Question about Motorola Mobility ROKR E1 Cellular Phone
Hello. I have a motorola Rokr E1 and I can no longer text message, add phone numbers to my phone book or even change my alarm clock settings. Anything that involves me entering text into a given field freezes my phone. It all started while I was in the middle of typing a text message. My phone froze in the middle of it and shut off. I reset the phone and now everytime I get to an area wherein text input is required and the cursor is flashing, I press a button and it freezes. I have to take the battery out to get it to shut off. I have not dropped the phone and I have done the master reset, which did nothing. The phone works otherwise which makes me think this is some sort of software error and not physical damage and it is physically undamaged
5 Suggested Answers
  • 167 Answers
SOURCE: text freezing motorola v550
motorola phone freez in txt massages
press menu
select setting
go to initial set-up
MASTER CLEAR your phone
your phone ask for your security code
the deafault of security code of motorola is (000000)
but some people change it.
enter your security code. and select ok/yes.
take note: your phone file will be lost'
such as pics., tones, and videos.
after master clear done..
do the same procedure
and select the MASTER RESET.
Posted on Jan 09, 2008
SOURCE: Razor Phone Freezing
I have had a lot of razor phones and they are good about sending you new ones when you have technical problems. I got my last one within a day from calling, and then you just send them back your old one. That could just be a glitch, they are good phones, but seem to have a lot of those.
Posted on Mar 28, 2008
  • 3100 Answers
Mobile Phone and accessories
    Verified Fixya Pro
    SOURCE: how do i set up my connections to let me have wifi on my motorola q9m wht do i suppose to type in on my connection set area. i dont know the settings.
    There is no WiFi on the Q9m. As far as your MMS settings. Who is your service provider? If it is Verizon they should already be on your phone. If you have another service provider, you may have to have them send the settings over the air via a network update.
    ##DATA# might get you into the menu to update but I can't be sure since I don't know what software is currently on the phone.
    Motorola Support
    Posted on Sep 23, 2014
    • 3 Answers
    SOURCE: how do I do a factory reset on my boost motorola android phone, I don't remember my passcode for the swipe thing to get into my phone so I can factory reset it. It is a boost Motorola android? the ba
    Seems that you will have to take it to a proper phone shop. They can try to restore it there, but if not, they may have to send it away. There is nothing you personally can do without your code. Hope that this helps and good luck
    Posted on Dec 23, 2014
    I can't send messages
    for sending text messages :
    1.go to your message settings and check the message center number to see if it is correct
    2. call to your network operator customer care
    3. request the message center number...
    4.note it down
    5. go to message settings>message center number
    6. insert the number which is noted by you and save it
    this solves your messaging problem ...
    Good luck
    Nov 09, 2010 | Motorola Mobility ROKR E8 Cellular Phone
    How do i reformat motorola e1 rokr? im having problems with sending txt messages it hangs up
    you need p2k tools and flash file for your motorola rokr e1. go to and download this file or email me at for assistance
    Apr 01, 2010 | Motorola Mobility SLVR L7 Cellular Phone
    Motorola rokr model cell phone - I can't figure out how to turn off auto text when creating sms text messages.
    go to message>new message>new short message>press menu>click entry setup>and change primary setup to tap extended
    Mar 15, 2010 | Motorola Mobility ROKR E1 Cellular Phone
    Cnt unlock or reset mater code on the motorola rokr for metro pcs
    Here is how to do a master clear or master reset on most Motorola cell phones.
    If you have a Motorola cell phone and want to clear all numbers out of the address book and reset factory settings you need to use the master reset function.
    First you need to go to the main menu, settings, setup, master clear option and enter six zeroes, 0000000
    This works on most phones. If that does not work call your carrier's technical support
    by dialing 611.
    Master Reset Codes and Master Clear For Motorola Cellular Phones.
    var dc_AdLinkColor = 'blue' ; var dc_PublisherID = 90892 ;
    Sep 09, 2009 | Motorola Mobility ROKR E1 Cellular Phone
    Motorola ROKR E8 Alarm and Synchronizing Problems
    U can flash it, that way at least u'll get rid of the alarm
    Dec 26, 2008 | Motorola Mobility ROKR E8 Cellular Phone
    Cant recieve calls suddenly, but able to call others
    if you're with rogers, then you should turn off name display
    Jun 27, 2008 | Motorola Mobility ROKR E6 Smartphone
    I believe its the bands that are not set up correct on the device. Make sure that its set on automatic as opposed to dualband. Menus on motorola phones can be split by 850/1900 and 900/1800. Just check the network settings, the phone is quad band and it should work. Only reason it wouldnt work, is if it was defective.
    Jan 22, 2008 | Motorola Mobility ROKR E1 Cellular Phone
    Motorola E815 alarm quit working
    I've had a similar problem with alarms not going off.  In my case, it was caused by receiving a text message that was unanswered between the time that I set the alarm, and the time that it was supposed to go off.  Try reading all your text messages, deleting all messages, and then take the battery out and put it back in after a few minutes.  The last part is to reset any caching, but the first two steps followed by a turn off/turn on should also do the trick.
    Oct 08, 2007 | Motorola Mobility E815
    Motorola Mobility ROKR E1 Cellular Phone Logo
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
