Question about Ovens
Easy off I used easy off and turned the self cleaning on now my oven won't turn on or work nothing? what can I do?
  • 117 Answers
You can't use easy off and do the self clean, but I want you to explain what is wrong with your oven, if it is not turn on or turn on but no heat, if it is digital or not, what brand and model number??
Posted on Aug 04, 2008
What should I do to clean my oven?
You can use Easy Off 'Fume Free' oven cleaner on a self-cleaning oven, if you want to manually clean it, but do not use it with the self-cleaning cycle.
Apr 26, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
I have a frigidaire self clean electric oven but I am not sure how to operate the self clean
lock the oven door lever to self clean side, and turn it on self clean - it should shut off automatically when cycle is complete.
BE CERTAIN NOTHING IS IN THE OVEN WHEN YOU TURN IT ON AS IT LOCKS SHUT!
ALSO CHECK TO BE SURE NO ONE USED CHIMERICAL CLEANER IN IT PRIOR -- DANGEROUS FUMES WOULD BE A RESULT
Best regards
Ck
Aug 18, 2011 | Frigidaire Ovens
My husband sprayed the non-fume Easy-Off oven spray into our KitchenAid self-cleaning oven. Then turned IT ON TO CLEAN! It was on for about 1/2 hour. There are instructions all over the can NOT to turn...
The best thing to do is with a cold oven, go ahead and use the Easy-Off non fume again and wait 2 hours. This should remove the original grease as well as the left over Easy Off from the 1st application.
Jun 05, 2011 | Ovens
I have an admiral self-cleaning oven in my apartment and do not know how to turn it on! I have locked the oven and pressed the clean button, but nothing happens. Help!
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Apr 23, 2011 | Ovens
When i turn on the self clean i get an F1 error code after a couple minutes. I have not tried to fix it but i have fliped the breaker off and back on. Nothing helps
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Aug 22, 2010 | Whirlpool RBS305PDS Electric Single Oven
My oven broiler does not seem to be working-I turned it on broil for about 15 minutes - no heat, nothing. On normal bake, it takes about a half hour to heat the oven to 350 degrees - my old stove took...
check the bake (lower) element, mine just went out. It was easy to spot the problem once I pulled the element out, the wire had burnt off the end. Please remember to turn the power off first.
Nov 28, 2009 | Whirlpool RBS275PD Electric Single Oven
How to self clean oven
If it has a self clean feature, you can set that feature to self clean. If it does not, you can use Easy Off oven cleaner. You should turn the breaker off to the oven first. Lay newspaper on the floor around the oven to catch drips and spray the entire oven. Let it sit for a few hours and use your vent hood to elimnate fumes, then wipe out with an old cloth. Hope this helps and answers your question. Ella
Aug 18, 2009 | Ovens
Self cleaning
Never use spray cleaners in a self clean oven it will void your warranty and possibly ruin the oven. it sounds like what may have happened is the fumes from the spray ignited inside the oven and may have blown out the pilot light if your using gas.
or maybe replace the thermocouple. sorry, hope that helps.
Aug 03, 2008 | Kenmore 42161 / 42169 Electric Single Oven
GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Feb 06, 2008 | Ovens
Ovens Logo
107 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you an Oven Expert? Answer questions, earn points and help others
