Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
The hdd is not recognized by the pc, evrytime i plug in the hdd it ask me to formated
  • Donald Tucker Mar 25, 2011
    Did you buy a blank hard drive? If so you can enter bios and auto detect the drive and see if it needs to be formatted. Since the drive is blank you don't need to worry about losing any saved information.
  • 24 Answers
Are you using EXTERNAL HARD DRIVE, which means the hard drive is in a box, and you connect it to computer with USB cable? If so, do the following
1. Try to plug and unplug and plug USB cable at the port on computer. 2. While plugged in, try to shake the plug a little. 3. Try to plug the USB cable to USB port at the back of the PC case, not the port at the front 4. Check the usb cable, buy a new one, or borrow one (its cheap) 5. Still does work? bring it to Customer service, there must be an error on the box itself.
Posted on Mar 25, 2011
Trying to start computer with SSD and HDD, NOT happening!
Have you tried going into the bios to see if the ssd is recognized and have the computer boot from the ssd So connect the drive and put your windows disk in and install to the ssd During the install it will scan for drives and ask which drive you want to install on Make sure you check the boot options in the bios to allow the connect drive
Nov 23, 2012 | Computers & Internet
Format issues on Seagate 9SF2A8-500
If you want to format it for PC, go to partition manager and the HDD should show there, if not use a partition manager program to select the HDD. Now you should format it to NTFS for windows or FAT32 if you want to use it for windows and mac.
Oct 27, 2012 | Computers & Internet
My usb ports on my laptop only recognizes my phone and mp3 player and not my external hdd, it tells me to format the plug and play external hdd. It does not do this in all my usb ports though
Maybe the external hard drive is to large to be recognized by your computer. Some computers won't recognize real large external drives.
Another problem could be that your external hard drive does not support Windows 7.
May 20, 2012 | Acer Computers & Internet
I get an error that says HDD init failed connect to pc when my computer doesn't recognize it so I cannot format the HDD?
The main hd is unpluged. Unscrew the screws nezt to battery. Slide left the back cover just like the battery cover and plug the hd back in. piece of cake!
May 04, 2010 | Gateway Photo Jukebox GCM-4 MP3 Player
PC doesn't recognize Passport after Mac use
you must choose the format you wanna run on your hdd.mac and pc aren't the same.
Apr 16, 2010 | Western Digital WD Passport 250GB Portable...
Blanking PC
1. Extract the HDD 2. Put it in any HDD USB case. Buy it in the nearest PC shop - 20 bucks worth 3. Connect the case with HDD to another PC and format it. 4. Put HDD back to laptop.
There are no another way to blank HDD. Cheers.
Sep 20, 2009 | Acer Aspire 4520-5582 Notebook
How do i format my novatech B750
Just use a bootable CD and boot up with it, you'll come to a stage where you're asked to format your HDD.Or bootable flopy disk, when in command prompts you type format e: and press enter Or you could remove the HDD and use a external USB casing and use other PC to Quick format your HDD. Note:If you're trying to format your Laptop HDD, I will suggest that you get the all driver information for the hardwares before installing a new operating system. Because when new fresh installation is done you will be asked for the drivers for CD-rom, key board etc...
Nov 13, 2008 | Computers & Internet
HDD wont get formatted
Hi, maybe the easiest way for you to format this drive would be if you could attach it as a secondary drive in a pc that is currently working and then try formatting it in the desired format from within windows. Windows will recognize a drive it only needs to format it in order to access it for data storage. You may need to change the jumper setting to slave on the HDD before you plug it in.
If you need any help with this just let me know.
SeaJade
Jan 26, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
PC won't recognize external usb HDD
You may not have installed the HDD correctly in the case... I had the same problem with my Thecus N1050 enclosure, the green power light on the enclosure would come on and the drive would spin up but my PC would not see the HDD!!??... I thought, becuase i could hear the drive spinning that i had it installed correctly but this wasn't the case, when i removed the enclosure again and FIRMLY pushed the HDD into the connector (all the way in) and connected it back up to my PC, it recognised it instantly. Hope this helps!
Jul 25, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
125 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
