Question about Sony Cyber-shot DSC-N1 Digital Camera
No appearance of LCD Backlight - Sony Cyber-shot DSC-N1 Digital Camera
    Novelist:
  • 137 Answers
Turn the dial, on top, to menu
Under LCD Backlight <select on>
Posted on Mar 25, 2011
Black screen
Hello
The backlight is not there. Check the backlight inverter. This is a common fault to most of the flat panel TVs.
Dec 18, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
Sounds from tv when titles appear
U mean the tv have pictures flashes only a few sec. than dies have the tv pragram sound left only?Yes? Mean ur tv have a tv LCD Screen Panel have no tv LCD screen backlight to produce tv pictures tv now are having backlight problems.The tv have 1 or 2 long boards that are called LCD inverter boards problems and the causes.These 1 or 2 long Lcd inverter boards only job are to produced backlight for the tv LCD screen panel to hold on to give the tv screen panel to have pictures only.Tries websites like Shopjimmy.com,EBAY.COM to those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Oct 03, 2011 | Philips Televison & Video
LN-T4061F turns on black screen sound is there and no menu appears
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backklight board.U will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Feb 27, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
JVC LT-37X688 37 in. LCD TV. When powered on there is a brief flash of light on the screen and then the screen is black and stays black. Audio is fine and I can still use all of the remote controlled...
No lamp on LCD tv.The LCD backlight inverter board it dead,that board needed replaced to get picture back.Tries Shopjimmy.com,Ebay.com to buy the LCD backlight inverter board.It usally a long board.The refurbish LCD backlight inverter board about $100-$120.
Feb 14, 2010 | JVC LT-37X688 37 in. LCD HDTV
My pc blank when bootup
If the laptop appears to boot up and the hard disk LED flashes then you have a backlight problem.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Nov 22, 2009 | Compaq Presario Notebook
Power stays on but screen goes black on my Gateway laptop.
www.ladparts.net
Nov 22, 2009 | Gateway 450ROG Notebook
Acer 5515 backlight not working also bootmanager missing
You need to fix the boot manager problem first by connecting an external monitor to the laptop so you can see and do a system repair.
As for the backlight problem :-
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info
Aug 14, 2009 | Acer Aspire 5610-4648 Notebook
Nothing appears on the display.
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 07, 2009 | HP Pavilion ze2000 Notebook
My sidekick three has glitches and the backlight wont turn on
If the backlight on your sidekick 3 is dead, you will need to replace the lcd assy. They runa bout 30 dollars on ebay and are easy to do.
Here is a guide for the replacement of the lcd screen:
How to replace Sidekick 3 LCD Screen
find the screens here:
Sidekick 3 LCD Screens
I hope that helps everyone.
Nov 23, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Lcd tv backlight prob
You need to replace the inverter board if you can find the spare part. Otherwise you need to replace the whole lcd panel.
Jan 01, 2008 | LG RZ-17LZ40 17 in. LCD Television
Sony Cyber-shot DSC-N1 Digital Camera Logo
27 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
