Question about Garden
After pumping to get pressure there is no spray coming out of the nozzle
  • 43,501 Answers
The pump for the tank is not working correctly.
Often times over the winter the washer in the pump dries out and will not pump air then.
Try taking the top off or just spray some water down into the pump... let this sit for a bit and then try to work the pump... also make sure that the check valve at the bottom is seating correctly...it will not pump air is that is not seating...
If water does not get the pump working sometimes Vaseline will soften the diaphragm and the seals up so that they will work again...to get the pump apart you will need to just pull it apart very hard or the top will twist off...
Any more questions or comments, please get back to me..
heatman101
Posted on Mar 26, 2011
How do i prime my troy built 2550 psi pump for the soap?
You have to use a low pressure nozzle ( usually black with very large spray opening) With the low pressure nozzle siphons your detergent in with the spray water . If you are using a high pressure nozzle the soap will not prime.
Oct 26, 2014 | Garden
I just got a Dewalt DXPW 3425 do they have a less powerful spray tip than 40*. Or is there a way to adjust the spray to a much lower output for more delicate deck woods? Thanks Mike in Oregon
Tips are described with two numbers. There is the "size" in gallons per minute and the spray angle in degrees. If you increase the nozzle size the pump sprays the same amount of water ( they are positive displacement pumps) but it will come out at a lower pressure. If you increase the spray angle you decrease the impact pressure over a wider area. A zero degree nozzle has the greatest impact on the smallest area. The largest spray angle is typically 40 degrees and has the "softest" impact. There are lots of nozzle charts online that will tell you the pressure output at various sizes and gallons per minute. Usually paint supply stores have nozzles and can help you get the size you want.
Another way to decrease the power of the spray tip is to simply hold it farther away from the target. The pressure decreases by the square of the distance. ( moving the tip away a little decreases the impact a lot) Experience helps with this technique. Start with the tip a foot away and slowly move it closer to get the maximum cleaning with the minimum damage to the deck. You have to be careful or a momentary lapse of concentration can lift the grain of the wood in a second. The nozzle size is much more fail safe.
Going to a larger nozzle size and wider angle is better than adjusting the bypass valve.
Oct 09, 2014 | Garden
Karcher puzzi 100 not spraying
blocked pressure hose or blocked nozzle at the end of the wand
it is controlled by a pressure relief regulator which quite often plays up.
Jul 19, 2012 | Garden
GX 08 spray gun problem
drain your system of pressure. remove your air cap and nozzle from the gun. slowly increase fluid pressure till it comes out of gun. this will clean out debri from gun. reduce pressure so you don't wast anymore fluid.
clean nozzle properly / completely
clean aircap. properly / completely
inspect needle tip for abnormal wear.
if cleaned properly you will find your gun works much better.
Oct 17, 2009 | Wagner GX08 Airless Spray Gun
Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Sep 24, 2009 | Briggs & Stratton Pressure Washer...
Power washer problem no pump action
sounds like nozzle is blocked.small bits of grit jam nozzle unscrew and make sure its clear turn water on and pull trigger to see if gun trigger works,then refit nozzle check again for spray.if clear start up and try out.if no go then pump probably needs cleaning and relubing seals.
Apr 20, 2009 | Comet Garden
Pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Apr 05, 2009 | Garden
70,000 BTU Ready Heater
If...the air pump pressure is right, the ignitor glows, the fuel is hitting the ignitor, then the unit will have combustion......unless.....
  1. there is an air leak on the pressure line
  2. there is a vacuum leak on the fuel line
  3. there is a leak at the nozzle adapter
  4. there is a restriction either in the nozzle or the fuel filter
  5. the nozzle is worn and is spraying fuel rather than fogging fuel
Feb 09, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
