Question about Samsung SyncMaster 152N (Black) 15 in. Flat Panel LCD Monitor
Hi I have a syncmaster b2430 which has been great for a few months. All of a sudden it seems to be unable to get the signal from my CPU. It goes from hdmi to analog to digital and just flashes a screen saying check signal cable hdmi. What can I do?
    Genius:
  • 1,043 Answers
First check to make sure that your cable is connected securely to both your monitor and your PC. IF it is, then try and boot your computer into safe mode with networking to see if you can get the monitor to work in that mode. This will only load the most basic VGA driver and should work. If it does then go to your graphics card manufacturers site to see if you have the latest driver for your card. If you do not then following the instructions on their website download and install their latest driver. If that doesn't resolve the issue then you will have to take your PC and monitor into your local repair shop as one of those components has stopped working.
Posted on Mar 25, 2011
Tivo turns off TV
For some reason your Tivo is tripping the internal breaker of your TV. Check the cables and see that they are not damaged and are connected properly (all the cables that hook up to the Tivo). If you have a spare set of cables, try them to see if the TV still turns off.
Jan 01, 2008 | Tivo Series 2 80-Hours Video Recorder
I have a samsung syncmaster 403T lcd monitor..its working good in self tet mode..picture is ok.. working normally,the problem is when i connect to pc or any video signal suddenly work after goes to wh
Sounds like T'Con board fault. Contact any service technician. When video signal interfaces, it goes overloaded. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 23, 2014 | Samsung Televison & Video
Screen says check signal cable - have check my cables....
Not really...
First check if the cable connected from the monitor is secured and properly connected to the video card of the CPU.
"Check signal cable" will only be display if there is no signal coming from the CPU.. that signal Passes through the video card..
Check the status of your video card.....and see also if the CPU is working and not dead set.
Hope this help...
Much appreciated if you rate this help.. thanks
May 21, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
No signal
check whether signal cable is connected or not connect it properly and latch the nuts also.the fault may lies in the cpu not in the monitor
Apr 11, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
Hi I have a samsung syncMaster 920N The screen has suddenly gone blank - the power light is showing. I have a second identical monitor and have swapped cables but no difference Is it a repairable fault?...
This happened to me a few months back. I removed all cables and left it for 2 days. Switched back on on it worked fine. That is until yesterday when half the screen went black. I found that my driver was out of date. I have undated the driver but have decided to leave it off and unplugged for another day.
You could try this. You say you have another monitor, i would suggest using it for a few days and the try the old one again.
Dec 05, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
Same problem- SyncMaster goes on/off, bad TV image, needs reset
try to update the monitor driver tehn check the same with the cables from cpu detached if no signal comes for long then the monitor is fine also try to check the monitor on bios screen
Sep 15, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Samsung syncmaster 551v
you dont have problem with your monitor, check your cpu very well am very sure you have problems with your system board
Jul 17, 2009 | Samsung SyncMaster 151 N 15" LCD Monitor
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
Apr 22, 2008 | Samsung SyncMaster 17" LCD Monitor
No signal from cpu
i think you should check if the sync wires are properly connected both on the db15 connector and the main board
Jan 30, 2007 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 152N (Black) 15 in. Flat Panel LCD Monitor Logo
586 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
