Question about Lite On (SOHW-1633S-03) DVD±RW Dual Layer Burner
Drive does not read or write disk. It spins disks and stops.
  • Lite On Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Mar 25, 2011
All of a sudden my disk and dvd movies will no longer pop up when i put then in the disk holder and push them in nothing happens i can hear the disk spinning for a few seconds and then it stops but nothing...
Insert a disk. Wait for the disk-spinning to stop.
Open "My Computer".
Double-click the icon for the CD/DVD drive, to see if Windows can read anything from the disk.
Jun 25, 2011 | Sony VAIO VGN-FE880E/H Notebook
My notebook suddenly shut down itself, then after i restart, it show select which drive to boot (but no option to let me select). Then i try to reformat it, but it show no harddisk install? i have try...
This means that no "bootable" CD-ROM was loaded into the CD-drive, *AND* that the "bootable" files could *NOT* be read from the disk-drive.
> it show no hard-disk install
Well, it shows that either:
* no electrical power is reaching the disk-drive
* the electronics "underneath" the spinning-part of the disk-drive have failed
* the "spinning" part of the disk-drive is not spinning (dead motor?)
* the disk is spinning, but nothing can be read from the disk-drive.
Try connecting the disk-drive to another computer.
If it is detected, that's good.
If not, then your disk-drive has a BIG problem,
and replacing it (with or without exercising any "warranty'") is your only way to move forward.
Sep 30, 2010 | ASUS A3Ac Notebook
I have a Zip 250 disk that will not read. When I insert the disk in the external disk drive, it will spin and stop a few times and that's it. When I try to access the disk/drive letter via "My Computer",...
If the disk is unreadable this means that the format or the files extensions on it are not readable in the operation system you use..either are damaged or the disk itself is damaged or it wasn't finalized like it should ...If other disks inserted run ok than the disk it is damaged and it is nothing wrong with the drive itself..When it says to insert a disk this means that it is not seeing the disk at all and it sounds like a drive problem ..but if other disks are ok ..than it is just a damaged disk or in a format unreadable ..beware if it a cd unit ..will not read dvd-es..or if it a dvd kind will not read large dvd-es (dual layer) or blue-ray disks..
May 29, 2010 | Iomega ZIP 250 External ZIP Drive
Not reading
Disassemble the case, and remove the disk-drive.
Attach it as a "slave" disk-drive in some desktop computer, and see if the desktop computer can "detect" the disk-drive, and if the files on the disk-drive are still accessible.
Mar 03, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
One day i was playing halo 3 and my disk drive starting making wierd, grinding noises and stopped then after the noise stopped my disk would stop spinning and now eveytime i try to read my disk my motor...
This hard disk is a easy fix, You can buy a new one for the fraction of the cost, All you have to do is slip this off the unit and apply an new or even a used hard drive. Here is some links for some hard drives http://catalog.ebay.com/Microsoft-Hard-Drive-120-GB-9Z600001-for-Xbox-360_W0QQ_fifptsZ1QQ_pcatidZ413QQ_pidZ70884347QQ_trksidZp3286Q2ec0Q2em271
you can get some for under 30 bucks. if this information helps please rate accordenly Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 02, 2009 | Microsoft Xbox 360 Console
Cd drive motor wont spin properly
...see if the laser lens not dirty and working fine...sometime if the laser lens can read the disk then the motor stop working...and in the information screen LED say "NO DISK"...
Apr 29, 2009 | Electronics - Others
Dell D600 not reading any type of disk
When the CD does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD will not be read, therefore the error.
When this problem is beginning you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with cotton tips and isopropyl alcohol, or to replace the CD drive unit.
Jan 14, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
CD/DVD drive stopped working gradually
  1. Ensure the Drive is seen in MY Computer
  2. Try removing the upper and lower filters per this article: http://support.microsoft.com/kb/314060
If the drive is seen in BIOS and in MY COMPUTER, but will not read any media after running the microsoft fix and rebooting, then replace the drive.
Jul 06, 2008 | Dell Inspiron 4000 Notebook
Lite On (SOHW-1633S-03) DVD±RW Dual Layer Burner Logo
54 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
William Alequin
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
