Question about Logitech Z4 Speakers
Given subwoofer of z4 but no remote cable; do you have a schematic so i can create my own?
Need the logitech Z4 user manual
connect it to the back of your computer, many monitors dont have 1/8 pin connections for audio out
Apr 20, 2013 | Logitech Z4 Speakers
Sound comes out of the right speaker with the z4 volume set at minimum. however the sound can be controlled by the windows volume control. When you turn up the volume on the z4 the left speaker works....
open your subwoofer because main system is inside in your subwoofer than clean it with a air blower ..
this happens when dust is inside the system....
Dec 26, 2010 | Logitech Z4 Speakers
Crackling sound
The crackling could be due to a faulty wire or jack connection. If you have any other sound device (e.g. headphones), try connecting that one instead of the Z4 and see whether the crackling disappears (in which case it's the Z4) or not (in which case it's the jack or the computer). Could arguably be an EM or electrical interference, but you'd need a laptop running on batteries to check the second, and trying orienting differently the speakers to try checking the first.
The music slowing down means something's wrong in the computer: the Z4 are purely passive, they can't do anything to the music tempo. Try running an antivirus check or try Task Manager (or Process Explorer) and see whether anything's eating more CPU than it should.
Mar 28, 2010 | Logitech Z4 Speakers
How can i open up my remote without breaking it
Pull the volume knob and bass knob right upp. They sit hard but will eventually slip off and are easily put back. Turn the remote back side up. Remove the small cushions, the adhesive on them will hold them in place when assembling later. You will find a screw under each of them.
Mar 04, 2010 | Logitech Z4 Speakers
Car that I am looking at has remote keyless entry but the shop selling it doesn't have the remote key for the car. It only has the spare key. the car is a 2007 bmw 3.0i z4 convertible. Can the remote key...
My advice, If it's not a bmw garage then look around for another Z4. You would have to get the key programed to that car which will be expensive.
I do not know the exact cost but for peice of mind phone the bmw garage and ask then how much that would cost to fix.
I would look around for another, when spending that sort of money you want everything with the car to be spot on with no missing bits.
Regards
Dan
Jan 31, 2010 | 2007 BMW Z4 Roadster 3.0si Convertible
How do you get the best sound out of logitech z4 speakers
If you have a newer model computer chances are you'd be getting the best sound quality now. If you want to improve the quality some look into sound cards at most tech retailers.
Jan 12, 2010 | Logitech Z4 Speakers
Play sound from music files, video files and DVDs,
thats not a hardware problem your speakers are fine sounds like a codex problem try downloading VLC free
and also put the downloaded audio on a pen drive and see if it will play on another system the files you downloaded may be corrupt
Dec 02, 2009 | Logitech Z4 Speakers
Logitech Z4 Speakers are both Dead.
The wires you put on are probably too small.  The gauge number is too high.  If the wires in the plug are okay, just get some light wire (like is on a table lamp) and use that.  It's similar to what they call monster cable but nowhere as expensive.   It's all about signal flow.
Jul 09, 2009 | Logitech Z4 Speakers
Feedback issues.
Did you run your power and remote wires the same route as your RCA cables? If you dont run the RCA cables on the opposite side of the power and remote you will get feedback through your speakers. I run my power on the side closest to the battery along with the remote ( passenger in my case) and the RCA cables should be on the opposite side( driver side). They say the power current will create a disturbance in the RCA cables that you would hear as feedback. Hopefully this will help you.
May 28, 2009 | MTX Thunder 8302 Car Audio Amplifier
Logitech Z4 Speakers  Logo
228 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
