Question about Lexmark P4350 All-In-One InkJet Printer
Lexmark x4550 When I try to print a page border, the bottom line is missing....any ideas please....
  • 300 Answers
That usually means that the document with the border has margins that are outside the printable range of the printer. Try temporarily setting the margins to 1" all the way around and try again. If that solves the issue then you can decrease the margin to your desired setting.
Thanks
Posted on Aug 09, 2008
I have a Lexmark x543 printer and when I print a document from MS Publisher, there is a small border around the edge of the doc. I have change my printer settings to Whole Page printing but it does not...
try to print a test page .. if u get the lining there then its a problem with the printer drum .. u might need to get it replaced .. if not then its an issue with the settings .. you can also try to reinstall the drivers in that case.,
Oct 21, 2010 | Lexmark T632 Laser Printer
Bottom of borders missing
Check to see if your paper setting is A4 instead of 8 1/2 x 11. If so change it.
Jul 04, 2010 | Dell 924 All-in-One InkJet Printer
Hi, i have a lexmark x4550. The pick up roller (the roller that grabs the paper and feeds it into the printer to get printed on), is not working, at least one of them isnt (there are two i think,,, but on...
Try the following: take an A4 sheet of paper and glue a 2 - inch strip of sanding paper onto the top of the sheet (full width of the page). sanding paper should be about 120 grain.
Now feed the page with the sand paper first (rough surface on top) into the paper inlet. grab and hold the paper, then press paper feed or send a print job. The printer tries to feed you special sheet, but you won't let go. This will sand off the gunk from you feed rollers and give a bit of rough surface to the rubber. Repeat if needed, it should cure the problem.
This works if the problem is the roller surface, it will not fix a problem with misalignment or a missing/broken spring in the feed roller mechanism.
regards, the perfessa
Aug 23, 2009 | Lexmark X4550 Multifunction Wireless Color...
Printing problem in Microsoft Word 2003
Does the bottom border show up in Print Preview? Some printers will not print the full page, to include the border if it is too close to the papers edge. If you adjust the border to be further away from the pages edge, it should print. Instead of applying a page border, you may have to draw a border using a rectangle shape and apply the desired line style.
You can also try to adjust the border margin to measure from "edge of page" instead of measure from "text". This setting is on the options button located on the page border tab under the Borders and Shading window. This may allow you to adjust the margin enough to be able to print the border.
Apr 09, 2009 | Microsoft Word 2003 for PC
No bottom page border
Apr 06, 2009 | Microsoft Office Professional 2007 Full...
HELP
You may need to adjust your margins so that the bottom border shows. In other words, go to file> page layout>margins and adjust the bottom margin to a lower number, the check print preview.
If that does not work, try checking the border settings. Perhaps line weight has been set to 0 or color has been set to white or no color for the bottom, causing it to be invisible.
May 29, 2008 | Microsoft Office Computers & Internet
Lexmark X1150 only prints first page
I have an x4550, running windows vista basic on an hp dv6000t notebook. i had the same problem. i contacted online lexmark tech and here's the solution that worked for me, thanks to help from lexmark (transcript of chat):
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. It should be set to the default to "LEMF." Change it to "Lexmark." Under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
Nov 19, 2007 | Lexmark X1150 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
159 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
