Question about RCA RP5010 Digital Voice Recorder
Olmpus Digital Wave Machine Files
I saw your recent answer regarding an Olympus recorder and thought I would try this one on you. Thanks for your consideration.
I recently purchased a digital recorder and make recordings at our family reunion. Today I transferred those files to the computer and they are stored in some form under the software. I can listen to the file on the software program but I would now like to make a copy of these files and send them to my other relatives that were involved in the conversation.
I can't seem to find a way of accessing those files. I can see them listed when I start the program, but I assume that I should be able to find them someother way to make an attachment, since there is no way that I can do anything from the program (at least from my point of view) other than listen to them on my own computer using the program.
How do I find these files to make a copy.
Thanks,
  • dadlarson Aug 04, 2008
    The soluin was perfect and I had not noticed the folder titled Digital Wave Machine nestled between my other folders. I went into the folder, attached a file, sent it to myself, and voila, it was a perfect FixYa.
    Your solution was perfect, and I thank you, but the fact is that your follow up comments really set the bar rather high for me. You suggested that I link the files to my IPOD (I am retired and got my first IPOD three months ago). In addition, you suggested I convert all of the wav files to MP3. You have truly challenged me to start learning about files, something I assure you I have never dealth with in my life.
    Bottom line, you solved my problem and I truly thank you.
    dadlarson
  • RCA Master
  • 2,794 Answers
In the program folders of your computer is a folder called Olympus. In that folder, there are four folders for audio files. They correspond to the audio folders you have on you voice recorder. Each file is save with a time a date stamped file name. The files should be saved as wavetable file or wav. These files can be played using windows media player and can be emailed under most cases as well provided the file size for the attachment is acceptable to the recipients e-mail address.
Usually what I have to do is link the folders using ITues. Then files can be synched and converted to mpeg3. That way if someone wants to listen to them on an Ipod or any other mp3 player there easy to transport.
Let me know what you find.
Tim
Posted on Aug 04, 2008
Failure to install Olympus VN 600PC
Yes, you need a vista compatible Digital Wave Player software version, file eng_2000_xp.zip
available here:
http://www.olympus.co.uk/consumer/2590_software.cfm?category=8&productgroup=347&product=420&os=10&result=
Install the DWP software first, then plug the recorder in and install drivers.
Jul 02, 2009 | Olympus VN-1000 Digital Voice Recorder
Transfering a stored PC recording
The recordings simply reside on your pc, but not in the "Digital Wave Player" software. The software is merely there to let you play the recordings, probably because they are not in a native Windows format.
If the recordings are "Wave, .wav" files as suggested by the software, then simply locate the files you want to put on disc... I am guessing you want to burn on cd.
Then, use a burning program such as Nero to add these files and burn to disc.
If you don't have Nero, then you would need to figure out what type of burning software your machine has installed and go from there.
Mar 18, 2009 | Olympus VN-2100PC Digital Voice Recorder
Reinstalled software and the old files are there but they do not
copy them to my documents/digital wave player/message/folder a
they will show up there
Mar 11, 2009 | Olympus VN-2100PC Digital Voice Recorder
CANNOT TRANSFER AUDIO FILES FROM WS-100 OLYMPUS VOICE RECORDER TO PC (Windows XP)
I wrote this for the Olympus VN-3100PC although it may work with this device as well.
Try this:
This problem can typically be solved by unplugging the device from your computer's USB port and plugging it in to another USB port on the same computer.
Also be sure you have Olympus Digital Wave Player installed and open with your Transfer Options set to Auto Transfer. To do this, follow the steps below:
Open Digital Wave Player > select Transfer from the menu > select Transfer Options > under Auto Transfer, check the box which reads "Transfer all audio files after detecting Recorder."
Mar 04, 2009 | Olympus WS-100 Digital Voice Recorder
Olympus VN-3100 software
Call tech support at Olympus. They maybe able to help you with a special link.
Feb 06, 2009 | Olympus VN-3100PC Digital Voice Recorder
How do I transfer files to computer from Olympus VN-3100PC?
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. Browse to the location on your computer where you downloaded and saved the Digital Wave Player files from Step 3
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Nov 29, 2008 | Olympus VN-3100PC Digital Voice Recorder
DRIVER SOFTWARE
Download the digital player from this link. http://www.olympusamerica.com/files/digitalwaveplayer.zip
Plug in the voice recorder again and it should now find the software automatically through window's automatic hardware finder wizard.
In all fairness, Beerlal posted this solution but to a slightly different question.
Hope this helps
Oct 24, 2008 | Olympus VN-4100PC Digital Voice Recorder
Unable to download files onto DSS Player on the PC
I think you have Version 7 of the software , try to upgrade it to version 7.1.0  download the update patch from Olympus website  ;
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1276&os=w
hope this will solve the problem
Sep 10, 2008 | Olympus DS-30 Digital Voice Recorder
Driver for VN-1100-PC
Olympus has provided new software for VN recorders to used with VISTA plus a few updates.
Uninstall the Digital Wave Player
Uninstall the recorder in device manager
Download and install the New digital wave player,
then go to Olympus america and download all VISTA related updates. Once you have installed and updated the Digital Wave Player software, plug in the recorder and Windows will use the Olympus Driver (not digitally signed) to install and the Digital Wave player software will open automatically.
Feb 22, 2008 | Olympus DS-2300 Digital Voice Recorder
I cant download any files
Hi guys
I had the same problem with Windows vista and here is how I got my VN-4100PC to work.
1. Download and install digital wave player file from: http://www.olympusamerica.com/files/digitalwaveplayer.zip
2. Vista updates can be found on: http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1291&os=w
This do the trick!
K
Oct 04, 2007 | Olympus VN-2100PC Digital Voice Recorder
RCA RP5010 Digital Voice Recorder Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
