Question about Audio Technica ATR4600 Microphone
I bouth an Audio-Technica ATR4600 computer microphone. But when I plug it into my laptop, my laptop does not acknowledge that anything has been plugged in. Other microphones work fine with my laptop. The Audio-Technica did not come with ANY instructions, manual, FAQ's... nothing! Is th product broken, or am I missing something?
Its probably broken test it in the store
Posted on Apr 25, 2011
My windows laptop does not detect the mic when i plug it in. it used to, and i know that the mic works
If using windows 7 go to sounds then properties then go to microphone than make sure enable after that test levels
Oct 14, 2013 | Audio Technica Audio-Technica ATR-20...
Connection
if it plugs into the line in or mic in using the 3.5 mm plug then no, the mic won't need a driver. Your playback and recording devices on your computer DO need drivers. Sounds like a computer config issue to me. Could be a few different things
I just bought an audio technica at2020 cardioid condenser mic its the 20 series and i cant figure out how to get it to work on my toshiba laptop
Unlike 'Dynamic' microphones all condenser microphones require some sort of power supply to make them work. Sometimes this can be by way of an internal battery but many of them work on an external 'phantom' power supply.
I am not familiar with the exact model number you quote but AT make 2 types of AT2020 condenser microphone.
1) If your AT microphone is fitted with a USB plug then you can connect it directly to the USB socket on your computer, which will provide it with the power that it needs to make it work. The USB bus should automatically recognise the microphone and allocate an audio channel to it but you may still have to select this device as your input source in your recording program. How you do this will differ from one program to another.
2) However if the microphone is fitted with a standard jack-plug then it will not work by you just plugging it into your computer microphone input socket as this is not powered. You will need a separate 48volt DC power supply to power the microphone.
You will almost certainly also need some sort of microphone pre-amplifier to match the output voltage and impedance (electrical resistance) of the microphone to the levels required by your audio input socket on your computer.
Probably the best way to achieve both of these requirements at lowest cost would be to purchase a small audio mixer with a phantom power option such as the Phonic AM220 http://cpc.farnell.com/phonic/am220/mixing-console-am220/dp/DP29303
WARNING - most audio mixers only have one on/off switch for phantom, power - thus the power is either on or off for ALL channels. Some other devices - like radio microphones, keyboards and electric guitars may be damaged by having 48v dc current supplied to them
Here is a link to the technical specs sheet for the AT2020 http://www.audio-technica.com/cms/resource_library/literature/49f63e6efc082082/at2020_english.pdf
More information is available here http://www.dolphinmusic.co.uk/article/40-why-do-i-need-a-microphone-preamp-.html
Jan 28, 2011 | Audio Technica Audio-Technica AT2020 -...
Will phantom power damage my audio technica DR-VX1 microphones?
No it will not. The reason for the word phantom is that it does not affect microphones that don't need it (apart from some types of ribbon mics)
Jan 04, 2011 | Audio Technica Audio-Technica DR-VX1...
I dropped the audio technica at2020 mic and when i record it doesn't pick anything
Most likely it could be two things either a connection is not getting current anymore. my 2020s have went through hell and no problems. or the other suggestion is that your phantom power is not being sent from your preamp to the microphone (not to make you feel stupid, just a reoccuring problem on this board.)
Good Luck, Cody J.
Dec 17, 2010 | Audio Technica Audio-Technica AT2020 -...
Audio technica microphone atm33a socket detached
Unfortunately you will have to contact them here:http://www.audio-technica.com/cms/site/74a0c4b691ac33ae/index.html as they don't seem to have that document listed on their site.
Jan 10, 2010 | Audio Technica Audio-Technica ATM33a...
Audio technica at 4040 constant ground hum noise
you can test the cable from connection to connection for continuity from end to end. There should be no resistance( a complete short) If the cable is good, there is a bad or broken connection inside the mic. Good Luck
Jun 23, 2007 | Audio Technica Audio-Technica AT4040...
Audio Technica ATR4600 Microphone Logo
96 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Morne Olivier
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
