Question about GE PDS18SBM Bottom Freezer Refrigerator
How do I switch the door from right to left opening on a GE Profile PDS18SB
freetek
  • 5568 Answers
SOURCE: Side by side GE profile freezer door pops open
It almost sounds as if the magnetic gaskets aren't as they should be.
Most all combination units have a path between the two parts of them to allow circulation of air, the amount or rato of which, is controlled by an adjustment that really just makes a duct larger or smaller so temperatures can be balanced to fall within the range needed by each.
Check to see if, when closed slowly, the gasket surfaces are parallel to the steel of the housing.
If not, there is normally a little adjustment possible at the hinge mountings.
Posted on Aug 24, 2008
SOURCE: side by side GE profile
I have a GE side by side refrigerater freezer. I thas the diagnostic center on the freezer door. The de symbol started flashing afew days ago and the refridgerater side isn't getting cold. the fan is on and doen't seem to cut off, If someone could steer me in the right direction I would appreciate it.
Posted on Nov 09, 2008
erpaalai
  • 999 Answers
SOURCE: Ge Profile Stainless Steel Refrigerator panel replacement
You can replace the doors but you will think you bought a new frig when you see what they cost. Most come as an assembly and are very expensive.
Eric
Posted on Jun 29, 2009
sawdust46694
  • 398 Answers
SOURCE: GE Profile Arctica freezer door not sealing properly.
Loosen the hinges on top of the door left side, . lift or lower the door till it is level with the top of the unit. now do the other door. now look at the line between both doors, and compare the gap at the top and bottom . adjust once more time if needed. clean the metal and the magnet with windex then put weson oil on a clean towel and wipe all the way around each door.. hope this was helpfull to you.... Sawdust46
Posted on Aug 11, 2009
aasc
  • 1606 Answers
SOURCE: GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Posted on Sep 30, 2009
Replaced rollers on dryer put back together door closed but keep getting message that it is not closed and wont run?
In order to replace the rollers you had to take off the dryer front. You probably had to unplug the wires to the door switch which if I remember right is in the top left corner of the front panel. Check those connections to the push button switch. If it is not connected, the door will show as open even though it is closed. Or the switch got damaged and is not making contact inside when door is closed. If i remember it is a 3 wire 1 piece plug.It also operates the drum light.
Mar 06, 2015 | GE Profile Harmony DPGT750EC Electric...
I have a new GE Profile dishwasher and granite countertop. How do I attach it so it doesn't tip. I can't use the tabs at the top as the granite is right there. Any help?
Open door and look for removable hole cover along left and right side, several inches down from the top. Use a wood screw to secure the side of the dishwasher to the cabinets there, then replace the hole covers.
Mar 21, 2011 | GE Profile PDW9880NSS Stainless Steel...
I just got a used GE Profile Refridge and would like to change the door from left opening to right side opening. How would I do that?
Hi. Look carefully at the door and check to see that there are buttons on the side of the door opposite of the hinge. Those buttons conceal the alternate set of screw holes for the hinges. If there are no predrilled holes on the other side of the door then it is not reversible.
That said, If you do locate those buttons, unscrew the hinges from the door, have a helper there as the door will be heavy. Once the door is off, remove the hinges, then move them to the opposite side and reattach the door to the fridge. Put those buttons in the new open holes. J.
Jul 30, 2010 | GE Profile Stainless Bottom-Freezer...
The fridge door was left open overnight and doesnt cool
the turbo cool function is for rapid cooling, when first switching on after defrosting or moving unit,it will switch off automatically when near your set temperature.(+5C)
Jun 21, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Oven door after self clean cycle won't unlock
Both the oven" ON " light and " Clean " light will flash when the clean has finished . When the " clean " light flashes , slide the latch handle to the left as far as it will go , then turn the " OVEN SET " knob to " OFF " to open the door.
Mar 26, 2010 | GE Profile JGS968SHSS Gas Kitchen Range
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
"door" appears when selecting bake or broil.
First take the door latch lever and push it to the left with moderate force. This may re-align the switches inside. If that does not correct the problem replace the door latch switch.
Apr 02, 2009 | GE Profile JGBP79 Gas Kitchen Range
OVEN DOOR LIGHT SWITCH
These instructions apply to my GE Profile JBP90 but other brands and models are similar.
1. DISCONNECT THE UNIT FROM ITS ELECTRICAL POWER SOURCE!
CONFIRM POWER IS DISCONNECTED BY OBSERVING DISPLAY GOING DARK
In your case this may mean turning off the 220V double circuit breaker or unplugging the unit cord from its power outlet.
2. Open the oven door
3. Remove the two screws under the front edge of the stove cooktop on the far left and right
4. Gently raise the cooktop 4 or 5 inches and prop it open with a small cardboard box
5. Find the door switch wire and gently pull the switch connector off
6. Remove the switch by squeezing the two metal spring tabs toward the switch and pushing the switch out toward the front
7. Inspect the switch. If its like mine, it may look a little melted and smell burnt.
8. Find a new switch online or at your nearest parts distributer
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=212235
9. Installation is the reverse of above steps.
Good Luck!
Jun 25, 2008 | GE JBP90 Electric Kitchen Range
Oven
do you see a push button on the left or right side of the oven?its the door switch.find that and make sure the wires are ok.
Aug 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE PDS18SBM Bottom Freezer Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
