Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
The suction is too strong and the vacuum "sticks"
SOURCE: Suction
i can think of 2 things first do"s the clutch{ if it has one}work or is it in the off postion you can test this by lying the dyson on it"s side and turning it on but remember to push down on the bottom as if you was hoovering if the brush spins then its ok if it dosen" move then replace it second take the bucket off and remove the bin tune it upside down and see if it is blocked if so the best way to clean it is to sit it upside down and put a hose pipe in then just wait till the water runs clean hope this is some use to you
Posted on May 22, 2007
  • 4 Answers
SOURCE: Suction
Might be the hepa filter needs cleaning? This is located in the housing on the side of the cleaner at the bottom (see your manual to find it). It is a big spongy ring which Dyson say you should remove once a month and wash in warm water. Dry off and replace in cleaner when completely dry. I've found this works and the suction is like that of a new machine!
Posted on Dec 19, 2007
SOURCE: no suction with Eureka Boss Pro Lightweight Bagless Upright, 411A
I checked the vacuum hose to see if there was a clog. 1st, disconnect the hose from the unit so you have access to both ends. Now, place a marble or other ball in one of the hose and see if it will make it all the way through. I found a major "hairball" about 8-10 in down from the vacuum end. I took a metal cloths hanger and bent it in half and did a "roto-rooter operation. It took about 30 minutes, but now it runs like new. I hope this works for you.
Posted on Nov 17, 2008
SOURCE: Suction loss when handle is tipped back to clean carpet
Ours did the same thing. I cleaned the filter and canister thoroughly. It needed to be cleaned, but that didn't fix the problem. I removed the plate under the carpet brush bar (three quarter-turn screws) and removed all hair, lint and threads from the rollers and brush. THEN my husband found the real problem: a piece of flexible hose running from the head into the hose (on the left side when behind the vacuum) was completely clogged. The hose will detach from the head, and you can remove debris. Once that clog was removed, the hose easily re-attaches, and we had great suction once again.
Posted on Feb 14, 2009
  • 59 Answers
SOURCE: bissel proheat 2x main suction problems
most likely your jets are clogged up. take off the clear water container and you will see the two jets that spray water. they are red and flat. you will need to squeeze each on together and pull it up. then you can clean it. after you clean it, pull the trigger while the unit is running, should flush the rest of the trash in the line. you might have to clean it a couple of times.
make sure the flap door in the diveter, in the clear cover, is moving to floor cleaning. this does break sometimes.
david
Posted on May 25, 2009
Mt dyson has too much suction
Hi there, it's Jack at Dyson.
I'm sorry to hear you feel your DC40 has too much suction. This sounds unusual, and in order to help you resolve things we would need to take some further details about your machine, and the particular flooring type you're having difficulty with.
When you have your machine to hand, please call us directly so we can talk you through some simple troubleshooting checks to make sure everything is correct with your DC40. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Sep 27, 2014 | Dyson DC40 Animal Upright Vacuum -...
Dyson cannot be pushed - too much suction
clean the sole plate of black residue then rub some baby powder on it to make it slide easy..
Apr 01, 2013 | Dyson Vacuums
How do I remove a hardwood floor polish safely from a laminate floor
www.hard-wood-floor-cleaners.com
and select the best chemicals and use for your hardwood polish laminate flooring.
God bless you
Aug 02, 2012 | Vacuums
I am not getting any suction from the floor portion of the vacuum. Suction is strong with the wand. I have checked all removable areas of the vacuum. Can't find any obstructions.
Hi Todd,
Apologies for our delayed response. It appears your inquiry was submitted sometime ago and hopefully you have you have been able to resolve the issue in the meantime. However, if you need further assistance, based on the details you provided we would appreciate the opportunity to speak to you directly. Please call us at 1-866-693-9766 (US) or 0800 298 0298 (UK).
Best wishes,
Jessica
Oct 09, 2011 | Dyson DC14 All Floors Upright Vacuum...
Is it safe to use the Shark Steam Mop on laminate floors?
You have to consult the laminate flooring manufacturer for the flooring that you have but usually it voids the warranty.
Jan 23, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Dyson dc14 has lost suction
Down on the lower right hand side of the vacuum, when you're behind it, there is a little 'J' shaped piece with a purple clip on it. Tilt the vacuum up and unclip this. Usually, people who have these amazing vacuums will accidently **** up things like lollipop sticks/pens/paperclips/etc. that don't bend... and will stay in this piece. This should solve your problem.
Sep 05, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Apr 11, 2009 | Dyson DC14 All floors Bagless Upright...
Shark Floor Cleaner streaking on pergo laminate floor
Start with a clean pad. A dirty pad wil spread the wet residue around and strek the pergo. After steaming use a clean microfiber dust mop to buff the pergo. It will dry and shine yur laminate.
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
166 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
