When i try to record it comes up error e4 54037380 toshiba d-vr16sb
  • Anonymous Oct 18, 2008
    I had the same problem, but only when I use DVD+R's. Worse yet, I could record stuff on them, I just couldn't finalize them so anything on those discs can't ever be copied from them AND I can only play them in my recorder...
    Using DVD-R's from now on avoids the problem, but I don't know what I can do about the +R's that I can't edit/finalize...
  • 4 Answers
This seems to be a very common problem with DVD recorders.
If a DVD Lens cleaner (with brushes) fails to fix the problem, then it could be that you have
grease particles on the lens. Do the following:
Note. If unit is still under warranty, you may nullify this by opening unit up
You will need:
Screwdrivers as necessary
Cotton Bud sticks (also known as Q-tips)
Isoproponal/Isopropyl Alcohol (small bottle comes with some CD/DVD cleaners)
Compressed Air cannister/aerosol
1. After disconnecting unit, leave standing for 15 minutes
2. Unscrew lid and remove
3. Carefully remove DVD lens cover
4. Blast whole area with compressed air to remove dust
5. Dip one end of cotton bud in Isoproponal, and very carefully wipe DVD lens (just one wipe
should do.)
6. Now wipe lens with dry end of cotton bud, and leave a few seconds to dry
7. Carefully replace DVD lens cover (watch out for ribbon cables)
8. Replace Lid
9. Reconnect, switch on and test
After I'd tried every other way possible, this method finally worked for me!
Posted on Nov 11, 2009
HOW do I clear Toshiba DVD recorder error E 4 54040901
You can unplug it from the wall and it should set the dvd player back to factory specs. If there error still comes up, you can try a cleaner disk. If still having issue can switch types of disk. If using + try the - or vive versa. Last thing to try would be the speed. There is S, SL and SLP. Change it and see if will work for you.
Feb 06, 2016 | Toshiba Televison & Video
Error message
ERR-15 hard drive error. need to replace hard drive also it would be easier if you just take it in a repair shop
Sep 10, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba D-VR16SB Gets error code: e4 54037380
This DVD combo will only read DVD-RW and DVD-R format discs the manual says that Verbatim DVD-RW 2X are the best to use also TDK DVD-R
Apr 25, 2010 | Televison & Video
I want to unlock my Toshiba D-VR16SB to make it multi region
have you googled it? try this website it might have what you need(michaeldvd,com.au) select under articles, then regional code enhancements, now this is just something i found on google so i can not certify the information found there is safe. good luck.
Dec 31, 2009 | Televison & Video
Trying to dubb video from hard drive to dvd-r and error 14 keeps coming up on the screen. thanks sylvie
Well, by now I'm sure that you know to clear the code, you press the "Display" button a few times. As for getting the Toshiba to actually burn a DVD, I'm not certain that I can help you there, as I've run into problems burning stuff. Unfortunately, it doesn't burn all the time, even if you use the same routine as the last successful burn.
Sep 26, 2009 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Error 14
Check to see if you are using 16X media. If so contact Toshiba for a fireware upgrade. If that is not the problem try cleaning the disc and cleaning the unit with a DVD Laser Lens cleaner. Then try again.
Mar 30, 2008 | Toshiba DR4 DVD Recorder
Problems finalizing discs
Check to see if you are using 16x media.  If you are you need to get a firmware upgrade from Toshiba.  Contact their support number listed inside of the manual.  They will ship you a dvd to insert into the unit.
Nov 02, 2006 | Toshiba DR4 DVD Recorder
Televison & Video Logo
375 people viewed this question
Top Televison & Video Experts
