Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
What ports do i plug into to be able to use a Broad Band internet
    Scholar:
  • 143 Answers
Plug the lan cable from Modem to the Router Wan / Internet port. From Lan port ( Router) you can connect to switch or computer if you have any . Or connect computer via wireless.
That' all
Posted on Mar 25, 2011
How do i find my access point name my broad band t-mobile & im working with windows 7 if any one can help that would to great thanks
Your "access point" means the thing that your computer connects to in order to get on the internet. An "access point" can be the dsl modem, a router or switch inbetween the computer and the internet connection or the point of entry to the internet - depending on what you are using to connect and get on line.
You mentioned you have a broad band connection with t mobile. Is this the T mobile home service link that gives you regular phone service and internet? If so - what is the name of the box your connecting your phone and pc to?
What is the name of the equipment that t mobile gave you to use that broad band link?
Are you using a desktop or a laptop? Wireless connection? or a wired connection with a ethernet cable (looks like a phone cable but a little bigger on the plug end)?
To answer my questions go back to your original problem posted on fixya and use the comment or reply link in blue.
Mar 26, 2011 | Sony Computers & Internet
New cisco Linksey E1000 router will only connect to local internet access, what do you I need to do?
Make sure to plug your broad band connection into the "internet" port or the yellow RJ45 jack on the back of the router. If that is already in place unplug all power connections to your Cable or DSL modem for at least 10 minuets. Then plug the modem back in and power up. Then reconnect your E1000 and wait for the unit to cycle. Then test for internet.
Also make sure to check any firewall software on the computers connection to the unit to make sure they allow or trust the new connection.
The last thing to try is to perform a factory reset on the E1000 and try the connection.
Mar 12, 2011 | Computers & Internet
I got a two day gold pass and a xbox 360 i also got tmobile broad band internet on my pc so how do i get started with xbox live without an adapter or do i need an adapter
Requires a Router/Switch
(2) ethernet cables
Using your PC as the main Internet Provider, connect one cable from the PC's ethernet jack to the WAN jack/port of a router. Next hook up your XBox to one of the wired 1-4 jacks/ports on the same router with the other ethernet cable.
Mar 09, 2011 | Microsoft Xbox 360 Console
How to hook wired router to cable box. What is WAN outlet
all of your computers should get hooked up in ports 1-4 and the WAN port should be hooked up to your broad band router from your internet service provider. so if your first computer is hooked up to port 1 just plug your second into port 2 and every thing will work fine.
I hope this helped.
Thank you,
Norse
May 18, 2010 | D-Link (DVG-2001S) Router (DVG2001S)
How can i connect the router? i got a intellinet 192.168.1.1 there is one wan and 4 ports are there.i have dialog broad band connection.how can i connect it?or iwant to install any software?
This is very easy to do and you should have no problems doing this. The first step to installing it connecting your router to your broad band router through the wan port. All you do it take your Ethernet cable that went from your broad band router to your computer and attach it to your new routers WAN port. next wile your new router is turned off, turn off your broad band router and then turn it back on wile it is booting up turn on your new router this is not always necessary but it will make sure that they sink together properly. And that's it your done just hook up all of your other computers to the remaining ports and they should work with out a problem.
PS. this is just the basics of setting up your router if it has wireless you may want to think about implementing some security measures such as encryption.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Intellinet Active Networking Intellinet...
Can someone please tell me how to connect to the internet so I can send text messages on my psp?
For this you need a broad band connection.Now switch on the psp go to settings go down fully and enter network settings and enter infrastructure mode.There select [New Connection] and you will enter WLAN settings there select scan.While doing this remember to do this switch on the broad band so that the psp will be able track it while scanning.After it finds your WLAN it will show you the SSID,Security and signal strength.Then press 'x' and type the SSID and press the right arrow to continue.Now you mus type the security code if you have one otherwise press none.Then select the address settings to easy or custom and keep going front until you find the sentence 'Press the x button to save settings'.Now you can browse the internet with the connection.But remember to switch on the broad band when you want to browse the internet.
Jan 27, 2010 | Sony PlayStation Portable (PSP) Console
I want to access the internet on two computers using cricket broad band
You have to connect the computers directly through the ethernet ports, then go to network connections in the control panel and click set up home or small office network and then you have to set up the computer with the internet as the host and the other as the guest computer.
Jan 09, 2010 | Computers & Internet
The wireless connection is not connecting
first unpluuge the modem and the router than plug in the internet from the modem to the router where it says internet ,than you install cd in pc restart the pc and plugg the modem and the router back to the outlet in the wall and see if you can read if your router is broad band if not you will not get acces to the internet and if you have the wireless or inbuild internet than you might be able to be online , so make sure if you dont ahve abuild inn use awirelessinternet adapter that goes with the router
Aug 04, 2009 | Belkin Wireless-N Wireless Router with...
I have satellite broad band on the host computer with a lap top via belkin.how do I connect the two computers together as a net work sharing printer internet etc?
Hi and welcome to FixYa,
With the indulgence of jmichelsen4, two ways:
  • a router if the satellite modem uses Ethernet port;
  • a hub or crossover cable if the satellite modem uses USB port on the host computer.
Good luck and Thank you for using FixYa.
Dec 07, 2008 | Computers & Internet
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
