real funny like chipmunk sounds
If the pitch of the sound being played by your computer speakers has changed dramatically or songs and videos are playing faster or slower than they typically should be, the problem is with the sound speed on your computer. This could mean a hardware issue with your speakers or sound card or a software issue with the program that you're using to play a digital media file.
Double-check your speaker connections. If one of the audio cables that runs off of your speakers isn't plugged correctly into your computer, this could cause the audio coming from them to speed up or slow down. Make sure all cables are properly connected to their proper inputs and try to play your audio again. Update the driver for your computer's sound card. Go to the website of the company that made your sound card and look for your unit's product page. Under the "Support" section, click on the download link for the latest device driver. Once the file is on your computer, double-click on it to install it. Then restart your computer and try to play your audio again. Make sure you haven't accidentally sped up or slowed down the media file you are trying to play. Many digital media programs like iTunes or Windows Media Player have features that allow you to play a song or video in slow or fast motion. If this becomes accidentally selected, the audio will also be in slow or fast motion. Click "Stop" to stop your media file from playing and then click "Play" again to allow it to play normally. Restart your computer. This will free up system memory when your computer restarts. If your sound was playing too slow or too fast due to an error with not having enough memory to play properly, that error will now be fixed and your sound should return to normal speed. Hope this helps.
Dec 28, 2012 | eMachines Computers & Internet
RE: Sony Acid Pro 6.0 I've made some custom loops (sound effects). They play fine on other wave editors, but in Acid they sound doubled (like the feedback effect you hear when you are monitoring a live...
Hi, I have used acid 6 for years on pc and never come accros this. Are the bit rates correct to the new track? Make sure you are not using any rewire objects on those tracks, maybe try re-bouncing them and making the file again with a new name.
Jan 06, 2011 | Sony Acid Loops Troy Klontz Rhythm Twang
Dell Movie Studio Plus - Video But no Sound
Make sure your audio out from the VCR goes into your sound card's IN device. Then also go into your sound properties and make sure the level is up for the Line IN. After doing that, try another record(download) and test the sound. If it still doesn't work, check Dell Movie Studio Plus' preferences see if anything about what input your using. I'm not familiar with this specific software, but related packages sometimes in preferences there are options to select different inputs. (in case you have more channels or multiple sound cards)
If you are using Windows as your OS, make sure you have the newest drivers for your dell, check for drivers here.
Jul 25, 2009 | Dell Movie Studio Plus (2x125)
My MIDI won't play back even when I play the file, no matter which program I use to play it. The computer I use is a Compaq Presario, I have Cakewalk Home Studio 2002 on it, and my sound card is SB X-FI...
The default MIDI setting of your PC may have been set for another MIDI device (for example, if Cakewalk Home Studio has been used with a MIDI compatible keyboard). Go to... Control Panel / Sounds and Audio Devices / Audio / MIDI music playback and change the setting back to your soundcard (and set as default if you prefer).
May 03, 2009 | Computers & Internet
Sound and picture
Check that you have connected the component video lead to the correct sockets in both the TV and the HTS9800W.
There are two sets of Phono (cinch) connectors, which are grouped together.
Red / Green / Blue - Component connectors - video only
Red / White / Yellow - Stereo audio and composite video connectors - audio and vide
If you have inadvertently connected the red audio connector to the red component input on the TV, it would cause similar symptoms as you describe.
Jan 13, 2008 | Philips Cineos HTS9800W System
Re: No sound
yup 9 proable dont suprt vista 11 verison will and beter
Jan 05, 2008 | Ulead VideoStudio 9
Won't play through Computer Speakers
Hi, go to start, control panel, Sounds and audio devices. You will need to set the audio system up here. Select the connection you have to the system, that should cure your problem. Regards mistyman
Sep 04, 2007 | Lexicon Omega Pro Studio External Sound...
Only recording 59 minutes in LP mode
My WS-recorder did something simular to me. I hadnt used it for a while then it would only hold about 20 min. of recording no matter what record mode I selected.....so..... I held down the menu/folder button to get to the menu "mode". Press the FF to scroll through until you get to "FORMAT". Press Play and the screen will show "NO"...press FF to chose "Yes" it will ask you "are you sure" press FF to say "YES" then play to make it reformat. It hangs out for a couple of seconds then after that I have my regular 4 hours of record time back. ***** I would make sure I had downloaded all my info off the WS-100 BEFORE I did a re-Format.**** I dont know why it worked, but it did. I like this little recorder and Im glad to have it functioning properly again. The tinny/echoey sound could just be the environment you are in. Even how close or far it is from the subject...how many people are in the room....if a fan is on in the room....This little thing isnt super high quality in its play back mode....hook it up to you computer speakers and you will like the sound much better. Good Luck.
Jul 22, 2007 | Olympus WS-100 Digital Voice Recorder
Echo when playing surround sound
You want to adjust the "DELAY" setting on the receiver. The standard (default) delay setting is 20mS, which may need to be shortened if your speakers are well behind your listening position. In a proper setup, you should not detect a significant echo effect in surround programming (unless it is a purposely "echoey" scene). Also, make sure you don't have any of the "enhanced" DSP modes engaged -- some of these are quite echoey. if it has speaker set up, there should be a setting for distance. You might have it set close, so that by the time you hear the fronts, the rears should go. Try setting it farther each time until it sounds right. good luck
Mar 24, 2006 | Teac AG-D8900 Receiver
Insignia 2.0 Speaker System (2-Piece) Logo
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
